Types of electrolytic caps
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    can you explain me what type of caps is the one shown in the attached picture. Is is different from so called classical one. I have taken a photo of these caps next to each other. The data written on the cap is 22 uF, 50V, PH, 116, H1 KO H1.
    On many motherboards there are different types of electrolytic caps. These look more robust (probably aluminium capacitor).
    Do they have some special purpose?
    I have one 22 uF, 50V so called robust cap and other "classical", the same capacity and 63V, but smaller dimensions.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Types of electrolytic caps
    At first I thought your cap was very similar to this one I posted about here:
    https://www.badcaps.net/forum/showthread.php?p=257252
    I may be wrong though, and if so it is probably a solid polymer aluminium capacitor.
    Basically they do not have any wet electrolyte and hence have much higher rated ripple current and a much longer life.
    This thread has a bit explanation about it, but I am sure others can point you to better resources here on Badcaps.
    https://www.badcaps.net/forum/showthread.php?t=65732
    • Askic
      • Sep 2018
      • 187
      • BIH
      Thank you Per, based on your suggested keywords, I was able to find a very good explanation:
      https://www.gigabyte.com/microsite/1...hyusesolid.htm
      This motherboard manufacturer has so called "ultra durable" motherboards with this type of caps.
      My dilemma is whether to replace solid aluminium cap with a classical one. I have an electronics card about 20 years old (PLC input card) which works most of the time but suddenly stop behaving as expected. After Power OFF/ON it works for another period of time. I was thinking to try to preventively replace the caps.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        In that case I think my first link above might be correct.
        I.e. that a Rubycon ZL or similar would be a good replacement.
        • Askic
          • Sep 2018
          • 187
          • BIH
          Thank you very much Per. I know this is not related to the discussed subject, but can you tell me what exactly is the PSU's "startup cap", you put it yourself under quote marks in the following link: https://www.badcaps.net/forum/showthread.php?p=257252
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            It is a small capacitor that is usually on the primary side of the power supply.
            It controls the startup of the power supply, and if this capacitor goes bad the PSU will appear completely dead.
            Not all power supplies have a startup capacitor, it is a kind of old design practice.
            Usually you can identify it it is the problem by heating the power supply up:
            If it starts after that it is likely to be a bad startup capacitor, see here for an example of that:
            https://www.badcaps.net/forum/showth...875#post114875
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              In a 384x design it would be something like C2 in this schematic:
              When AC is first turned on, C2 is charged through R2 until the voltage is high enough for IC1 to turn on. Once turned on, IC1 receives its Vcc through D2 and D1. However, if C2 is high ESR, the energy drawn by IC1 lowers the voltage at Vcc and the under-voltage protection in IC1 shuts down IC1.
              In that circuit both C2 and C4 are stressed and need to be high quality parts such as Nichicon PW series or UCC/NCC LXZ series.
              PeteS in CA
              • Askic
                • Sep 2018
                • 187
                • BIH
                Excellent explanation Petes, thank you and also Per for your time and effort.
                  by momaka
                  03-12-2025, 03:42 PM
                • tony359
                  Best tool to place electrolytic SMD caps on a board
                  by tony359
                  HI all,
                  I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                  When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                  The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                  01-28-2024, 06:23 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
