question capacitor ceramic smd
  • gamer87
    Banned
    • Sep 2021
    • 12
    • usa
    Do small portable electronic devices that use ceramic or tantalum SMD capacitors also need to be used constantly because they have the same problems as long-term stored electrolytic capacitors?
    • 31129
    Re: question capacitor ceramic smd
    no.
    and electrolytics take many years to depolarise anyway.
    • chth96
      by chth96
      03-09-2024, 10:03 PM
    • NuclearSpartan
      Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
      by NuclearSpartan
      I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
      The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
      I don't see any other visible damage anywhere else on the board....
      11-14-2024, 02:32 PM
    • rictechie
      smd ceramic capacitor use in iphones
      by rictechie
      is there a brand of smd ceramic capacitor use in iphones? or they are generics
      07-26-2024, 08:28 PM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • Sparklingx
      SMD ceramic capacitor capacitance & voltage
      by Sparklingx
      what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
      09-12-2024, 01:04 AM
