Cap Identification
  • Oh-my-tv
    • Aug 2018
    • 9
    Cap Identification
    I have some caps that I am having a hard time identifying. Can anyone assist me? Thank you for your expertise. it is a cylindrical cap about 8mm dia. with 3 lines of text top line is EP middle line is 47-16 then a line across and bottom line is V1
    • 20795
    Re: Cap Identification
    Can you post a picture of it
    • Oh-my-tv
      • Aug 2018
      • 9
      Here is a pic.
        • 20795
        Here is a pic.
        What does it have written on the side of the cap
        • Oh-my-tv
          • Aug 2018
          • 9
          Nothing, just manufacturers name. Can you take a guess as to what the board coating is? Manufactured in the 80s.
            • 31015
            probably 47uf and 16v
            looking at what its in i think it needs to be 105' temp rated.
            so maybe use rubycon YXF
            • Oh-my-tv
              • Aug 2018
              • 9
              Thank you very much, It is a cruise control unit. Appreciate the help
              • PeteS in CA
                • Aug 2005
                • 3579
                • USA, Unsure of Planet
                Those Wima 2.5 mm lead space caps definitely have a 1980s vibe. I'll guess the coating may be Humiseal, a coating used to seal out moisture.
                PeteS in CA
                • Oh-my-tv
                  • Aug 2018
                  • 9
                  Thank you PeteS. I appreciate the help
                  • Maniackk
                    Reader PocketBook InkPad 3 – identification of a black component marked 'CT' on the microUSB line
                    by Maniackk
                    Device: PocketBook InkPad 3
                    Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
                    I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
                    I would appreciate help identifying this component.
                    Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...
                    05-16-2025, 08:53 AM
                  • cubytus
                    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
                    by cubytus
                    Hi to all,
                    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
                    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
                    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
                    01-10-2024, 01:26 AM
                  • TrueSword88
                    Kogan - KALED65XU9220STB - Blue Vertical Line
                    by TrueSword88
                    Hi all.
                    I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                    The line just happens to coincide with the end of COF and start of the next COF (attached).
                    The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                    Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                    Hoping to fix...
                    05-05-2023, 04:28 PM
                  • FALKLAN
                    Running Line Voltage and Integrating LED Pods - Automotive
                    by FALKLAN
                    Howdy everyone! I hope all is well where ever you are!
                    I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                    I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                    02-05-2025, 12:30 AM
                  • mindoverflow
                    ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
                    by mindoverflow
                    hello,
                    there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
                    I changed pads and thermal paste.
                    I run mats test but it is reporting 0 errors.
                    I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
                    After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
                    02-09-2022, 03:22 PM
