Need replacements for Samxon HP
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    I've been looking through all the best brands (rubycon, nichicon, UCC) with little success (edit, I mean I find them out of stock, or only stocked in other countries). Is there a mid-range brand for these
    Must be:
    315v-400v
    470uf (560 maybe)
    1.7ARMS
    30mm diameter max
    40mm height max
    Mid-range caps are fine and you guys are up to date on other brands
    for: Plasma TV main power board
    I know some are bloated and I plan to replace as many as I can
    Middle mains are Samwa
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Need replacements for Samxon HP
    There are a couple on Mouser after clicking through their filter system.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      One of the first places I looked. I used their filter system. The only one within a good price is 85c. I'm not sure I'm comfortable with that
      • PeteS in CA
        • Aug 2005
        • 3579
        • USA, Unsure of Planet
        Is Hitachi available? Panasonic?
        PeteS in CA
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          Already searched through through panasonics series
          I'd be just fine with a medium-grade brand right now. Might just bump up V/uf for life purposes
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            Come on guys I gave you the caps database, which is surprisingly like the #1 link on a few searches I came across. I should of put ads in there I knew it!
            Suggestions please
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              You're not going to find a cheap capacitor with the ratings you specify unless you look on the used market.
              The ones I linked are all fine, the 85°C version would be no problem unless the designer of that TV was really stupid.
              Here is a list from Digikey, very similar: https://www.digikey.com/en/products/...ACeLCpq1JKCdQA
              EDIT: Well, after looking at the Samxon datasheet it looks like they should be 35mm wide, unless this was a custom order.
              If so there are allot more choices.
              That said bulk filtering caps rarely fail, so if you want to cheap out you could just leave them alone.
              I would check in-circuit ESR and capacitance though to make sure it is in the ballpark.
              EDIT2: And if the caps are the same as in this users post this all feels a bit meh:
              https://www.badcaps.net/forum/showpo...8&postcount=55
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                No, the HP 315/470 has two, one 35 and one 30x40
                I'm not looking for cheap, just decent mid-range.
                also that is the same board on the same plasma TV with the same problem
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  Took the whole VRM FETS off. Huge pain in the ass. Some traces unglued a bit but they're still on
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Well if you change the DC rating to be from 315v in the search you find this one for example:
                    https://www.mouser.se/ProductDetail/...P3eDelTA%3D%3D
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      I have a video on fixing this supply blown pfc.
                      https://youtu.be/ESRx3UVlfCI
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        This one does turn on, you can hear the audio, it just takes about an hour for the screen to get brighten up. I already found several more bloated caps under one of the VRM heatsinks
                        • Uranium-235
                          Comrade Glimmer
                          • Aug 2007
                          • 5042
                          • US
                          LOL Lelon is going by the name Surge/Lelon. Maybe this is just bad branding?
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            https://cdn.badcaps-static.com/pdfs/...ba21ea4335.pdf
                            Oddly enough the GK does not have a 35v version on the datasheet, but this board does. Must be custom order
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              This is about as close as I can find:
                              https://www.digikey.com/en/products/...71MELB/2540761
                              https://www.digikey.com/en/products/...MELB40/2540156
                              ^ Both are 470 uF caps in 30 mm dia., but one is rated for 315V and the other for 400V. Height for both is 42 mm... which is the smallest you can get. Do you really absolutely must keep the height below 40 mm? With the case close on the plasma, is there really no more space / height inside? Otherwise, if you can go up to 47 or even 52 mm, that opens up even more choices, like these:
                              https://www.digikey.com/en/products/...MELB45/2540435
                              https://www.digikey.com/en/products/...MELB45/3929841
                              And yeah... I know you said mid-grade, since you probably want to keep the costs lower... but that's the unfortunate part about plasma TVs - they really do need quality caps if you don't want to do this repair again. And also, mid-grade caps aren't much cheaper - at least not on Digikey. I'll try to check eBay for you tomorrow. I know I have bookmarked a few sellers that actually had good quality caps for relatively cheap. Just don't remember if they had HV units.
                              BTW, maybe another (possibly cheaper) option would be to look for used Panasonic Viera / plasma TV boards online and just take the caps from that?
                              Either way, I too also always cringe when I see a PSU with big caps that need replacement. This is why I hate APFC on cheap ATX PSUs - never ends up being a cost-worthwhile repair if it needs new primary cap(s). For this reason, I always pick up broken Sony and Panasonic TVs on the side of the road - at least LCDs. If I had a truck, I'd pickup the rear projection units too. Those probably have decent caps too (again, at least Sony does, for sure.)
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                Height isn't a restriction here. But only the LGU and LGX have the equivalent ripple (1.7)
                                I did search 400v, not sure why those didn't come up on dgk
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  Can anyone find me any information on Samwha PL series. I can't seem to find literally anything
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Well, one of them is rated for 1.68A... I doubt that will break the bank here.
                                    Also, these are the 120 Hz low frequency ratings. I'd say look at the higher frequency - if it matches to within 0.3 Amps, it's probably good enough.
                                    I only get hits back from this thread and your database (for a different cap manufacturer.) :\
                                    I checked the list of caps I jotted down from an old Samsung plasma I found recently, and it also has Samwha PL caps here and there (4x 315V 440 uF). Also some PT series.
                                    I wouldn't look for datasheets for these - just go with whatever brand/series has the highest ripple current and with longest endurance/life. The PL on my Sammy are on two very hot boards at the end. Not sure what these are called (any plasma TV folks want to fill me up on this? ) In any case, since it's hot there, just go for the best specs possible.
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      Seems like a series used specifically for certain manufacturers.
                                      I just matched UF/V (sometimes slightly higher V) with a slight/middle up ripple and down ESR. Just matched the datasheet if it was 120hz or 100Khz. The TV still technically worked, hadn't blown. I figure with all caps panny/ruby/ucc/nichicon and 105c 2000+ hrs it should be fine for a few more years
                                      hardest thing was taking the series of fets off to get under one of the heatsinks
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        These caps will very likely outlast the screen.
                                        I find that even Japanese GP caps used in applications calling for mild-to-medium low ESR tend to last longer than "LOWESR" garbage from China/Taiwan/Korea.
                                        Only exception is APFC circuits in PSUs - those seem to kill just about everything... unless caps are grossly oversized.
                                        Oh BTW, when I found that Sammy plasma, I found something interesting on it that you might like. Just gotta see if I've pulled the pictures from that.
                                        • cook
                                          Good brands of run capacitor for house heat hump
                                          by cook
                                          Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
                                          Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
                                          09-13-2024, 12:53 PM
                                        • chth96
                                          Can I replace KME cap with Samxon GF cap?
                                          by chth96
                                          Hello.
                                          I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                                          Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                                          I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                                          04-17-2024, 07:11 AM
                                        • slybunda
                                          Gemcon capacitor replacements?
                                          by slybunda
                                          taken from my thread about car alarm siren here: https://www.badcaps.net/forum/troubl...rm-siren-issue
                                          there are 2 caps which im looking to get replacements for.
                                          Branded as Gemcon
                                          single 100uf 16v 6.5mm x 11.5mm
                                          single 100uf 50v 8mm x 11.5mm
                                          lead spacing is around 3mm
                                          there is space for 16mm tall caps
                                          rs components is good place for me to go since its close by, what replacements do you suggest and do these need to be low esr?
                                          the caps have...
                                          02-05-2024, 03:36 PM
                                        • burom
                                          Xbox 360 Xenon Modern Capacitor Replacements
                                          by burom
                                          I found my old Xbox 360 in storage and opened it up to see if there was anything that broke since it was built in 2006 (launch era Xenon revision, never red ringed, never been serviced) and didn't want to find out by releasing magic smoke. Upon moving the dust bunnies out of the way I was greeted by a bunch of capacitors with crud coming out of the top; it doesn't seem to have leaked onto the board so at least I have that going for me.
                                          I'm posting here because I want to try to source replacement caps myself from Mouser or Digikey instead of braving eBay or waiting for places to have...
                                          06-07-2024, 05:10 PM
                                        • прямо
                                          Help me decide which MOSFETs are suitable replacements
                                          by прямо
                                          Friends,
                                          I need help. I'm having a bit of difficulty in deciding what would be the compatible replacement for these MagnaChip N-Channel Trench MOSFETs on a VRM circuit because they seem to have a much faster switching times compared to most N-Channel Trench MOSFETs out there that have the same (more or less) current rating and Rds(on)
                                          MDD1502 (high side), 48.5A 7.8mOhm
                                          MDD1501 (low side, 2 in parallel), 67A 5.6mOhm
                                          VGS is 10V High side drain is 12V. Low side drain is from PWM controller (Richtek RT8120A) phase output 1V.
                                          Here are the ones...
                                          02-01-2024, 09:06 PM
