Soltek
  • GameMusic
    • Sep 2005
    Soltek
    Within 10 minutes of startup my computer restarts when the hard drive boots. After that it just restarts most of the time. Windows XP restarts on startup. DOS programs run perfectly. Windows 98 sometimes restarts on startup, and otherwise Windows and Windows programs constantly show illegal operations, blue screens, Mozilla Quality Wizards, restarts, etc. Downloads, especially compressed, are corrupted and scandisk errors run all over the place. Interestingly, turning off the L1 & L2 cache in CMOS blocks all errors except restarting on boot.
    So is this bad caps?
    Why does turning off the L1 & L2 cache fix it?
    Why does it run differently within 10 minutes of startup?
    Why do DOS programs run?
    Model : Soltek VIA Technologies Inc VT8753 Apollo P4X266
    Board Temperature : 39.0°C / 102.2°F
    Power / Aux Temperature : 34.0°C / 93.2°F td
    CPU Voltage : 1.50V
    Aux Voltage : 2.53V
    +3.3V Voltage : 3.28V
    +5V Voltage : 5.11V
    +12V Voltage : 11.48V
    -12V Voltage : -11.87V
    -5V Voltage : 3.59V another badcaps clue?
    Standby Voltage : 4.97V
    Battery Voltage : 3.42V
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Soltek
    CPU Voltage : 1.50V
    Aux Voltage : 2.53V
    +5V Voltage : 5.11V
    -5V Voltage : 3.59V<-----
    Dead ringer of bad caps or a bad power supply.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • bushytails
      Moderator
      • Dec 2004
      • 217
      Re: Soltek
      Actually, I've noticed a LOT of supplies don't seem to provide one or both negative voltages, or they float at totally random things.
      ...and haven't noticed anything miss them. heh. systems seem to still work perfectly.
      --Randy
      • Rainbow
        • Aug 2005
        • 1374
        Re: Soltek
        Bad memory can cause problems like these.
        The voltages shown by various programs for Windows can be wrong because boards have the hardware monitoring chip wired in various ways.
        Some newer PSUs don't have -5V voltage at all. New boards don't have ISA slots (most of them) and -5V is not present in PCI slots.
        • bushytails
          Moderator
          • Dec 2004
          • 217
          Re: Soltek
          That would explain why I've noticed most supplies don't have -5v.
          --Randy
          • MD Willington
            • Sep 2004
            • 702
            Re: Soltek
            What model board?
            Ya'll think us folk from the country's real funny-like, dontcha?
            The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
            • Lance Thornton
              • Jan 2005
              • 84
              Re: Soltek
              It would be nice to have a clear picture or two of your Soltek board for the diagnosis. Please post a few if you can.
              • Fernon@Repair
                Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                by Fernon@Repair
                i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                VCCIO voltage ok
                VCCSA Voltage OK
                VCCPLL Voltage OK
                Ram Voltage ok
                RamVTT OK
                VPP 2.5 OK
                But No Core Voltage
                and i want to this vrm ic datasheet or pinout (ISL69269)
                anyone have this ic pinout voltages?...
                06-25-2025, 07:19 AM
              • electron_jj
                Panasonic TH-L42D25A checking the PSU output voltage
                by electron_jj
                Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                08-29-2021, 08:13 AM
                Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                by sam_sam_sam
                I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                Now...
                06-09-2024, 10:57 AM
                ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                Based on Intersil's Robust Ripple Regulator...
                11-05-2024, 03:24 PM
