New, unused capacitors bulging?
  • japlytic
    • Oct 2005
    • 2086
    Twice I have seen an electrolytic capacitor (new - never used, never had a volt applied to it) which has bulged over time. Both were different brands.
    Can anyone throw some light on this matter please?
  • c_hegge
    • Sep 2009
    • 5219
    Re: New, unused capacitors bulging?
    https://www.badcaps.net/forum/showthread.php?t=8312
      • 31170
      not seen that, i had some shit ones that leaked around the wires though!
      • severach
        • Aug 2007
        • 1055
        I got in a pack of 10 motherboards that sat for a year. Never used or seen heat other than factory construction and testing. About no name 10 caps on every board were bulged. Board quality was very low and it was easy to burn traces so the dual P3 boards were scrapped.
        sig files are for morons
        • japlytic
          • Oct 2005
          • 2086
          I've been told that a chemical reaction occurs (which produces gas and makes the capacitor bulge) in the capacitor if there are two incompatible chemicals and metals inside it. What might those chemicals and metals be?
          • sofTest
            • Aug 2008
            • 361
            Are you sure it's not just a dud (from the forming at the factory), that slipped through quality control? Or did it bulge while in your possession? I received one in a lot I bought a good while ago.
            Be a mensch
            • japlytic
              • Oct 2005
              • 2086
              The capacitor in question was not bulging when I received, but over time, it bulged, even though it was not soldered in a circuit.
              • TheLaw
                • Jan 2011
                • 477
                That doesn't make sense. Something must have happened....atmospheric pressure or something....
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  It makes perfect sense, the electrolyte activated with the impurities in the aluminium and created gases, since it is a closed container something has to let go...
                  • TheLaw
                    • Jan 2011
                    • 477
                    Then wouldn't you think that would happen more often?
                    • c_hegge
                      • Sep 2009
                      • 5219
                      I've seen it happen myself once too (since I posted that link to the thread). We ordered a brand new PSU at work and it had fuhjyyu caps. They were bulged even though we never even fired the PSU up.
                      • TheLaw
                        • Jan 2011
                        • 477
                        I suppose if the material used is absolutely crude. Junk aluminum and junk electrolyte. I could see something bad happening.
                        But I wouldn't expect that in a high quality cap.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          The only time I've ever seen a new good cap was a Panny I ordered, although I'm pretty sure it was just a manufactured dud that slipped through the QC Checks, but fuhjyyu is the only brand I've known to bulge just from sitting on the shelf.
                          • brethin
                            • Dec 2008
                            • 1907
                            Must have been a really bad batch or stored improperly for them to do that. Within spec a cap should never produce enough gas to vent never having been used and properly stored.
                            My guess is they were exposed to heat for a period of time. We all know even a new cap tossed in a fire will explode.
                            • yyonline
                              • Jul 2009
                              • 692
                              I bought a new old stock Slot A board on eBay a few years ago...Jetway if I remember correctly. It was definitely never used, still sealed in the box. That said, it was 10 or so years old. It was full of GSC caps, most were bulged. I don't know what kind of conditions it was stored in, obviously.
                              • Pyr0Beast
                                • Feb 2009
                                • 406
                                I've seen caps bulge even after you heat the PCB from lets say, graphic card.
                                • Hitto
                                  Slightly Bulging Capacitors
                                  by Hitto
                                  Would you consider a slightly bulging capacitor defective if it measures perfectly and it is brand-new? To be honest, they are all equally like this: vent is not totally flat but they have very low E.S.R. and VLOSS is negligible.
                                  So, everything seems perfect apart from the vent looking a bit "strange". They are genuine capacitors, BTW.
                                  The bad thing is that they are 400V capacitors so testing them just to check how much they last would mean using them on the primary of a power supply, which means the risk of damaging the whole circuit.
                                  What do you...
                                  12-23-2024, 05:08 PM
                                • dragon3x
                                  After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                  by dragon3x
                                  Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                  power on.
                                  Here are some examples :
                                  (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                  switching supply area).
                                  (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                  than 6.3 V.)
                                  1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                  I replaced capacitors with aluminum-polymer.
                                  3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                  03-21-2025, 02:46 PM
                                • slybunda
                                  AA and AAA battery charger capacitors?
                                  by slybunda
                                  hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                  it has inside:
                                  2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                  2 x 470uf 16v LZ105c branded as G.Luxon
                                  not heard of these brands are they any good?
                                  iv attached photos of the charger and the board inside for an idea on the type of...
                                  12-24-2023, 04:41 AM
                                  by sam_sam_sam
                                  After all of...
                                  07-13-2024, 08:14 PM
                                • Cama
                                  Solar Inverter - SMH-II - 2 missing capacitors
                                  by Cama
                                  I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                  My model is : EASUN SMH-II 7 KW
                                  Mother Board : P/N 18947-002401250250
                                  Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                  Thank you...
                                  09-12-2025, 02:50 AM
