Electronic Keyboard with exploded capacitor
  • feetee12
    • Dec 2020
    Can someone please help me with a query?
    I am trying to fix an electronic keyboard (Pitchmaster DU090463) which has a blown capacitor.
    I have armed myself with a new box of various sizes of capacitors and a soldering iron kit. BUT, the capacitor which has blown is unidentifiable due to it blowing to smithereens.
    I guessed which size it might be based on the size of the base (all that was left of it) and the other sizes of capacitors on the pcb, I guessed 220uf, but every time I replace it...boom!
    How do I figure this out??
    Thanks in advance.
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    Re: Electronic Keyboard with exploded capacitor
    You either use capacitor with much lower voltage rating, you reverse the polarity when you are soldering it of there is other problem with the board. If it blows, stop putting new capacitors. Check the voltages on the board with multimeter and for any shorts.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    • R_J
      • Jun 2012
      • 9583
      Post some in focus, high quality pictures so we can see what we are dealing with.
      • brethin
        • Dec 2008
        • 1907
        Throw it away and give up. If you blew it more than once you didn't learn anything from the first blowup so you won't learn anything now.
        • petehall347
          • Jan 2015
          • 4435
          so from when was blowing up stuff not so cool ?
          • petehall347
            • Jan 2015
            • 4435
            we need information starting with pictures . and service manuals or just the schematics is good
              Originally posted by r_j
              post some in focus, high quality pictures so we can see what we are dealing with.
              +10
              • petehall347
                • Jan 2015
                • 4435
                might be using wrong supply brick .
                • MORETTIGIAN
                  by MORETTIGIAN
                  Title:
                  Description:
                  Procedure performed:
                  - Removed backplate
                  - Reapplied thermal compound
                  - Reassembled card
                  09-18-2025, 12:14 PM
                • tranquility
                  newbie needs capacitor sizes. HP Spectre X360. schematic maybe available
                  by tranquility
                  hello, i am very new to laptop repair and generell electronics
                  i have a HP Spectre X360 Convertible 13 - ap0016ng
                  motherboard number DA0X36MBAE0 REV E
                  massive burned and shortet mosfets. after removing them still shortet in the i think "main power rail"
                  found a shorted capacitor. removed it and the short is gone.
                  i want to try a crazy repair which is hard because the mosfets are like welded on one side to the track. is there a method to get this loose ?
                  in this area another capacitor was shortet.
                  12-06-2024, 04:12 AM
                • Prolog
                  by Prolog
                  12-01-2024, 08:27 PM
                • chth96
                  by chth96
                  12-22-2023, 04:34 AM
                • chth96
                  by chth96
                  06-02-2024, 07:31 PM
