New Capacitor brand
  • bambino
    • Jan 2010
    • 7
    New Capacitor brand
    I have some capacitors with the text:
    SSL +85°C
    K
    S
    10uF 35V
    are this bad or good?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: New Capacitor brand
    wrong section to post in... and pics would be helpful.
    sigpic
    (Insert witty quote here)
    • retiredcaps
      • Apr 2010
      • 9271
      And what application? 85C is unsuitable for many of the newer hotter electronics where there is no active cooling (i.e. fan).
      --- begin sig file ---
      --- end sig file ---
      • Scenic
        o.O
        • Sep 2007
        • 2642
        those came out of a set top box DVB-T receiver. Top vent is a slightly stretched X
        i think those might be samsung..
        edit: uhm.. my webspace is acting up. there should be 3 pictures above this text. ftp server works fine, http doesn't work at all
        if you can see the pics, it works again.. but right now it doesn't.. i'll leave the images in here anyways..
        • robert
          • Jan 2008
          • 69
          SSL? Looks like Samsung. Especially if its green.
          And yes, its crap. Now sold under the name of Samwha, which is well known to anyone repairing TVs...
          • bambino
            • Jan 2010
            • 7
            I have capacitors at the same style, but the color is brown,
            105°C ST
            L D
            S
            • Scenic
              o.O
              • Sep 2007
              • 2642
              i know why my webspace isn't working now. hoster disabled it. said i didn't log in in the last 100 days.. total BS..
              oh well.. re-uploaded to a long forgotten free-hoster account.. (where i didn't log in for at least 2 years.. still everything there lol )
              • bambino
                • Jan 2010
                • 7
                should be low ESR capacitors in a radio be?
                sorry,but my english is not good, im from belgium.
                • MORETTIGIAN
                  Capacitor detached from PCB – RTX 2070 Super Founders Edition
                  by MORETTIGIAN
                  Title:
                  Description:
                  During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                  I did not notice it detaching, so I am unsure of its original location on the PCB.
                  Procedure performed:
                  - Removed backplate
                  - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                  - Reapplied thermal compound
                  - Reassembled card
                  Observed behavior after reassembly:
                  - GPU powers on and operates normally under...
                  09-18-2025, 12:14 PM
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
                • chth96
                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                  by chth96
                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                  I know that these capacitor will not last as long as nichicon capacitor...
                  12-22-2023, 04:34 AM
                • oldirdey
                  Need help to identify capacitor brand
                  by oldirdey
                  Want to repair some broken floppy disk drives. I need help to identify the brand of this capacitor to find a suitable replacement.
                  Did someone know the brand of the capacitor or a suitable replacement in terms of esr / ripple?...
                  07-15-2021, 03:17 AM
                • chth96
                  Is it no harm to replace with capacitor without ripple current rating?
                  by chth96
                  When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                  Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                  But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                  Rubycon YK DataSheet (b...
                  04-19-2024, 05:19 AM
