Replacement 'green cap' 392J 1200V
  • tiff_lee
    • Feb 2016
    • 17
    I had a logitech Z506 psu go bad due some glue corroding the legs of several components and the one i'm struggling to find a replacement for is a green polyester capacitor markings 392J 1200V.
    The problem is I can't find any 3.9nF caps with a voltage rating of 1200V from any reputable retailers (plenty of 100V) , this particular cap only seems to be available from Chinese sellers which leads me to believe the rating is garbage or the cap is.
    There is a thread on this particular PSU here
    https://www.badcaps.net/forum/showthread.php?t=32783
    but no mention regarding a replacement 'greencap'.
    Any help is appreciated.
    cheers, Lee
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Replacement 'green cap' 392J 1200V
    photo would be nice, of the original and where in the circuit it belongs.
    1200V is unusual, are they using that instead of a proper Y-cap?
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Sounds like a PFC output cap, a film cap that parallels the big lytic, or maybe a primary side snubber cap.
      Maybe look into Panasonic ECWH series parts, page 80 of this catalog, https://cdn.badcaps-static.com/pdfs/...c9731e0d95.pdf .
      PeteS in CA
      • tiff_lee
        • Feb 2016
        • 17
        Ok some pictures attached.
        yeah according to that linked thread it is part of the snubber circuit .
        Thanks for the catalogue link, so ECW-H8393RJV is the same capacitance, lead spacing (7.5mm) but only rated to 800VDC. Honestly I don't know how critical that is and whether the greencap rating is even genuine. The Panasonic caps rated to 1.25kV have a 20mm lead spacing.
        • PeteS in CA
          • Aug 2005
          • 3581
          Another possibility, https://bz.airlibro.jp/book/view_html5.php?id=466&p=19
          Rubycon MPE Series
          PeteS in CA
          • redwire
            • 3910
            ... ECW-H8393RJV is the same capacitance, lead spacing (7.5mm) but only rated to 800VDC....
            No, that is 39nF not 3.9nF or 3,900pF which is why it is so big. But ECW-H8392 is obsolete and big too.
            The voltage rating is a bit ridiculous, as if the power MOSFET is rated for that, and the pcb footprint so small. Sometimes a disk cap will be usable.
            • R_J
              • 9558
              The cap was likely ok, but he cut the leads off so now it is nfg. You can get .0039µf 1200v mylar or polyester caps from many suppliers.
              • tiff_lee
                • Feb 2016
                • 17
                Rubycon MPE Series
                I'll take a look thanks
                Yeah my bad it was pretty late
                You always so passive aggressive? no 'he' didn't cut the leads off why would I of done that when I had all the tools in front of me to remove it. The leads had been completely corroded by the glue and pretty much disintegrated.
                I don't have an actual picture of mine but it looked similar to this but only much worse as the entire cap base was covered in the glue which had changed state into the corrosive brown stuff.
                Would you care to share which suppliers you are referring to? like I said all I could find of that capacitance, with that lead spacing and voltage rating were dodgy chinese suppliers.
                  • 31090
                  what does it do?
                  is it in series with the big resistor?
                  if it is, are the pair across a diode or mosfet?
                  • redwire
                    • 3910
                    It is the primary RCD snubber network on the Logitech Z506 power supply.
                    D5 FR207 1kV 2A 500nsec
                    C3 3,900pF 1200V LS=7.5mm
                    R2 10R 1W
                    R1 51k 3W
                    TOP258MN datasheet they use a 3.9nF 1,000V cap plus a 200V TVS though fig39. The IC max. is 675V. It's just a cheap Logitech design and then even cheaper parts went in.
                    Nothing is rated 1,200V in that small 7.5mm leads, and it runs next to hot resistors, is covered in conductive glue. I would stuff in a quality film cap 1kV or ceramic disk cap 2kV there.
                      • 31090
                      i was just thinking 2kv ceramic
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        Same here.
                        2 kV Ceramic should be fine... unless the design is so bad that this somehow causes oscillations on the primary (I've seen it happen on cheap 2-transistor flyback designs on the 5VSB of an ATX PSU... but those are a more special case, I think.)
                        If not, I think the rating could also be dropped to 630V on the film cap. As others said, nothing in the circuit is rated for that high of a voltage, so it probably isn't needed... unless the ripple current on that snubber circuit is so high that it causes lower-voltage (smaller case size) film caps to overheat.
                        In any case, I suggest going with a 630V quality polypropylene cap in there, and that should be fine. Polyester might work too, but PP has better high-frequency stability. If not, go with a 2kV ceramic.
                        • R_J
                          • 9558
                          You post someone else's picture then get pissed off at me for stating the obvious.
                          • tiff_lee
                            • Feb 2016
                            • 17
                            R2 10R 1W
                            R1 51k 3W
                            Thanks for jumping in and the link.
                            Thanks to the others for the recommendations.
                            Are you ok mate? not sure what your problem is but I posted my own pictures (the glue one was for reference as I had already cleaned my board off), you took a shitty attitude before I posted the glue picture up. Thanks for contributing zero to the thread apart from the chip on your shoulder, I guess you must be the resident troll.
