Which diameter is this Hitachi capacitor?
  • Hitto
    • Apr 2019
    • 95
    • Italy
    I'm trying to determine the exact diameter of this Hitachi capacitor:
    It is a rather generic 85° capacitor and the datasheet specifies three possibile diameters: 25x45, 30x40 and 35x25.
    Datasheet is here:
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Which diameter is this Hitachi capacitor?
    It looks to be taller than it's diameter so that excludes 35x25. A 50 cent euro coin has a diameter of 24.25 mm if you have one of those you should be able to determine which cap you require.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      do you not have a mm ruler?
        • 31015
        yes, use a ruler.
        i'm often finding custom made caps in things that dont match the datasheet.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          My guess is 25x45 because the capacitor looks fairly tall from the PCB. The 30x35 would look more squarish, and I'm estimating 25mm from other cues from the picture...
          • Hitto
            • Apr 2019
            • 95
            • Italy
            Yes, they are 25mm! Thank you all.
            • Prolog
              by Prolog
              12-01-2024, 08:27 PM
            • chth96
              by chth96
              12-22-2023, 04:34 AM
            • chth96
              by chth96
              06-02-2024, 07:31 PM
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
            • chth96
              Should I replace polymer capacitor?
              by chth96
              a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
              I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
              Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
              Is this ESR value of polymer capacitor correct?...
              11-18-2022, 04:22 AM
