Sound Jack Problems
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Sound Jack Problems
    My PC is and old Dell 4550 Dimension. Only one sound channel works out of the back of the PC. Thats ok since I think the female jack in back on the mobo is damaged. I've been using the female jack on the front under the little cover. Now this female Jack is getting dirty. The female headphone jack on my powered speakers is also acting up. What spray product would I use to clean these up? I'm a heavy smoker so thats the problem in a nut shell. I know that most any product that can clean this mess can also melt plastic. What should I use and where do I buy it?
    Mark Twain
    John Paul Jones
    Rod Serling
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Sound Jack Problems
    i have a solution: quit smoking
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      That is a good idea but it still doesn't fix the problem at hand.
      Mark Twain
      John Paul Jones
      Rod Serling
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        what abaout sticking a little brush of some sort im there gently? or maybe a cotton swab?
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          deoxit.
          i use a lot of dp5 here.
          do the rear ones too.a spritz in each hole and work a plug in them.the jacks have a through/bypass switch that gets fouled from dirt/smoke drawn through by airflow.
          • Krankshaft
            • Jan 2007
            • 2328
            Just Deoxit them as KC said the stuff is pricey locally at Ratshack but it works. I've saved tons of jacks and noisy POTs with it.
            Just spray a bit into the jack and rapidly insert and remove a cable to spread the compound and clean the contacts.
            I honestly can't remember how I found out about the stuff I may have picked it up on a whim but I'm glad I did.
            You may get away with using automotive connector contact cleaner but I wouldn't chance it I've always used Deoxit.
            • Junk Parts
              Court Jester
              • Jun 2006
              • 8953
              Thanx! I'll look for it at my local Rat Shack! We call it Chicken Shack here for some reason. I don't know why....
              Mark Twain
              John Paul Jones
              Rod Serling
                • 31278
                isopropanol on a matchstick - you know what to do.
                • Logistics
                  • Apr 2007
                  • 721
                  The last time I had a jack get all crackley and not want to work on one side I just stuck a q-tip into it and spun it around and pulled it out; worked great afterwards. :shrug:
                  • everell
                    • Jan 2009
                    • 1514
                    I have sound jack problems also. There are several Jack programs for Ubuntu, but I have never been able to get the sound to work. The Jack meters look cool, if I could ever get them to work.
                    So who is our resident Ubuntu expert? Where are you...Ratdude???
                    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • dreamlayers
                      Weird clipping on Logitech Z-10 speakers
                      by dreamlayers
                      I bought used Logitech Z-10 computer speakers. They can act as a USB audio device or accept line input, and they have a headphone output jack. Some music didn't sound right, so I played a frequency sweep and heard other frequencies and beat frequencies between them and the sweep. I uploaded a spectrogram of a frequency sweep. From the very start, some but not all odd harmonics are visible, indicating symmetric distortion. Then at higher frequencies there are descending images of those harmonics, indicating non-linearity and constant higher frequency noise mixing with the harmonics. The image of...
                      05-22-2025, 11:41 AM
                    • LEECH666
                      Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                      by LEECH666
                      Good day ladies and gentleman!
                      I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                      This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                      I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                      01-19-2024, 05:46 PM
                    • valente222
                      LAPTOP HP 15-DY2059LA / i3-12gen has stability problems in vccpu coils, BUZZING SOUND. ¿Coil whine?
                      by valente222
                      Hello friends, I just received this equipment, it has a strange hum on the board. The computer works fine, outputs an image and starts Windows. But the problem is when charging the battery, a constant loop to charge. In short, it never charges the battery. When the charger is connected, the stability of the CPU is stressed and it seems that the coils make that electrical sound louder. This board is modern and I don't have a schematic. I have checked with a microscope and the pcb is completely new. Has anyone had this happen to them before? defect in driver ic?...
                      11-18-2024, 03:21 PM
                    • StrongTester
                      Audio Jack on hp-ec1001np detects phones and external speakers but no sound
                      by StrongTester
                      Hello friends, I am having trouble with a hp-ec1001np that detects the headphones or speakers when connected to the jack, but no sound comes out. The normal laptop speakers work fine. Anyone has an idea what it might be? Did a full reinstall of windows, still nothing.
                      05-30-2023, 10:29 AM
