D865GBF with oddball KZG
  • quiggs
    • Feb 2012
    • 6
    Re: D865GBF with oddball KZG
    yyonline - just to be clear, you say I need different replacements for the ones near the CPU vs the ones near the ram, even though the originals are all identical?
    • yyonline
      • Jul 2009
      • 692
      Originally posted by quiggs
      BTW, i also need to replace the 2200uF 10V (10mmx25mm) near the SATA jack.
      What brand/series of capacitor is that? My photographic memory is usually pretty good, but that one wasn't bad on my board, so I don't recall what it was. It's possible my board uses a different brand of capacitor there. If it's another KZG, you can use this:
      https://www.badcaps.net/store/produc...roducts_id=137
      • yyonline
        • Jul 2009
        • 692
        Yes. They're on different circuits, so the applications are different. Exact replacements aren't available, so we have to pick the "next best" thing. Given that the circuits are different, the next best things will be different for the two applications.
        Take CPU VRM. The original caps are rated for 6.3V. One of the proposed replacements is a 2.5V cap. P4 CPUs run at "about" 1.5V, and that's the voltage on that circuit. Therefore, it's safe to reduce the voltage rating in this case. The 2nd proposed replacement changes the capacitance. This is low risk, as having extra capacitance in the CPU VRM circuit isn't an issue.
        Now, let's take the ones near the ram. If my memory is correct, these were at DDR voltage, which is 2.5V. Therefore, the 2.5V rated capacitors that I suggested for the CPU VRM are inadequate for use here (barely adequate, but it's good to have a safety margin). Therefore, we can't reduce the voltage. It's not a VRM circuit, so I don't think changing the capacitance is a good idea here. Keeping the capacitance the same, the only things that meet the specs of the original capacitor (exceed in this case) are polymer capacitors. Polymer capacitors are smaller, but have superior specs and are constructed out of different materials.
        I hope this makes sense - I'm pretty tired so my explaining skills might not be what they usually are :-)
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          You want the total uF in Vcore to be ~5500uF or more.
          [That's based on what is found on production all-poly boards.]
          Only cheap POS boards like AsRock [or boards for very low power CPU's] use less.
          All poly server boards tend to have 6000-7500uF in Vcore - for each CPU.
          10x 680uF Poly would do fantastic.
          Just make sure their [individual] ESR is less than the original KZGs and ESR will be fine..
          The total uF is to keep voltage in spec during transients like CPU from 10% to 100%.
          If you don't have enough and you go to a heavy load suddenly you can cause BSOD or reboot.
          Mann-Made Global Warming.
          - Dr Seuss
          • quiggs
            • Feb 2012
            • 6
            Sorry guys -- I missed your responses last night because I didn't notice that this thread had grown a second page! (You know, the internet continues to astound me: total strangers from across the country are helping me with an obscure problem in the middle of the night. I really appreciate it.)
            1) The 2200uF 10V is a Nichicon HM(M) which is silver & black (vs. the copper & black HN(M)'s near the CPU).
            2) Other than cost difference (which is trivial in light of the amount of work I'm about to do), is there any reason not to use polymers everywhere I can (even if an exact replacement lytic is available)? And was there originally some technical (not financial) reason that Intel mixed 3 lytics in with 7 polys in the VRM?
            • yyonline
              • Jul 2009
              • 692
              HM and KZG have identical specifications, so the suggested replacement will work fine.
              Cost, most likely. A few cents savings over millions of boards adds up to a lot. I've never had any issues changing the CPU VRM capacitors to polymer.
              Elsewhere you have to be a bit careful differing too much from the original specifications. It might work, it might not. Changing this around too much gets into experimentation territory. Furthermore, polymer capacitors tend not to be available in capacitance above 1500uF. There are a few, but not many series that go higher.
              • quiggs
                • Feb 2012
                • 6
                #27
                OK, then, I think I'm good to go. Thanks again for all your help!
                • dpdemay
                  • Feb 2013
                  • 3
                  • United States of America
                  #28
                  Got 2 of these D865GBF boards that I'm going to attempt to revive ~ found some Rubycon MBZ 820uf capacitors on eBay. One of the boards has 5 bulging Nichicon HN(M), the other has 3 bulging 820uf KZG, the two near the RAM haven't swollen, but I might as well swap those out as well. Anything wrong with using the Rubicon caps in all 5 locations, or should the ones near the RAM be the ones from Digikey mentioned above?
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Ruby MBZ should be fine for all of those locations, but I wouldn't encourage using fleabay for them, as most on there are fakes. Just get yourself some newer Hichicon HNs from here (https://www.badcaps.net/store/produc...roducts_id=163).
                    • dpdemay
                      • Feb 2013
                      • 3
                      #30
                      With any luck, the Rubycons that are scheduled to arrive on Monday won't be bogus. The eBay seller has 11K+ Positive Feedbacks, and sells scads of capacitors, so I'll give 'em a shot. The D865GBFs are obviously old boards at this point, so if my attempts at repairing them fail, it's no big deal. They came out of a pair of machines I built for a friend back when the D865GBF & D865GLC boards were relatively new. I've since upgraded just about everyone else's machine that I built with those boards back then, and I'll likely be replacing this pair soon, even if the Rubycons fix works. They've been doing a fair job of running Windows 7, but it's really time to retire 'em...
                      • chth96
                        Is it no harm to replace with capacitor without ripple current rating?
                        by chth96
                        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                        Rubycon YK DataSheet (b...
                        04-19-2024, 05:19 AM
                      • SwedishDiesel
                        Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                        by SwedishDiesel
                        Howdy folks,
                        I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                        10-30-2021, 12:47 AM
                      • Antonynl
                        What are typical ripple voltages on a laptop motherboard?
                        by Antonynl
                        I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
                        So I have two questions:
                        1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
                        2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
                        Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
                        12-09-2022, 06:51 AM
                      • JohnsonJ
                        Allen&Heath XONE92 DJ mixer repair
                        by JohnsonJ
                        Hello everyone.
                        I'm having issues with my DJ mixer, and after taking it apart and checking everything out, it seems that I need to replace 2 rotary potentiometers for the filter, and that the PSU has some caps burned. Hopefully these 2 fixes will solve my issues.
                        The potentiometers I will just replace (hopefully the repairman I spoke with will indeed send me the spares, in case he doesn't, I'll update here if we can find a suitable replacement), but for the PSU caps I'd kindly ask you forum members, if anyone could help guide me in the right direction. I'm having difficulty...
                        12-12-2020, 11:19 AM
                      • Junkrepair
                        Calculating ESR from tan delta -- tan delta's dependence on capacitance
                        by Junkrepair
                        I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                        I found this nice little description of the conversion:
                        Calculating capacitor ESR from Tan(delta)
                        https://forum.digikey.com/t/calculat...-from-tan/2633
                        It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                        06-12-2023, 02:45 PM
