Very old Sanyo OS-CONs. Safe to use?
  • quicknick
    • May 2009
    • 33
    Hi folks,
    Some time ago I got (for very cheap) a bag of 200 Sanyo OS-CON SA series, 220uF/10V, manufactured January 1988. Measured a few of them and the readings were all over the place so I put them in storage.
    Fiddled with them one more time today, to decide if I keep or throw them away, and noticed that strange readings are due to a layer of practically invisible oxide that developed on the leads. Rubbing them just a bit with fine sandpaper or even with the tester probes and they can be tested OK, tried with 10 of them and they mostly measure towards 250uF, with one or two being closer to their rated 220uF, and ESR is about 25-30mohm.
    Searched the 'net for information about their shelf-life, couldn't find anything useful. Do you think they can be used after all those years? Is there anything that can dry out or otherwise deteriorate inside them (I suppose they are solid electrolyte)?
    master hoarder
    • May 2008
    • 12175
    Re: Very old Sanyo OS-CONs. Safe to use?
    I'm no cap expert, but given that these are solid polymer capacitors, I don't think they will deteriorated as fast or as bad as regular electrolytics. So most likely, they are probably OK.
    Before using them for any repairs, though, perhaps take a few random samples and connect to a test circuit. With the test circuit, bring the caps to their full rated voltage (i.e. as close to 10V as possible, but not over) to see if the electrolyte inside starts breaking down and shorts out or not. If none of the sample caps issues, chances are the rest will be fine too.
    While at it with the test circuit, though, also check the leakage current on the caps - i.e. see how much current DC current they are drawing once fully charged to max rated voltage. After this, discharge caps, then check ESR and capacitance again to see if anything has changed.
    All in all, though, I think they are still likely OK to use.
    Curious to see what other people that know more about the matter will have to say (waiting for Wester547 to chime in 3...2...1............ just anytime now )
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      I wouldn't deem myself an expert either, however interested I am in the topic.
      But those Sanyo OS-CON capacitors (technically not polymers in the strictly technical sense of the term; they use a special type of semiconductor material for their electrolyte) are very old now. They are ~32.5 years old. And even though they are sealed with epoxy rather than rubber, this is enough time for some precipitation and deterioration, regarding their specifications, to occur. Their leakage current has probably risen quite a bit as is characteristic of solid capacitors (polymers or otherwise). Since such capacitors rely upon electronic rather than ionic conduction, conductivity is usually much better than comparable electrolytics (of the time at least), but the ability to “self-heal”, present in liquid electrolytics, is generally forsaken in solid capacitors as a result.
      I attached a catalogue which includes the datasheet for the SA series (found on page 43). It seems the ESR readings are fairly close to those in the datasheet, provided the case sizes match those in the datasheet.
        master hoarder
        • May 2008
        • 12175
        So what's your short answer then?
        Use them? Don't use them? Try them.
        I'd say try with caution. Or better yet, first charge to full voltage and check leakage current. If all is well... let's go!
        Thanks for sharing that datasheet by the way!
        • petehall347
          • Jan 2015
          • 4440
          use them in your own projects
          • Wester547
            • Nov 2011
            • 1268
            • USA.
            Sorry, got carried away and forgot to mention that part. Use them at your own risk (with caution). Although, despite being Japanese made solid capacitors, something makes me uneasy about using said capacitors from three decades ago, even in breadboard projects. Of course, better those than 30 year old Junkcons...
              master hoarder
              • May 2008
              • 12175
              Originally posted by Wester547
              Of course, better those than any Junkcons...
              Corrected that for you.
              Well, at least I would gladly use these over GSC / Evercon / Sacon FZ and Rulycon (fake Rubycons, no surprise). Heck, these might be better over a lot of other junk brands like CapXon and Cheng/Chang/ X.
              • quicknick
                • May 2009
                • 33
                Thank you for all the answers (and for the datasheet, the case size is indeed the same). Haven't had the time to play with them, but I'll check back in a few days with some results.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  Being polymer, and good polymers at that....I would use them without any concern.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • mockingbird
                    • Dec 2008
                    • 5484
                    I would certainly not use old OS-CON caps. They do in fact deteriorate. Just open it up and see for yourself. The polymer dielectric should be a moist, glossy black but you will often find in old polymers (or junk counterfeit Chinese polymers for that matter) a crusty, often white and scaly layer.
                    Good polymers will also often exhibit a well defined concentric circle when the innards are removed and the "roll" is looked at from the top.
                    • cj_reha
                      Mystery 80s Sanyo cap - perhaps polymer?
                      by cj_reha
                      Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                      01-06-2023, 09:24 AM
                    • toddw65
                      Sanyo DP5834 - Gray Screen
                      by toddw65
                      Hey All,
                      I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                      Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                      Thanks,...
                      10-31-2024, 10:37 AM
                    • hugocarmo
                      Sanyo VHR-D4710G VCR no sound.
                      by hugocarmo
                      Hi again guys.
                      Today I have a problem with this Sanyo VCR.
                      I bought it online, It worked sometimes.
                      I recap the Power supply and it started working fine.
                      Image is perfect and all digital effects too.
                      All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
                      I have no sound on playback, on tuner, or aux in.
                      On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
                      On one of the sound processing...
                      01-23-2024, 12:58 PM
                    • m4a2t0t
                      50's Sanyo monitor
                      by m4a2t0t
                      What type of caps can I use to replace these Rubycon (K) caps? Can I use a film cap? I cant find any aluminum electrolytic caps that go that low. They are .033 uf and .047 uf
                      06-16-2025, 07:04 PM
                    • fharris1977
                      Sanyo DP65E34 Backlights off after a 1-2 sec
                      by fharris1977
                      Hello. I have a Sanyo TV that had no backlights at first. I changed CS9 off the power supply and now the backlights will come on for a second or 2 and go right back off. I can see the image if I shine a flashlight in the screen. Anyone familiar with this particular model and problem, your help would be greatly appreciated. Thanks in advance....
                      03-14-2023, 01:13 PM
