PCI (Not PCI-E) vs AGP
  • bigbeark
    • Jan 2010
    • 661
    Some people opt for 64MB through 256MB PCI cards in preference to the 4MB ATI-Rage onboard AGP video on server boards.
    When I wkipedia this I find that 4xAGP has a throughput of 1066Mbs, 2XAGP is 533Mbs vs 133Mbs for PCI cards. So it would seem pointless to use the PCI card.
    I have a 54MB PCI card and it seems marginally faster than the Rage Onboard, but perhaps it's just wisful thinking. I see people paying big bucks for 256MB PCI video cards. Are they deluded?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: PCI (Not PCI-E) vs AGP
    there is nothing wrong with PCI graphics cards. in fact, if its like one of mine, an ati radeon x600 or x300 (dont remember havent looked at it for a while) with 256mb ram then yes its way faster than an onboard ati rage
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      if bandwidth is not a bottleneck but gpu RAM (or gpu power) is, then go for pci. onboard tends to be crap... it may be connected internally by pci for all we know.
      sigpic
      (Insert witty quote here)
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        and keep in mind many higher-end agp cards are pci-express with a little conversion chip. same goes with pci and agp.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Think higher resolutions, HDMI outs, multiple monitors, stuff like that. It's not all about speed.
          A working TV? How boring!
            • 31067
            server video is designed to not do much more than console output, hence a whole 4meg of vram!
            i actually have a pile of pci cards like this intended for - and pulled from servers.
            • Wizard
              • Mar 2008
              • 2296
              Stj is correct. That is what INTENDED use.
              PCI has small bandwidth and quickly filled up if there is high texture load.
              AGP was nice bump up but that was from PII days. That is where PCI-E came in later.
              Yes there is one generation where some cards had PCI-E to AGP bridge chipset on some cards. But not many generations. I don't recall if ATi(AMD) had done this but I KNOW Nvidia did.
              Cheers, Wizard
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                They're still doing it actually. HD3850/4650/4670 are available in AGP flavor too.
                • BigTroll
                  • Sep 2010
                  • 1317
                  • LAMBDA SOND
                  there was a great forum troll named stilllengendary on overclock.net, his specialy was using a 600mhz Pentium /// Gateway and he kept buying stupid PCI graphics cards for it, like a radeon hd 2600 pro then back to the 6200TC and they all run like crap, he would troll about running crysis on it, however it was of good comical value for me so i wouldn't mind, but yeah a ati rage is really slow so even putting in a pci geforce 2 your gonna see huge improvement.
                  ENJOY TLDR WOT
                  My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                  • mockingbird
                    • Dec 2008
                    • 5484
                    Reminds me of that guy on StorageReview who spent a whole lot of money on his Dual Pentium Pro setup. Boy did they ever rip on him.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      There's another big difference.
                      - On most consumer mobos the PCI BUS Bandwidth is SHARED by all the PCI devices [which in addition to what is in the slots that usually includes drive controllers, USB, LAN & Sound] so that 133Mb/s you cite is not all available for video bandwidth. Much of it is being used for other things like data transfer to-from drives. If you have PCI video that hangs when a hard or optical drive spins up then an over loaded PCI Bus is probably why.
                      AGP on the other hand is a dedicated [Independent] BUS so the whole Bandwidth can be used for Video.
                      Server based boards [boards with server chipsets] usually have multiple Independent PCI Busses and some of them are 64-bit vice 32-bit so their total PCI bandwidth is HUGE compared to consumer based boards.
                      The 133Mb/s is for 32-bit 33MHz PCI.
                      - The was also a 32-bit 66MHz option [using the standard short PCI slot as in NOT a PCI-X slot] that could do 266Mb/s. It was 'legal' but implemented on very few motherboards because to make it work they needed either [at least two] Independent PCI Busses or for everything PCI to run at 66MHz. - If they had to 'wire' Independent PCI Busses anyway it made more sense to use a PCI-X 64-bit slot. [The only boards I've seen it on were too proprietary to be useful to me. I -think- they were for some obscure specific-purpose IBM Server but it's been a while so maybe it wasn't IBM.]
                      - There WERE a number of PCI cards made for the slot because they could do 32-bit at either 33MHz or 66MHz.
                      Great cards to find if you like overclocking 33Mhz PCI Busses.
                      If you find a standard length PCI card that is keyed for both 3.3v and 5v then you MIGHT have found one of those.
                      Not all dual volt PCI cards can do 66MHz but all that can do 66MHz should be 3.3v compatible.
                      Mann-Made Global Warming.
                      - Dr Seuss
                      • Shodan486
                        • Nov 2009
                        • 203
                        Cannot agree, we've seen boards being made in 2005 still with an AGP slot present, think Foxconn made some and MSI, also we have AsRock crazy solution boards with both PCI-E & AGP buses...so no, in PII days AGP wasn't a big deal, after Pentium III / Athlon generations the AGP4x held accountable superiority in bandwidth solutions against PCI/PCI64...Had an MX400 in one of my socket7 boards with AGP2x of course, the cpu was 350 K6-2 at 100FSB with 512MB RAM - warcraftIII sucked on it all the way.
                        Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Originally posted by Shodan486
                          Cannot agree, ...... the AGP4x held accountable superiority in bandwidth solutions against PCI/PCI64...
                          And I can't agree with that.
                          AGP4x was 1066 MB/s [and even 8x was only 2133 MB/s].
                          PCI-X allowed and varied between 266 MB/s and 4.3 GB/s depending on version.
                          - Dr Seuss
                          • BigTroll
                            • Sep 2010
                            • 1317
                            • LAMBDA SOND
                            i think the earlier PowerMac G3s blue and white had a 66mhz PCI slot for the rage 128 graphics.
                            • Wizard
                              • Mar 2008
                              • 2296
                              PCBONEZ is correct.
                              Mine was very kind sarcasm to AGP. Even 8x was choking on the texture bandwidth.
                              PCI-E was real saver. And cheaper too rather than trying to buy latest AGP cards.
                              Cheers, Wizard
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                as did the original G4 graphite. it was essentially a bw G3 board w/o adb with a G4 cpu in a different color. the G4 sawtooth used AGP.... and that was the end of pci video cards in macs.
                                oddly the other pci slots in both boards were pci-X length as well... but 33mhz (marked on the boards).
                                sigpic
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  I'm guessing 64-bit @/33MHz. [266Mb/s]
                                  Unusual but legal by the specifications.
                                  They probably expected the next chipset to support 66MHz and to be the same 'foot-print' so they could use the same reference board with only slight adjustments.
                                  Or: Sometimes what looks like a PCI-X slot, isn't. In that case it's a proprietary slot for a riser with multiple 32-bit PCI slots.
                                  The 'normal' section is just 32-bit PCI [so a card will work] and the extension is more 32-bit PCI(s) for the riser. [Less the power which goes through the first section to save on # of slot pins needed.].
                                  - Dr Seuss
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    not a riser, thats for sure. 64 bit would be my guess.
                                    sigpic
                                    • Shodan486
                                      • Nov 2009
                                      • 203
                                      BONEZ, we're you drinking last night? I can't see any comment on "PCI-X", I wrote specifically PCI/PCI64. PCI-X runs at 133MHz, twice as faster as AGP and has a variety of addressing features (as I recall) against AGP, which supports side band addressing (something's popping in my mind PCI-X has some more) - YES, PCI-X is definitely faster than AGP, but not PCI64 or PCI at 66MHz.
                                      To Wizard - there's is no practical performance difference between AGP4x / AGP8x.
                                      • Per Hansson
                                        • Jul 2005
                                        • 5895
                                        • Sweden
                                        Even the latest graphics cards for PCI Express see limited scaling by the higher bandwidths.
                                        See this for some numbers if you are curious;
                                        http://www.techpowerup.com/reviews/A...press_Scaling/
