unknown Elna caps
  • Scenic
    o.O
    • Sep 2007
    • 2642
    unknown Elna caps
    no idea what forum section to put this in..
    got those from a friend asking me if they were any good and if i'd have a use for them.
    he bought them on ebay to fix his LCD, but he messed up with the can size.. they won't fit
    been searching on the net quite a while... no infos at all.. not even on the elna website?! o.O
    125°C, flat top, 470uF 35V
    0730 seems to be the datecode (week 30 year 2007)
    they seem to be high-temp polys.. (?!)
    no usual series marking from what i can tell.
    that guy i got those from said he bought 100pcs of those for 6.20eur (about 8.36US$) including shipping.
    if they really are solid polys, i'd probably buy some of those.. seems to be a damn good deal..
    plus they're elnas.. so i guess they should be pretty reliable..
    unfortunately, i don't own an ESR meter.. so i cant tell if they are low ESR or high-temp GP caps
    if there's someone near me (preferably in europe.. bc. of the shipping costs) i could send a few of those over for closer examination... ESR and stuff..
    any ideas?
    • 31278
    Re: unknown Elna caps
    are they used?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      oddballs!
      maybe counterfiet?
      how about pics of the bung.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        they were prepared to be used (shorted legs, negative one being bent to an "U" at the end .. see left one on the pic)
        but ended up never getting used according to the auction.
        definitely not a cheapo bung IMO
        strange stuff..
        edit: pretty thick and strong leads too.. had a hard time bending the negative one back straight on the right cap..
        • Scenic
          o.O
          • Sep 2007
          • 2642
          • Scenic
            o.O
            • Sep 2007
            • 2642
            a little bumpage
            anyone willing to test those if i send a couple of them over?
            tried contacting elna via email.. no response yet..
            • sofTest
              • Aug 2008
              • 361
              If you don't get any volunteers closer to you, I can see what my EVB and ESR-micro 4 meters can make of them.
              Be a mensch
              • Scenic
                o.O
                • Sep 2007
                • 2642
                i just bought a 100pcs. bag of those a couple days ago. arrived today. enough test samples i'd say
                not all of them have the legs shortened like in the pics above. some of them look like they were just ripped out of the paper stripe..
                datecodes range from 0714 to 0728 from what i can tell..
                i think i'm gonna look up the shipping for a couple of those and probably some of the one's mentioned in this thread..
                one of the Elna's has relatively deep dents in the can.. probably from shipping them in a bag >.<
                i think i'm gonna cut that one open to see if it's a wet lytic or not..
                • linuxguru
                  • Apr 2005
                  • 1564
                  35V is a bit high for the voltage rating for a polymer, most of which max out at 16V. The combination of 35V and 125c temperature suggests a conventional automotive-grade electrolytic, if it's genuine...
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    The (Q) suggests it isn't +/-20% tolerance [which would be the usual (M)]
                    ... but I can't find a (Q) in the cap codes.
                    The S in the circle might mean special order.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      ELNA has the Q in their own docs.
                      https://cdn.badcaps-static.com/pdfs/...2962bba97e.pdf
                      It's -10%/+30%
                      - Dr Seuss
                      • POM_MJ
                        • Aug 2009
                        • 228
                        I thought those caps are not low ESR type.
                        in my opinion, ELNA's low ESR caps would be use solid stripe printed on sleeve.
                        | AMD Phenom II X2 550BE | GIGABYTE GA-MA790FXT-UD5P | GeIL DDR3 Ultra 2x2GB 1600C7 |
                        | XFX GTS250 DDR3 512MB | Dell H525EF-00 | Lancool PC-K62 Black | Samsung 2232GW |
                        | 2xWD7500AYYS | 2xHD322GJ Raid0 |
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Might be right.
                          Good eye! - I never noticed that before.
                          - Dr Seuss
                            by momaka
                            03-12-2025, 03:42 PM
                          • eryjus
                            by eryjus
                            05-10-2023, 11:21 AM
                          • Paxman_Swede
                            by Paxman_Swede
                            Hello!
                            01-14-2025, 09:51 AM
                          • captain150
                            by captain150
                            03-16-2025, 07:34 PM
                          • Foetuss
                            Gigabyte GA-6OXT :: caps question
                            by Foetuss
                            Good evening
                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                            But I was also suprised about the bigger boys, which are 330µF 25V.
                            Could it be they used 25V caps because they were cheaper / available at that time?...
                            02-11-2025, 12:22 PM
