My new CPU Cooler
Re: My new CPU Cooler
Yup
Funny, what you want is exactly what I wanted when I set out to build my system more than a year ago. Great with media, quiet, expandable, and great quality. Just a nice, solid, reliable tower that's always there when I need it. You described my system perfectly, except I am running C2D instead of C2Q.Comment
a c2d would not be bad, but if i am ditching the PDC, i want to go all out. now if i came into a c2d cheap/free (you would be surprised what i have gotten for freebies), i would take it, but if i really was investing in it, a c2q would be nice (as would 8gb ram and a better graphics card, but thats another dream).sigpic
(Insert witty quote here)Comment
I picked C2D because the C2D vs. C2Q benchmarks failed to impress me. So far my C2D (E7500) has yet to even show signs of struggling with anything I've yet to throw at it. Runs 64-bit stuff like a boss. If you are buying retail, C2D has a good power/price ratio IMO. Not to mention C2D and 775 are at that sweet spot where they have reached maturity but are still considered modern.Comment
i saw that... you have a good point. doesn't matter as the pdc will have to do for now.sigpic
by BleedCapI already posted this on vogons.
Its a 3d printed custom bracket for socket 478.
I used this AM4 bracket as a base design.
Its to be use with cheap generic clip based cpu cooler.
Reason for doing this is:
- Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
- New generic cooler is cheaper and can use bigger fan (less noise)
I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
The processor that I was using is P4 2.4Ghz prescott....-
by Uranium-235I have a 5900x to replace my 5800x (actually a fair bit of performance difference). It came with the CM. I can't actually find any article of a direct comparison between the two. The Fuma has a Higher TDP but the CM looks to have a more solid build. Fresh AS5 either way.Scythe Fuma 3100.00%1Cooler Master MA620M0%0
by Ede2001I am looking for a boardview file or schematic for the EVGA GTX 780 Ti SC w/ ACX Cooler video card.1 Photo
by edugimenoHi there!
I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some... -
by KYBOSHPicked this one up today.
In addition to falling LED diffusers there is a single line here that maybe a deal breaker.
From my reading on these boards it is said that the issue is likely a sign of failed tab drivers, ribbons or tab bonding to the panel.
Wanted to get a 2nd opinion from you guys before I gave up the ghost.
Great looking TV otherwise.
Is there any tricks I can do to try to save this one?
If so, i'll gladly order a set of backlights and save this one from the landfill..
Thanks in advance
... - Loading...
