high esr on new rubycon caps
  • moss99
    • Oct 2013
    • 50
    Hi , i just bought some 47uf 50v caps from farnell , the esr of the cap i took out was around 0.8 the new ones measure 1.8 which seems too high , are these a bad batch do you think ?
  • PeteS in CA
    • Aug 2005
    • 3586
    • USA, Unsure of Planet
    Re: high esr on new rubycon caps
    You'd have to look at the spec for the part. Did you buy the same mfr and series or an equivalent part?
    PeteS in CA
    • bestsystem
      • May 2011
      • 59
      what series is it?
      • moss99
        • Oct 2013
        • 50
        The caps i removed were JEC cd110 these are what i used to replace them :
        https://uk.farnell.com/rubycon/50yxm...50v/dp/1281851
          • 31300
          those are not low-impedence caps
          • moss99
            • Oct 2013
            • 50
            So as a general rule when replacing caps , i would need to see if the caps removed were low esr or not , ?
            i just thought i needed to check capacitance value and voltage , .
              • 31300
              depending on the use, different things may be required.
              a high frequency circuit needs low esr, and low frequency or dc psu's for example will not care but ripple current handling will play a bigger role.
              • moss99
                • Oct 2013
                • 50
                Thanks for that info , learnt something new today , I will pay more attention when looking at esr charts in future .
                So there must be different charts for low esr ?
                  • 31300
                  esr is stated in the datasheets of low esr caps,
                  but not in "general purpose" caps.
                  • moss99
                    • Oct 2013
                    • 50
                    So for power supply boards for example if i had no schematic or the capacitor which needed to be replaced, make could not be identified would it always be better to use low esr caps , ?
                      • 31300
                      yes
                      • moss99
                        • Oct 2013
                        • 50
                        Thank you for the great advice ..
                        • PeteS in CA
                          • Aug 2005
                          • 3586
                          Using a low impedance part for general purpose decoupling may be moderate overkill, but the extra cost is moderate (or less), and the low impedance part might last longer.
                          PeteS in CA
                            by momaka
                            03-15-2023, 10:17 PM
                          • P4C800
                            ASUS P5A and P2B-S recapping. Searching old datasheets.
                            by P4C800
                            I'd like to recap some of my old mainboards (they are from 1998) before switching them on again for the first time after many years in storage. All caps still look good from the outside.
                            There are three mainboards:
                            - ASUS P5A rev 1.04
                            - ASUS P2B-S rev 1.03 "Rubycon"
                            - ASUS P2B-S rev 1.03 "Chemi-Con"
                            If you are interested in their specs, The Retro Web has pages for the P5A and the P2B-S.
                            They all have many 1000uF 6.3V 105°C capacitors. But there are some differences I cannot figure out.
                            P5A
                            10-09-2023, 05:55 AM
                          • clearchris
                            New capacitor technology - high lifetime caps
                            by clearchris
                            I'm getting ready to put in a capacitor order. I generally look for nichicon, panny, kemet, or united chemicon, and I'm noticing that there aren't any 1000 hour caps anymore, and not many 2000 hour caps. Most of the caps are rated around 5000 hours or better. Last time I ordered, 1000 hour caps were pretty much most of them, and the very few 10,000 hour caps had pretty bad specs.
                            So what's the deal, have we made major progress with capacitor reliability in the past few years? Are these high lifetime caps ok to use? It's not that I wouldn't welcome the change, I really would, I'm...
                            03-26-2021, 06:39 PM
                          • Paxman_Swede
                            by Paxman_Swede
                            Hello!
                            01-14-2025, 09:51 AM
                          • link626
                            damn. I'm disappointed these high quality caps made my power supply worse
                            by link626
                            I thought my tv power supply was stable. It's been stable for a few weeks since I swapped in nichicon, united cc, panasonic caps to replace the cheap china caps.
                            But today it caused my tv to have a flickering spasm again.
                            what a letdown.
                            I swapped back my backup power board which has cheap china caps, and the tv backlight stopped flickering.
                            Sometimes these high quality caps just don't make things better.
                            09-01-2021, 11:02 AM
