Motherboard Design Assumption
  • bigbeark
    • Jan 2010
    • 661
    I assume that Motherboard designers locate the capacitors on motherboards close to where the particular power is required.
    So I would expect to see caps close to the Ram slots, around the CPU socket etc.
    I note that on some boards there are very few, or low powered caps near the PCI slots.
    Older boards seem to have more caps in the immediate vicinity of the PCI slots. I would assume that server boards would have more caps around the PCI slots than a desktop as more devices are likely to be installed in those slots than in a home PC with say onboard video, sound and Lan.
    The problems I have been having with my Soyo boards not loading the OS
    could be becasue I'm using a SCSI card and Drive, and perhaps the PCI slots
    which appear to use very few and notably low-powered caps on these boards just don't put enough power there to run SCSI.
    I can load the OS if I use IDE Drives, and I know my SCSI card/drive are good.
    So perhaps modern boards were never intended to have a high PCI load, and hence, are unable to provide enough juice so that my card can see the SCSI drives.
    Does this make any sense? I noted that my SOYO KT333 has no provision at all for other boot devices, for that matter, it has no boot menu within the regular bios setting and that twigged me to this thought.
    Comments please.
  • i4004
    • Oct 2006
    • 2029
    Re: Motherboard Design Assumption
    hard drives have their own power cables, you know.
    traffic on the pci bus is mainly low-power data traffic...yes, it powers the pci-boards that are located there, but that doesn't mean you need much power there...
    also soyo kt333 is from 2002...that's not new at all.
    not loading the os via pci controller card and drive attached to it is nothing weird...
    it has to do with the way mobo's bios is setup, wether it looks for other boot devices on pci bus, or not....
    • hardwareguy
      • Jun 2006
      • 405
      The lower number of caps is due to the lower ESR of new caps and the lower ripple output of ATX power supplies.
      With that said...the caps on the motherboard have to be *good*, and Soyo was notorious for using poor capacitors.
      i4004 is right...its a BIOS setting. Set the boot device in the BIOS to "bootable add in card" or "SCSI"
      • kaniki
        • 514
        agreed with what was said above, but are you 100% sure that it will support booting from a scsi card.. that may be the problem.. also, maybe hook the setup up to another PC to make sure that the card has not gone bad..
        • bigbeark
          • Jan 2010
          • 661
          My bad - I was using a cable without active termination.
          Lots of machines seem to work fine without a terminator, but I guess if there is any marginal component at all (or maybe no nearby caps), the card doesn't see the drive.
          Soon as I switched to a terminated card, bootup proceeded normally.
          • glovecaps
            by glovecaps
            11-25-2024, 04:23 PM
          • Docus
            Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
            by Docus
            Hi everyone 😀,
            I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
            To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
            Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
            1. I already own the exact same model, but its plastic chassis is badly damaged.
            06-10-2025, 04:24 PM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
          • dragon3x
            by dragon3x
            power on.
            Here are some examples :
            switching supply area).
            than 6.3 V.)
            03-21-2025, 02:46 PM
            ASUS P5GC-MX motherboard recap
            by momaka
            Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
            This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
            So here is what the motherboard looked like with its original caps:
            CPU VRM area up close…...
            01-27-2021, 11:59 PM
