New Capacitor brand
  • bambino
    • Jan 2010
    • 7
    New Capacitor brand
    I have some capacitors with the text:
    SSL +85°C
    K
    S
    10uF 35V
    are this bad or good?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: New Capacitor brand
    wrong section to post in... and pics would be helpful.
    sigpic
    (Insert witty quote here)
    • retiredcaps
      • Apr 2010
      • 9271
      And what application? 85C is unsuitable for many of the newer hotter electronics where there is no active cooling (i.e. fan).
      --- begin sig file ---
      --- end sig file ---
      • Scenic
        o.O
        • Sep 2007
        • 2642
        those came out of a set top box DVB-T receiver. Top vent is a slightly stretched X
        i think those might be samsung..
        edit: uhm.. my webspace is acting up. there should be 3 pictures above this text. ftp server works fine, http doesn't work at all
        if you can see the pics, it works again.. but right now it doesn't.. i'll leave the images in here anyways..
        • robert
          • Jan 2008
          • 69
          SSL? Looks like Samsung. Especially if its green.
          And yes, its crap. Now sold under the name of Samwha, which is well known to anyone repairing TVs...
          • bambino
            • Jan 2010
            • 7
            I have capacitors at the same style, but the color is brown,
            105°C ST
            L D
            S
            • Scenic
              o.O
              • Sep 2007
              • 2642
              i know why my webspace isn't working now. hoster disabled it. said i didn't log in in the last 100 days.. total BS..
              oh well.. re-uploaded to a long forgotten free-hoster account.. (where i didn't log in for at least 2 years.. still everything there lol )
              • bambino
                • Jan 2010
                • 7
                should be low ESR capacitors in a radio be?
                sorry,but my english is not good, im from belgium.
                • MORETTIGIAN
                  by MORETTIGIAN
                  Title:
                  Description:
                  Procedure performed:
                  - Removed backplate
                  - Reapplied thermal compound
                  - Reassembled card
                  09-18-2025, 12:14 PM
                • Prolog
                  by Prolog
                  12-01-2024, 08:27 PM
                • Agent24
                  Dick Smith Q-1760 linear power supply filter capacitor question
                  by Agent24
                  I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                  It has at least one problem.
                  The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                  I have already ordered a replacement potentiometer, so that's not an issue.
                  Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                  All are CapXon...
                  10-21-2025, 05:39 PM
                • chth96
                  by chth96
                  12-22-2023, 04:34 AM
                • oldirdey
                  Need help to identify capacitor brand
                  by oldirdey
                  Want to repair some broken floppy disk drives. I need help to identify the brand of this capacitor to find a suitable replacement.
                  Did someone know the brand of the capacitor or a suitable replacement in terms of esr / ripple?...
                  07-15-2021, 03:17 AM
