Charge capacitor to a small voltage
  • coolrox86
    • May 2010
    Is it possible to charge a capacitor to a small voltage of 3mV with just current 5mA in 3 seconds? The capacitor is 0.667F. I want to fully charge back the capacitor every time after it has used 3mV for sending signal via a small radio module.
    Any idea and help is well appreciated. Thanks!
    • 31170
    Re: Charge capacitor to a small voltage
    0.667f?
    • kikkoman
      • Jul 2007
      • 691
      wait - what?
      up to 3mV? you probably mean the voltage drops by 3mV.
      you know that if you connect a cap to a voltage source its resistance goes to infinity (in theory) as it approaches full charge?
      this means that all you have to do is hook it up to its desired charge voltage. the cap does the rest.
      that voltage drop is a pretty impractical way of measurement. plus, as I suspect that cap is a Goldcap (or similar), you might get inconsistent transmitting power since those caps only can deliver very low currents.
      they also are very unforgiving towards overvoltage.
      hook that transmitter up to a stable voltage source and measure the supply current as a reference (and check against the cap supply). it's much easier to work with if you know the values of your circuit.
      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
      • ruletero
        Acer a515-43 low battery charge voltage
        by ruletero
        Hi
        Acer A515-43
        LA-H801P
        Fail: Does not charge battery, has low voltaje on connector.
        Laptop didn't want to turn on, only charge led blinked.
        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
        10-24-2022, 02:31 PM
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • chth96
        by chth96
        03-09-2024, 10:03 PM
      • chth96
        desoldered capacitor is self charging until 0.6 voltage.
        by chth96
        I have an 21 inch CRT TV which is not able to power on.
        I disassembled 21 inch CRT TV and measured voltage of main filter capacitor(Samhwa HC 400WV 220uF) in the circuit.
        It shows 270V on my DMM.
        So I discharged this main filter capactior completely and detached circuit board from cathode-ray tube.
        Then I desoldered this main filter capacitor from circuit board.
        But I noticed that this desoldered large capacitor(Samhwa HC 400WV 220uF) is slowly charged by itself until it reached 0.6V
        I measured its ESR value with MESR-100 and it shows 0.1 ohm,judging...
        03-28-2024, 08:56 AM
      • crnimrki
        MacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime
        by crnimrki
        MacBook Pro 820-2327-A, have green light, charge, have normal voltage, no chime. On power on fan spins 5 seconds then stop and again spin and stay spinning.
        CPU Warm, DVD Drive not spinning, Mouse on USB Port inactive. No beeps without RAM DIMM-s.
        PPBUS_G3H - 12.55V without battery, 11.99 with battery charging
        PP3V42_G3H3.39V
        PPVCORE_S0_CPU - 0.98
        RAM VOLTAGE 1.49
        Where to search...
        01-02-2025, 12:51 PM
