Electronic Keyboard with exploded capacitor
  • feetee12
    • Dec 2020
    • United Kingdom
    Can someone please help me with a query?
    I am trying to fix an electronic keyboard (Pitchmaster DU090463) which has a blown capacitor.
    I have armed myself with a new box of various sizes of capacitors and a soldering iron kit. BUT, the capacitor which has blown is unidentifiable due to it blowing to smithereens.
    I guessed which size it might be based on the size of the base (all that was left of it) and the other sizes of capacitors on the pcb, I guessed 220uf, but every time I replace it...boom!
    How do I figure this out??
    Thanks in advance.
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    • Bulgaria
    Re: Electronic Keyboard with exploded capacitor
    You either use capacitor with much lower voltage rating, you reverse the polarity when you are soldering it of there is other problem with the board. If it blows, stop putting new capacitors. Check the voltages on the board with multimeter and for any shorts.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    • R_J
      • 9624
      Post some in focus, high quality pictures so we can see what we are dealing with.
      • brethin
        • Dec 2008
        • 1907
        Throw it away and give up. If you blew it more than once you didn't learn anything from the first blowup so you won't learn anything now.
        • petehall347
          • Jan 2015
          • 4450
          • United Kingdom
          so from when was blowing up stuff not so cool ?
          • petehall347
            • Jan 2015
            • 4450
            • United Kingdom
            we need information starting with pictures . and service manuals or just the schematics is good
              Originally posted by r_j
              post some in focus, high quality pictures so we can see what we are dealing with.
              +10
              • petehall347
                • Jan 2015
                • 4450
                • United Kingdom
                might be using wrong supply brick .
                • MORETTIGIAN
                  Capacitor detached from PCB – RTX 2070 Super Founders Edition
                  by MORETTIGIAN
                  Title:
                  Description:
                  During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                  I did not notice it detaching, so I am unsure of its original location on the PCB.
                  Procedure performed:
                  - Removed backplate
                  - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                  - Reapplied thermal compound
                  - Reassembled card
                  Observed behavior after reassembly:
                  - GPU powers on and operates normally under...
                  09-18-2025, 12:14 PM
                • tranquility
                  newbie needs capacitor sizes. HP Spectre X360. schematic maybe available
                  by tranquility
                  hello, i am very new to laptop repair and generell electronics
                  i have a HP Spectre X360 Convertible 13 - ap0016ng
                  motherboard number DA0X36MBAE0 REV E
                  massive burned and shortet mosfets. after removing them still shortet in the i think "main power rail"
                  found a shorted capacitor. removed it and the short is gone.
                  i want to try a crazy repair which is hard because the mosfets are like welded on one side to the track. is there a method to get this loose ?
                  in this area another capacitor was shortet.
                  12-06-2024, 04:12 AM
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
                • Agent24
                  Dick Smith Q-1760 linear power supply filter capacitor question
                  by Agent24
                  I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                  It has at least one problem.
                  The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                  I have already ordered a replacement potentiometer, so that's not an issue.
                  Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                  All are CapXon...
                  10-21-2025, 05:39 PM
                • chth96
                  If I replace with inferior capacitor, Is it No harm to other IC components at all?
                  by chth96
                  I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                  Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                  It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                  So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                  I know that these capacitor will not last as long as nichicon capacitor...
                  12-22-2023, 04:34 AM
