Help finding alternative rectifier (SF3006PT)
  • curt2199
    • Oct 2013
    • 54
    I'm working on my treadmill motor control board and found a short on the motor side. The rectifier SF3006PT is shorted across 2 legs. I don't believe I got it back on the heat sink properly when replacing the bridge rectifier that had gone out which lead to it getting hot and blowing about 30 mins into a jog. I've looked around and most of what I'm seeing is at least a month out from China. I'm wondering if anyone has an ideas on a suitable alternative that I could find within a week or so stateside. Below is the Mouser data sheet.
    https://cdn.badcaps-static.com/pdfs/...ec9d8cb238.pdf
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Help finding alternative rectifier (SF3006PT)
    On Semi's MUR3040WTG looks very similar (60nS recovery time instead of 35nS), https://cdn.badcaps-static.com/pdfs/...7a104ec573.pdf
    PeteS in CA
      master hoarder
      • May 2008
      • 12175
      Originally posted by curt2199
      I’ve looked around and most of what I’m seeing is at least a month out from China.
      I would suggest you avoid buying semiconductors directly from sites that stock Chinese "non-verified" components - e.g. Amazon, eBay, AliExpress, and etc. The reason why is because there are way too many counterfeit parts. With semiconductors, it seems they always blow up or burn out at a fraction of the specs they are rated for, if dealing with counterfeit parts. Now, when it comes to eBay, there are genuine sellers and sell genuine parts (typically production over-stock), but you kind of have to know how to identify them. FWIW, Digikey and Mouser are usually the two safest approaches to buying genuine parts.
      • curt2199
        • Oct 2013
        • 54
        Thanks but Digikey and Mouser were out of stock. Ended up ordering on eBay from a German seller. 2 week wait time… we'll see.
        • R_J
          • Jun 2012
          • 9548
          You could have went with the SF3008PT which is just a 600v version of the 400v and is in stock at digikey.
          Digikey pt# SF3008PTC0G-ND 710 in stock
            master hoarder
            • May 2008
            • 12175
            ^Agreed.
            Anyways, I hope O/P keeps us posted how it goes. Hopefully he does get a genuine part at least.
