Toolkit
  • Berne
    • 13
    Toolkit
    Hi All,
    First post, This is for home use only Id like to price a basic motherboard tooling kit for checking the functionality of mainboard components only, if not too expensive. List all the tools required please apart from 30W soldering iron.
    Also what grade of solders should be used for various jobs that a motherboard might require.
    Just browsing the issue at the minute.
    All good advice welcome.
    Berne
    • 31015
    Re: Toolkit
    autoranging digital meter for voltage, resistance etc.
    get one with a diode-test on it - probably 10-15€
    esr meter - see other threads.
    solder - .5 or .7mm on a 250gram roll - dont fuck around with small packs.
    i recommend lead free, silver loaded.
    probably something like 96% tin, 3% silver, 1% copper.
    something like 15€ a roll.
    if you change your profile so we know where you are, i could be more helpfull.
    • kaniki
      • 514
      Re: Toolkit
      Dont forget some solder braid/wick (same thing, 2 different names) or a solder sucker for removing the old solder.
      The reason that it is important is solder can become less pliable or flexible the more that it is reheated, which can make it harder top work with too, so best to use new solder on a joint. there have been discussions about this too.
      and a little flux (dont need a huge container as this goes a long way)
      i would say that the use that you are going to use it for is going to depend on the size of container that you buy. If you are planning on only doing a couple of small jobs, then a small container is fine, but if you plan on doing a lot of soldering later, then get the bigger roll. You do not need a lot of something small like replacing a couple capacitors, but if will start adding up quick if you start doing dozens of them. take into consideration your abilities and if you will use a lot before you buy the roll. and just remember, solder does not go bad, but at the same time if you only replace 5 caps then buying a big roll is a waste.
      • Krankshaft
        • Jan 2007
        • 2328
        Re: Toolkit
        Get name brand solder like Kester the flux is EVERYTHING when it comes to solder.
        Cheaper no names will use cheaper flux which leads to substandard joints.
        Get a solder with Rosin based flux the no clean stuff makes horrible joints.
        I'd stay away from the lead free stuff unless you have a temperature regulated iron that can handle it the soldering temps are HIGHER for lead free and it doesn't flow as easily.
        Unless you're in EU jurisdiction with that ROHS crap use leaded.
        • Berne
          • 13
          Re: Toolkit
          Hi ,
          Got a solder sucker. I have ample solder 0.7 Sn99 Cu 0.7 with A11flux, EU spec.
          Lastly I think it would be wise to get a capacitance meter, this one has a cap range of 500nf to 3000uf (Meterman PMFX P51), when cap is removed by applying + and - terms I will be able to read if capacitor is gone or not right? This cap range will be ample Im sure. What is the average range of Caps used in Motherboards? I dont think one can measure the validity of a cap while its in the board cheaply ....only tool here is an expensive scope am I right?
          Will source braid, ESR meter will read threads, then update.
          Thanks,
          Berne
            • 31015
            Re: Toolkit
            you can get a good combined cap & esr meter for cheap from the russian guy - do a search.
            btw, A11 is active flux, so make sure you clean it off after with IPA.
            • Berne
              • 13
              Re: Toolkit
              Hi STJ,
              Can you be more specific on how I can contact therussian, I searched but only got a few threads but no mention of The Russian? Also what is IPA?
              Berne
                • 31015
                Re: Toolkit
                IPA = IsoPropyl Alcahol
                russian guy:
                http://www.radiodevices.ru/esr/esr4.htm
                • Radio Fox
                  • Jan 2010
                  • 281
                  Re: Toolkit
                  Originally posted by Berne
                  Hi STJ,
                  Can you be more specific on how I can contact therussian, I searched but only got a few threads but no mention of The Russian?...
                  RusMike is a member of these forums. You can email or PM him from his profile:-
                  https://www.badcaps.net/forum/member.php?userid=12802
                  ________________________________________________
                  Invisible airwaves crackle with life
                  Bright antennae bristle with the energy
                  • Berne
                    • 13
                    Re: Toolkit
                    Ok , thank you. Lastly are there any other basic tools I should consider for other parts of the board within reason for home use only?
                    Regards,
                    Berne
                    • corrize
                      Best way to solder LVDS connector for beginner (and qfn) ?
                      by corrize
                      Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                      I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                      I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                      See the test :
                      https://youtu.be/bNAzC-EvqHs?t=1767
                      With hot air from bellow the board, that's...
                      03-09-2023, 02:57 AM
                    • myth77
                      UV solder mask - high temp resistent, recomendation?
                      by myth77
                      Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                      Is there any solder mask...
                      03-28-2022, 04:04 AM
                    • petemanuk
                      BGA solder balls not connecting - help pls
                      by petemanuk
                      So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                      I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                      I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                      11-16-2022, 05:21 AM
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • sircastor
                      Solder not reflowing - what am I doing wrong?
                      by sircastor
                      I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                      For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                      03-03-2024, 02:44 AM
