4v caps?
  • torin3
    • Aug 2009
    • 178
    Re: 4v caps?
    It's hard tell without being able to see both of them, because the K is kind of squashed vertically, but I think it is closer to the Sanyo style. The bottom leg is fairly far out from the main upright on the upper leg.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: 4v caps?
      Sacon, I mean Evercon, I mean GSC's site has disappeared again.
      Time will tell what name #4 is [or will be].
      I've been digging a little and I'm starting to think Capsun was OEM'ing Lytics for Evercon/Sacon and possibly some OST.
      All 4 of those brands look identical on some Soyo P3 and P4 boards.
      Same color, same vent, same abnormality in the vent.
      [Abnormality = stamp over sleeve, vice, sleeve over stamp.]
      Mann-Made Global Warming.
      - Dr Seuss
      • fety
        • Jan 2007
        • 27
        Re: 4v caps?
        I just got a Dimension 8400 today and it has 4v caps too. I found this thread and wanted to make sure the 6.3v are ok. 4 of the 8 are spewin out the bottom, the others haven't budged. Hmmm.....
        • c_hegge
          • Sep 2009
          • 5219
          Re: 4v caps?
          Chemi-con KZJ, definately not polys. They NOT very tolerant of the heat. I recently removed some bulging and leaking ones from an MSI motherboard which were 16v 1000uF on the VRM in.
            • 30978
            Re: 4v caps?
            that's a very poor construction where the vent stayed intact and the bung came out instead!
            • fety
              • Jan 2007
              • 27
              #26
              Re: 4v caps?
              Question: Is it safe to assume those yellow guys in the middle will be ok? They are 4v 560uf and it says M 4D51U on the side. So are they Sanyo? -according to the K graphic on page 1 of this thread.
                • 30978
                Re: 4v caps?
                all the sanyo stuff i'v seen says sanyo on them.
                • Sparky
                  High voltage
                  • Jan 2007
                  • 234
                  Re: 4v caps?
                  If you have any I'd replace them but if not I'd leave them for now. I would however replace all 8 of the KZJ caps, not just the leaking ones, as the others are soon to follow. 6.3V is fine and would probably be easier to find (heck I have several 6.3V 820uF caps sitting around here, though used, so maybe not 820uF capable any more).
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    #29
                    Re: 4v caps?
                    those are fujitsu polys.
                    i would clear out that whole row and replace with the 820@2.5 available in the badcaps store and elsewhere. the ones in there now have likely been dealing with all the ripple since the lytics are shot and may have been for a while.
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
