Blown cap on old dwell gauge - kal equip 2851
  • snakeintheeaglesshadow
    • Dec 2021
    • 10
    Can anyone help ID this cap, or any tips on how to figure it out? As you can see, it's clearly fried. Unfortunately the burn marks obscured the color bands. I couldn't get a good zoom on it with my phone, so I hope the pics are enough. I can try again if not.
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Blown cap on old dwell gauge - kal equip 2851
    looks more like a resistor to me ..what does it connect to ?
    • R_J
      • 9551
      Looks like a resistor to me also, post a clear picture of the trace side of the board. Also post the number on the component next to the burnt resistor.
        • Dec 2021
        • 10
        Thanks both for the quick replies. Sorry I couldn't respond until now.
        Attached are pics of the trace side and (I hope) a clearer pic of the numbers of nearby components.
        I believe it connects:
        The very purple resistor (?) to the left of it
        The black three post component (not sure what it's called)
        Two white 'blocks': .1J100# and (horn?)33nJ250 (obviously not so sure on the symbols)
        Last edited by snakeintheeaglesshadow; 07-19-2022, 10:58 PM. Reason: More info and correction
          • 31065
          desolder it and check its resistance
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            looks like a track got burned through .
            • redwire
              • 3910
              I followed the circuit a bit, but can't tell what all the wires go to. The burnt resistor connects to the red wire near the LED, see pic.
              I would say it's 82R based on the grey band and smoke, so power shorted to that wire. It's a weird fault, someone must have connected up the wires wrong to the board. +12V power is supposed to connect to the top right corner. The CD4069 IC then gets 9VDC power.
              OP a resistor does not burn up unless there is an overload caused by another issue. So replacing the resistor will just smoke it again. The other resistor looks OK it just has a purple body. I can't see any cooked pcb traces, it's just solder-dipped might appear that way?
              The transistor typically connects to the ignition coil/points, but here it's missing all the surge protection parts so I'm not sure where they are.
              • petehall347
                • Jan 2015
                • 4427
                • United Kingdom
                here doesn't look right ..
                • petehall347
                  • Jan 2015
                  • 4427
                  • United Kingdom
                  that transistor looking thing might be shorted ..best check its id number then test it .
                  • redwire
                    • 3910
                    You're right trace should be flat but I have seen that as a solder blob from the tinning process, on PC boards made in the 1980's like this one.
                    The dwell meter reminds me of Sun, Sears Craftsman etc. circuits. PCB marked 01-4221B so it might be made by them.
                    • desert-rat
                      • Mar 2014
                      • 4103
                      Yeah that's a res. Can you read the colors on it ? And yeah check whatever it is connected to.
                        • 31065
                        a lot of times a resistor can get that hot and still work - it just got very hot from the real fault
                        so always worth metering it
                          • Dec 2021
                          • 10
                          Wow what great input! Very impressed by this community.
                          Can you recommend a specific resistor(s) to try?
                          I found it among my late father's hot rod stuff. No instructions of course, so I just plugged it up. Incorrectly, obviously.
                          Ah ha! I think I know where I went wrong attaching it. With no surge protection built-in, must be pretty easy to fry.
                          On the attached pic I attached the each colored lead to it's corrsponding connector on the board. I'm thinking the correct attachment points to engine are:
                          Red = ignition coil positive
                          Black = ground
                          Blue = ignition coil negative
                          Inductive pick-up = spark plug wire
                          Would this work even if blown? I figured it stops 'resisting' when such.
                            • 31065
                            but is it blown, or just got hot enough to burn the paint??
                            thats the reason to test it
                            • desert-rat
                              • Mar 2014
                              • 4103
                              Check it with an ohm meter. If you need a new one the color bands are a key to its value.
                              • redwire
                                • 3910
                                Where does this red wire go? It mistakenly got +12V power on it which is what smoked the resistor.
                                  • Dec 2021
                                  • 10
                                  That goes to two AA batteries. Just FYI the other red wire in the pic goes to a 9v battery.
                                  • redwire
                                    • 3910
                                    Um, how many batteries are in this? A pair of AA's and a 9V?
                                    Usually these run off the 12V power at coil(+) for tach, dwell. Maybe the battery is for small engines.
                                    Unless... this meter must have an ohmmeter function? That would explain the smoke lol.
                                    I would measure the burnt resistor value and see if its good for a guess at what it was or its dead. For ohms function (slide switch to the right?). One leg of the burnt resistor connects to GND.
                                    The small transistor is the inductive pickup amp and although nearby it is not a suspect.
                                      • Dec 2021
                                      • 10
                                      Yes indeed. Three batteries total. I would kill for a set of instructions to know why haha.
                                      It does have this function! I probably should have put all of the functions in the title. Attached is a pic of the front. It does dwell, tach, volts and ohms.
                                      Ok that will be my next task. I think I found a few good youtube tutorials.
                                      Precisely! Volts/ohms. The other switch is for tach/dwell.
                                      • desert-rat
                                        • Mar 2014
                                        • 4103
                                        Did you try to see if it would work? Volts and ohms are easy to check. For tack and dwell you would need an old car with points.
                                        • cmlewis89
                                          LG 47LB5DF blown power supply board
                                          by cmlewis89
                                          Hi folks,
                                          I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                                          09-03-2024, 07:50 PM
                                        • drscoot
                                          HP X360 convertible battery blown fuse error, not charging
                                          by drscoot
                                          HP Modelnumber: 14-dh0061nb​
                                          This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                                          The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                                          I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                                          And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                                          All these 3 batteries are charging...
                                          12-15-2023, 05:54 AM
                                        • swerg
                                          Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                                          by swerg
                                          Hey everyone,
                                          I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                                          I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                                          I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                                          06-06-2024, 03:39 PM
                                        • MrzPdlch
                                          Blown fuses on Gigabyte GTX 980TI 6GB
                                          by MrzPdlch
                                          Hey everyone,
                                          I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                                          Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                                          Find some pictures of the actual GPU together with a picture of how it should look like.
                                          I also wonder whther it might be a problem that there...
                                          03-10-2024, 04:14 PM
                                        • cheeky2
                                          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                                          by cheeky2
                                          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                                          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                                          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                                          06-15-2025, 05:12 AM
