DIY PSU load tester
  • c_hegge
    • Sep 2009
    • 5219
    Re: DIY PSU load tester
    I'm going to be using CPU heatsinks on mine. With no fans, it takes less than a minute before they are too hot to touch. I'm hoping that the fans in the case i've knocked up can do the job.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      #42
      Well it turns out it isn't that bad after all. I decided to see just how much the MOSFETs will take, and managed to get 14 amps @ 12.10v for a couple minutes before they gave up. That's 170 watts! And what's even more surprising is that two of them went short but one survived - even though there is visible heat damage to the plastic case!
      Since this was an absolute worst-case scenario, 170W/3 mosfets means a total of 1.7 kW, and i will rarely have to deal with power supplies >600W, i'll just go ahead and build it with PSU heatsinks. Now time for some PCB design.
      A working TV? How boring!
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        #43
        Not sure if this is a useful design suggestion, but perhaps you can submerge part of the heatsinks in water all the way up to the MOSFETs, keeping the MOSFETs dry of course. I think that should give you much better cooling. When the water gets too hot, change it .
        Or you can also use mineral oil and completely submerge everything since it's non-conductive.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          #44
          There would be no problem with submerging the MOSFETs in water either due to the low voltage (well, except generation of hydrogen...), but i don't want to go that route. I just tested the 8 fans glued together - and i'm starting to get worried they might take off or something. I think they're gonna be enough.
          • c_hegge
            • Sep 2009
            • 5219
            I would be more worried about the possibility of corrosion if they were under water. Hydrogen is awesome stuff when you have a box of matches handy
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              #46
              Don't remind me - i was bored one night and was doing just that... One of the bubbles exploded so loudly that it was amazing it didn't wake anyone up.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4953
                • New Zealand
                #47
                How about a PC watercooling kit? Wouldn't need to immerse the heatsinks in water then. Would be expensive though.
                -David VanHorn
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  #48
                  Not to mention the waterblocks wouldn't offer enough space, unless i'd be mounting the 'fets on the main radiator. This isn't a 150W quadcore, it's from 150W up to one kilowatt remember.
                  8x 80mm fans seems to be enough but i'll add two more anyway, AND leave provision for some on the front. I'll have to go pick up the meters and come up with the design and material for the front panel then i can commence building the rest.
                  Oh and if all else fails... there's no one stopping me to change the fans for 240v ones.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    170W x 3 doesn't mean 1.7 kW, try 510 watts.
                    Water cooling is just a gimmick to sell crap to gadget addicts.
                    There are a number of Xeon CPU's that hit 150 watts and factory air cooling works fine.
                    Should be able to rework some copper core coolers to get the job done.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      #50
                      The nominal dissipation is intended to be 35W/mosfet, that is 105W per heatsink. There are 30 mosfets and 10 heatsinks. 105 x 10 = 1kW. I said that the dissipation limit was tested at 170W over one heatsink, before the 'fets fry. Or at least two of them did. 170 x 10 IS 1.7kW. Furthermore, i left the remaining good 'fet along with two new ones at 10.2A / 11.84v for 30 minutes. That's 121W. They held.
                      So it seems that this will be capable of 1.2kW load medium term - you don't need more than 30 minutes to test a PSU anyway. Though i do agree that the PSUs i will test will average at 500W, my math isn't wrong.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          @/35w each you could use some Prescott coolers you could easily put 3 or 4 MOSFETs per cooler which might save space depending on your layout.
                          Just drill and tap the heatsinks and you could attach them directly with machine screws.
                          - Dr Seuss
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            #53
                            There i was referring to the total power. 170W over three meant 1.7k over 30. Sorry for the misunderstanding.
                            Anyway, i have enough of those ATX power supply heatsinks that i can do just two per heatsink. At 12A going thru 4 of them temperature settled at 95C which isn't that bad. That's with just three of 8 fans running so i guess they'll do fine. And what they can do short term is rather incredible. I got my 20A meter to read "out of range" for a minute or so before the 'fets got too hot and i had to lower the current. If four of them can do this to a 12v rail, i can just imagine what twenty will. Btw, the 420W Powerlink PSU that i am abusing for testing seems to be holding up so far.
                            I'd rather use the heatsinks i have now rather than buy some more, unless i can buy some Prescott coolers on the bulk i'd just use those that i already have.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              #54
                              Sometimes boredom can be good. I was bored today and had a spare fan from a gutless wonder i can't be bothered to fix. It's a "Te Bao Metallic Plastic Co" fan. So what could be more entertaining than testing it to see how much it'll take before blowing up? I knew Intel stock coolers generally go kapow at 18 volts.
                              The only problem was, i couldn't blow it up. I ran it up to 27 volts which is the limit of my adjustable supply, and it just kept on working. More so, it produced an impressive amount of airflow.
                              So i decided to see whether the group of fans i'll be using for my load tester can take the same. Well what'd you know... each of them did. Actually, with all 8 fans running the poor little transformer gives up at 14 volts, with 4, at 20 volts. At 20v x 4 fans the amp meter reads 0.83A.
                              Even at "just" 20 volts, four 80mm fans make a ridiculous amount of airflow. If i was worried about them taking flight at 12v, now i actually have to hold them so they don't move. I have a huge 2x 24v transformer, it's not too practical but i guess i can use one winding to feed the fans. Now i just have to figure where would i put it. Certainly not in the load tester itself. Oh, and i also got myself something that'll do nice for a front panel.
                              Edit: I hooked up the big transformer. I only went up to 21 volts with all 8 to make sure i don't damage the fans. All i can say is... GOT CFM?
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Wouldn't it be simpler and less expensive for this project to mount them as passive cooled and use a 12-14 inch AC powered box fan to cool the whole box?
                                - Dr Seuss
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  #56
                                  I'm not going to rip out the bathroom fan for this.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Good idea.
                                    Bathroom fans only move 50-100 CFM which is why I didn't suggest them.
                                    The kind of fan I did suggest would cost about the same as a bathroom fan, be MUCH quieter, and get you roughly in the range of 600 CFM.
                                    - Dr Seuss
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      #58
                                      Well an additional problem with a mains powered fan would be the 50hz field it radiates, with signals in the tens of mvs nearby, it wouldn't be such a good idea.
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Um, it would be rather silly to put a fan that big so close to the PCB.
                                        And a simple grounded wire mesh grill would provide all the shielding needed.
                                        - Dr Seuss
                                        • c_hegge
                                          • Sep 2009
                                          • 5219
                                          I Just ordered the last of the components for mine. For a 700W loading capability I've gone with the following resistors
                                          3.3v: 3x 0.33ohm 50W (30A)
                                          5v: 6x 1ohm 50W (30A)
                                          12v1: 8x 5ohm 50W (19.2A)
                                          12v2: "
                                          -12: 1x 120ohm 10W (0.1A)
                                          5sb: 1x 5ohm 10W (1A)
                                          All 27 resistors will have a switch in series with them
                                          • AJ847.63e
                                            Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                                            by AJ847.63e
                                            Hi Folks,
                                            Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                                            I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                                            The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                                            05-06-2025, 10:37 PM
                                            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:20 PM
                                            HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                            09-06-2024, 10:56 AM
                                            HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                            This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
