What damage can occur when a filter cap explodes?
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Hi all.
    Following on from my previous thread...
    Just wondering which other problems (if any) can be created further down the pcb when a reversed polarity filter cap explodes?
    Trying to get a better understanding for future repair diagnostics.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: What damage can occur when a filter cap explodes?
    The diodes can fail because of the extreme current draw of the capacitor.
      • 30979
      high ripple can blow chips downrange if your really unlucky
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        Thanks for those replies.
        It did make me wonder, as there would not be any collapsing coil fields, but clearly such dramatic events would not be without consequence.
        @Per
        Are you talking about the bridge rectifiers? Or any diode nearby?
        @STJ
        Regarding blowing chips downrange through high ripple, would that be instantaneous, or only if left switched on and in circuit?
          • 30979
          damage from ripple would be over time
          • Crystaleyes
            • Sep 2021
            • 493
            • Brazil
            Cool.
            That is what I would have thought.
            At least I appear to be thinking along the right lines.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              But if it "explodes" explodes, I'm imagining you might keep the thing off till you replace it
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8118
                Last time my main filter cap shorted in the psu of my oscilloscope. All damage it did was the main filter cap shorted and a fuse blown. So it really depends on the build quality of the power supply.
                • Crystaleyes
                  • Sep 2021
                  • 493
                  • Brazil
                  Actually I bought the unit already like that. It was part of a cheap 'job lot' from a repair shop, and considering how I am still learning all this electrickery, it seemed like a good opportunity to learn a bit more.
                  This particular cap was on the PSU of one of two Kenwood CS4035 scopes, which had both been dead when received. I've been messing with this one today (with a new cap) as changing the exploded cap has revealed other issues further along which I'm struggling to identify right now. No direct shorts but something on the main board is pulling the + & -8v lines down to ~6v on both the scopes.
                  These scopes have half a dozen 'hybrid' IC's which seem to be non-existent in the world of datasheets, so hopefully they are not the problem.
                  After pulling and testing all the caps on the PSU, it might be the next step to see if a cap or two is failing on the main board.
                  This is the area I need to learn how to speed up on...
                  • Crystaleyes
                    • Sep 2021
                    • 493
                    • Brazil
                    Thank you. Good to know.
                    The PSU is now working apart from the reference voltage adjust pot. This may well be one of these hybrid IC's playing up (a KMA 01).
                    For now, the -8v reference is -8.6v so I'm not stressing, more important is what on the main board is pulling the voltages down 25%
                      • 30979
                      hybrids can often be replaced,
                      the schematic will give you an idea of what they are doing.
                      it could be as simple as a bunch of transistors that have exactly matching spec.
                      • Crystaleyes
                        • Sep 2021
                        • 493
                        • Brazil
                        There is actually a .pdf online of a template and component layout for one of them. Fingers crossed that none have failed.
                        I'll start a new thread regarding the scopes project
                        • PeteS in CA
                          • Aug 2005
                          • 3579
                          • USA, Unsure of Planet
                          If it’s an electrolytic, the liquid electrolyte is very conductive and could cause shorts.
                          PeteS in CA
                          • petehall347
                            • Jan 2015
                            • 4426
                            it could blow your eardrums and blind you if it hits you in the eye .
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              I can tell you guys this...if a polymer explodes, it smells like popcorn
                              • PeteS in CA
                                • Aug 2005
                                • 3579
                                And the cases tend to launch.
                                PeteS in CA
                                • PeteS in CA
                                  • Aug 2005
                                  • 3579
                                  I haven't heard any lytics going off that dramatically, but my experience is, obviously, finite. OTOH, when a wet slug tantalum went of a couple of feet from me my ears were ringing for an hour or two. I have seen both lytics and polymers launch.
                                  PeteS in CA
                                    • 30979
                                    i had a high voltage dump cap from a big xenon strobe lamp explode in front of me once,
                                    that wasnt fun - electrolyte all over me - paper all over the room.
                                    metal can probably bounced off several walls!
                                    • PeteS in CA
                                      • Aug 2005
                                      • 3579
                                      Actually, I do remember a lytic launch. I was working at Boschert, and a new engineering tech was working on a 48V input DC-DC converter prototype. The assembler had accidentally installed a 7.5V cap on the input instead of the correct cap (75V?). He applied power and after a couple of second the cap launched and hit him in the chest. He wasn't hurt, but I didn't see him in the test are for an hour or so.
                                      Another time, at Tandem Computers (not Tandy) we were doing rehearsals of "abnormals" tests for UL. The method was to select a component to short or open and then apply power to see if the power supply failed safely. In one of tests we shorted one of the series-connected input electrolytics. When 208VAC was applied, that put over 300V across 200V caps. What was supposed to happen was that one of those caps would short and blow a fuse. Well, this time it started venting steam, like it was going to launch. We all scattered for a few seconds until someone had the courage to switch off power to the power supply we were testing. This was not a good outcome and was totally unexpected. The safety people tried multiple time to duplicate what happened, but always had what was expected happen.
                                      About a year before I hired on at Boschert they had moved their manufacturing to Manteca, a California city a couple hours' drive away. Some employees moved there, a few stayed, and some moved on. The senior engineering tech had been the manufacturing test supervisor. One day he showed me the ceiling above what had been the manufacturing test area. There were quite a few circular holes in the ceiling tiles from reversed or incorrect caps that launched.
                                      Also from the 1980s at Tandem, I was testing some prototype power supplies that had screw terminal output caps mounted on bus bars. When I powered on one I heard a faint pop, switched off power, and found that the output caps were reverse-polarity. The little vents had popped open, and some electrolyte dripped out. The power supply had shutdown-and-retry current limiting, so I'm not sure whether anything more dramatic than dripping electrolyte would have happened.
                                      All these memories are from the 1980s and are a bit dusty and dim.
                                      PeteS in CA
                                      • Joel Ohana
                                        Lenovo IdeaPad 3 15IAU7 that suffered water damage
                                        by Joel Ohana
                                        I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
                                        Symptoms:
                                        • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
                                        • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
                                        What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
                                        03-06-2025, 11:25 AM
                                      • azozexd
                                        Need help hp 725 g3 liquid damage
                                        by azozexd
                                        Hello freind i have hp elitebook 725 g3 White liquide damage
                                        after cleaning the board i find à damage resistor white no value i test it not reading in multimeter
                                        could some one tell me the value of this resistor
                                        Thank you...
                                        12-15-2024, 06:01 PM
                                      • mon2
                                        A1466 Macbook Air (Liquid damage repair)
                                        by mon2
                                        Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                        Macbook AIR Model A1466 Diagnostic 09-01-2021
                                        Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                        Problems & Resolutions
                                        1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                        09-01-2021, 09:31 AM
                                      • rtstorm
                                        HP EliteBook 840 G8 water damage - identify component
                                        by rtstorm
                                        Hello, i got an HP EliteBook 840 G8 that has water damage, and i found this component has damage on it U60600. What is that component? I have schematics and boardview and the par no is:
                                        SINERGY_SYV128RAC_QFN_20P i cannot fount it anywhere. Is this component have some other name?
                                        Here is schematics + boardview...
                                        09-18-2024, 05:36 PM
                                      • Jenzo
                                        MacBook A1989 overheating after liquid damage
                                        by Jenzo
                                        Hey everyone,
                                        Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
                                        I can't figure out how...
                                        05-13-2023, 07:58 AM
