A question about Polymodding. I understand the rule of thumb has been 'half the uF value of the lytic...or thereabouts' when replacing a cap, but do you HAVE to reduce the uF of all the caps your replacing, or is it just certain circuits (VRM ect...). Prolly been asked and answered before, but I haven't found it. Any help would be nice.
Re: question about Polymodding
I agree. Recently polymers are also cheaper and (I hope so) more robust.
I think that as long as the E.S.R. of a polymer is not a problem for the circuit you can preserve the original capacitance. Doing so you can combine the benefits of polymers without a single trade-off.Comment
is it true that as long as the ESR is equal or lower than the ESR of the cap you are replacing, the motherboard should work properly? (obviously with a matching voltage and uf)Last edited by halaster79; 02-08-2020, 01:51 PM.Comment
no it depends on the vrm design. if it uses a high switching frequency, esr matters more so u must use the same esr or lower. u can get away with a slightly lower capacitance in that case.
if its a low switching frequency, capacitance matters more so u must use the same capacitance or higher. u can get away with a slightly higher esr.Comment
How would one know if it used either one?no it depends on the vrm design. if it uses a high switching frequency, esr matters more so u must use the same esr or lower. u can get away with a slightly lower capacitance in that case.
if its a low switching frequency, capacitance matters more so u must use the same capacitance or higher. u can get away with a slightly higher esr.Cap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
There is no precise guide to this really. It's mostly a rough ballpark.
Generally, this "high" frequency vs. "low" frequency VRM thing is mainly meant to rule out much older motherboards. For example, many old ECS motherboard (but also a few other cheapo ones) used a KA7500 or DBL494 or TL494 PWM chip - i.e. the same ancient PWM chip that's been used in ATX power supplies for decades. These PWM chip doesn't really go much above 50 KHz switching frequency, if even that, and the motherboards are 2-phases max. The ECS K7S5A, for example, has 4 coils... but it's only a 2-phase design due to the fact that KA7500/TL494 having only 2 outputs. Either way, motherboards based on these ICs tend to have either bigger inductors or just more larger capacity capacitors... and typically it's the latter. Because of the relatively low switching frequency, ultra-low ESR caps are not needed, but the capacity is important due to the slow frequency at which the output caps are "refilled" from the coils. In other words, it's like having bigger batteries in a device, but charging the device less often.
That's why on many old motherboards with KA7500/TL494/DBL494, you see at least six 2200-3300 uF caps filtering the CPU VRM. The ESR doesn't matter so much, but the capacitance does. And that's why they got away just fine with using barely entry-level low ESR crap caps (like G-Luxon LZ and similar.)
This brings another point: number of VRM phases.
Generally, the more phases a VRM has, the less capacitance is needed on the output. That's because each phase "refills" the output caps when the others aren't. So more phases = lower ripple current per given output capacity. Thus, on some older motherboards with only a single phase VRM (think Pentium 3 era), it's good to keep the capacity similar to the original (or higher, if possible.) As to whether very low ESR caps are needed... that brings us back to switching frequency: inductors/coils with less than 1-2 uH tend to be "higher" frequency IME. Meanwhile, anything with 4-5 turns or more on a big inductor core is typically medium frequency, more or less. These, and the high switching frequency boards will do very well with ultra-low ESR caps (or polymers).Comment
wouldn't the reason why older boards are different because they don't use ATX 12V? Didn't older boards use the 3.3 or 5V rail for CPU power? A lot of those higher uf caps are 6.3v. Vs the 16v input -> Mofset & coil -> output cap 2.5poly or 6.3v lytic from ATX 12v
just a thoughtCap Datasheet Depot: http://www.paullinebarger.net/DS/
by ReintarFirst of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...08-30-2024, 06:13 AM -
by DeXXterHello, so I replaced a soc SRK08 (i3-1115G4) on a hp 14-dq because the 1.8v power supply was shorted and the pch was gone and I installed a SRK05 (i5-1135G7) that I had at hand. And I was wondering if a clean me region is needed after replacing the chip, I usually do this on laptops with separated pch, but with a soc (cpu and pch together) I have no idea. Normally I wouldn't ask this, but I have only the motherboard, no screen nor the adapter, and after I fix this I have to send it to another region so if someone knows about this, some help would be apreciated.
Note: After doing all... -
by competitionI have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
by doivaythoiemStatus: I have a 12th generation Acer Nitro laptop with the main code HH514 LA-L973P REV 1A and the CPU is faulty. I replaced a CPU from an Acer mainboard of the same type and it worked, but the CPU had an error and couldn't enter Windows. Next, I replaced a CPU from a Dell laptop that was still working but had a VGA error. After replacing it, I flashed a new bios from the Acer manufacturer, but the machine still couldn't work. Can someone answer this question? Thanks.11-06-2025, 01:29 AM
I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.-
- Loading...
