Has anybody hacked into these yet since amazon has discontinued them. I am so tired of seeing the low signal strength. Thanks Michael
Fire TV Recast
by jczarniakHi,
Is there available any Android Fire TV ROM backup ( Fire TV Firmware ) which I can download, save on USB stick and then load into the TV ?
I have got JVC LT-50CF810 Fire TV with firmware not working properly.
Thank you very much for any support.
Regards. -
by rwkishCapacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
by paulocoobHello forum friends.
I want to ask for help diagnosing this GPT52 LA-k201p HP 250 G8 card (without dedicated GPU).
The motherboard turns on and consumption is 2.2A (CPU fire)
All voltages seem OK.
The coil resistances are these
[FONT="<font style="vertical-align: inherit;"><font style="vertical-align: inherit;">Lucida Sans Unicode</font></font>"]PL302 = 3.2kΩ
PL301 = 30.1kΩ
PLB2 = 10.1MΩ
PLZ1 = 22Ω
PLZ2 = 22Ω
PLG1 = 77Ω
PLM1 = 5Ω[/FONT]
Could...11-13-2023, 07:54 AM -
by valvashonYesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting... -
by conghuymsI have a COLORFUL GeForce GTX 1060 3GB that is not working. After replacing the NCP81174 ic, the card works again. but 2 mosfets Q625 and Q619 fire . Replaced 2 mosfets Q625 & Q619, still burned. the position I marked in the attached image.
please help me. thank you so much... - Loading...
