Fried A CPU - Why?
  • bigbeark
    • Jan 2010
    • 661
    Fried A CPU - Why?
    I put my Tyan S2466 into a case, fired it up, and kapow - the magic smoke from CPU#2.
    I used a Thermaltake TR2 430 watt power supply new out of the box. It claimed to have the 30A needed on the 5v rail to support the dual athlon MP cpus.
    I had the required power connectors hooked up 20-pin ATX, 4-pin auxiliary and 4-pin Molex.
    Why would this happen? You can see the burn mark on the back of the CPU.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Fried A CPU - Why?
    check your standoffs- you could have a screw stuck between the board and the case, causing a short.
    sigpic
    (Insert witty quote here)
    • c_hegge
      • Sep 2009
      • 5219
      Also, make sure the cooler is clipped on proberly. I had one side come undone on a Skt. A board once and the same thing happeded.
      • yyonline
        • Jul 2009
        • 692
        I once installed a Socket A heatsink backwards, it's fairly easy to do if you're not paying attention. There's a groove in one side for the plastic part of the socket to fit into. If you put it on backwards, the CPU die doesn't contact the heatsink and it overheats very quickly.
        • bigbeark
          • Jan 2010
          • 661
          I will recheck the standoffs, but the Heatsinks were positioned correctly.
          I wonder if a fan could have been bad. I DID hear some squeaking noise that may have been coming from the fan on that CPU, although the fan was spinning properly. The frying was pretty well instant as soon as I turned on the power supply.
          I wonder if the "on button" on the front of the case could be shorting.
          This is the second CPU this case has fried this week!
          • yyonline
            • Jul 2009
            • 692
            With a dead fan, the CPU would die a slow death, not an instant one, as long as the heatsink was properly mounted.
            Did it fry two CPUs in the same board, or different boards? If they were in different boards, I'd definitely check for a source for the short in the case somewhere.
            If the power button were shorted to itself, it'd just turn off, since that's how it functions normally. I've never measured the power button pins to figure out what would happen if it shorts to ground or something else...Probably not much, as with some poorly marked boards I have to go on a "hunt" for the power button pins, trying to deliberately short all the different pins until I find the right pair, and I've never damaged anything doing that.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              squeak plus same case tells me to look in the psu. maybe a short in there... maybe the mobo tray is warped, casing a short.
              this is farfetched, but i wonder if a shorted LED would do it...
              sigpic
              • seanc
                • Nov 2008
                • 1319
                I don't think a shorted LED, or lack of power would blow the CPU.
                I think trying to draw too much power would cause the PSU to shutdown, rather than any damage to other components.
                Are you certain this CPU worked before being installed into the board? Perhaps it was damaged before installation.
                Also, this 'case', has it fried two CPUs in the same board, in the same socket in this case?
                • stevo1210
                  • Oct 2006
                  • 4156
                  I use the same PSU in my main system, and have been for the past 3 years. Needless to say, they are great PSUs and I have installed them for many other people without an issue, so I wouldn't blame the PSU... unless yours is a lemon.
                  Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
                  • seanc
                    • Nov 2008
                    • 1319
                    Lemons are always possible.
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      errmm-those arent such great psus. they are nice and quiet though.
                      http://www.hardwaresecrets.com/article/332
                      edit: i had one. it exploded (not with fire) (but with a cap flying around) needless to say that caused a dead mobo.
                      im so sick and tired of my pcs having problems with cheap power supplies, im selling all my raidmaxes and deers and such on craiglist.
                      • bigbeark
                        • Jan 2010
                        • 661
                        No. Two different motherboards. Both dual-cpu, one was CUR-DLS using a different PSU,
                        and this 2466 Tyan. It was the same socket (CPU 2) but on two different mobo's.
                        I like the case because it will take the full-ATX boards without a shoehorn!
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          same power outlet? sounds like there could be a wiring fault in the outlet, sending power to the ground.
                          sigpic
                          • bigbeark
                            • Jan 2010
                            • 661
                            Yes same power outlet. Last night we had power go out multiple times. These fried CPUs happened earlier in the week. I'm wondering if there was power spiking at that time, and perhaps these 2-CPU units are more sensitive to that.
                            Do UPS (uninterruptible power supplies) help smooth out power spikes and do you recommend their use?
                            • tamerelapute
                              [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                              by tamerelapute
                              I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                              Except the cpu, I cant feel anything getting warmer.
                              I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                              I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                              I believe that if the cpu was fried,...
                              07-08-2024, 03:28 PM
                            • x_orange90_x
                              Samsung UN65AU8000FF fried by water
                              by x_orange90_x
                              I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                              10-16-2025, 08:40 PM
                            • Lapsmith
                              Fried capacitor on Dell-5520. Guilty as charged.
                              by Lapsmith
                              While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                              07-06-2025, 11:08 PM
                            • amuse619
                              Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                              by amuse619
                              Hello!
                              Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                              Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                              08-14-2024, 01:22 PM
                            • triplefour
                              LG 55LF6000-UB main board swap from 55UH6090 powered up but component on MB fried.
                              by triplefour
                              So I was trying to repair this tv. Board independent tests prove Psu is good. Backlights are good. But mainboard does not turn on or respond in any way to button or remote. I dig around and find some parts I've stashed from other LG tvs and find the box for 55UH6090 which says all parts were good. Taken from bad panel tv. It looks different and takes a different tcon but the connections to the Psu and to the tcon are conpatible. I figure what the hey just try it. So I do. At first I don't connect the tcon. It powers up fine, backlights and everything. Turn it off, plug in the tcon and turn it...
                              04-01-2022, 11:03 PM
