One socket works, one doesn't
  • bobrosco
    • Jun 2005
    • 9
    I'm a newbie, but I already appreciate the site!
    I recently became the proud owner of an old Abit VP6 that supposedly worked before I got it. So I plug her in to take for a test drive and within the first few seconds, two caps popped (EC 30 and 31 if it matters). I read through the forums here and ventured to replace to two with some Radio Shack 1000uF 35V since they were easy to come by. Now one socket posts and will boot fine, but the other socket won't post at all. I have 2 PIII 1.0 identical processors and each will boot in the "working" socket fine, but the board won't post at all once a processor is in the "other" socket.
    So my question is, would it be a good investment to recap the board and potentially solve my problem? or should I look for something else as the cause? or is this just bad news?
  • bushytails
    Moderator
    • Dec 2004
    • 217
    Re: One socket works, one doesn't
    Replace all the caps... including the two you put on. They're probably not low ESR capacitors, and can be almost as bad as bad capacitors...
    I don't know about VP6s, but on MSI 694d boards (also dual p3), the second cpu socket going awol is one of the first signs of bad caps.
    --Randy
    • Chris1992
      • Apr 2005
      • 561
      although Willawake says that the board <i>will</i> post with non-low-esr caps, I would replace all caps including the 2 new ones you put on. And maybe you have to enable DP capability in CMOS, I dunno. Never had a vp6.
      The great capacitor showdown!
      • bobrosco
        • Jun 2005
        • 9
        Thanks! No settings in the BIOS that I've seen or read about.
        I read that Mouser and Digikey were popular places to get new caps, but I'm having trouble locating low ESR caps that I need:
        15 1500uF 6.3V
        4 1000uF 16V
        4 1000uF 10V
        I searched "low ESR" and "computer grade" on the other sites listed in the FAQ too. Any suggestions where I can find my replacements in the US?
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          https://www.badcaps.net/forum/showth...hlight=digikey
          North America - Allied Electronics - http://www.alliedelec.com/
          North America - Computek - http://www.computekinc.us/
          North America - Digikey - http://www.digikey.com/
          North America - Mouser - http://www.mouser.com/
          North America - Newark In One - http://www.newark.com/
          look for panasonic FC or Rubycon ZL. otherwise Topcat can sell you Rubycon MBZ which are superior caps you will not find at these sources. http://www.badcaps.net
          • bobrosco
            • Jun 2005
            • 9
            Thanks for the help. I ordered the panasonics from digikey, and once I get it finished, I'll post the (hopefully good) results.
            • bobrosco
              • Jun 2005
              • 9
              Well... I replaced the 23 capacitors on the board with the panasonic fc series and I still get the same results. One socket posts fine, the other not at all. Any other suggestions?
              • bobrosco
                • Jun 2005
                • 9
                New info:
                While checking the non working socket, I noticed the cpu that was in the socket has one pin that is just barely bent towards the center of the cpu. I can easily straighten it, but once I try to "lock" the socket, it's bent again. Is there a way to check to see what's causing this?
                • bushytails
                  Moderator
                  • Dec 2004
                  • 217
                  check for the remains of a broken off pin in the socket, or other damage.
                  --Randy
                  • bobrosco
                    • Jun 2005
                    • 9
                    Found the problem
                    The socket had some superglue? or something clear and hard down in around the pins. I removed the upper part of the socket and could see it down in there. I removed the rest of the socket and the pins were broken and bent, so that's beyond my skill to mess with.
                    So now I have a VP6 with new caps and can only be a single.
                    Grrr....
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      i have replaced sockets on these.bet tc has too.
                      dont give up yet!
                      • bushytails
                        Moderator
                        • Dec 2004
                        • 217
                        That's going to be a joy to desolder...
                        --Randy
                        • bobrosco
                          • Jun 2005
                          • 9
                          Even if I can manage to desolder them, can you only get replacement pins from a donor? I guess you'd only have to replace the broken and bent ones, so that might be managable. Also, the plastic that covers the pins and holds the cpu in place isn't in great shape, I'd probably replace that if I'm even considering going through that kind of work. Where can you get those?
                          • Chris1992
                            • Apr 2005
                            • 561
                            I'd try digikey; if you can get pci sockets than I'd assume you can get PGA370 sockets.
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              dont give up yet!
                              I have. NOT fun!!! Took forever and a day. A VP6 is well worth the effort tho. Good Luck!
                              <--- Badcaps.net Founder
                              Badcaps.net Services:
                              Motherboard Repair Services
                              http://folding.stanford.edu/
                              Team : 49813
                              Join in!!
                              Team Stats
                              • bobrosco
                                • Jun 2005
                                • 9
                                It seems that digikey, mouser, newark, and allied electronics are all out. I'd have to get 90 or so to make the minimum order. Does that mean I need a donor?
                                • Chris1992
                                  • Apr 2005
                                  • 561
                                  Yup. Talk to your local computer store, see if they have a dead s370 board.
                                  • bobrosco
                                    • Jun 2005
                                    • 9
                                    Thanks, found one. There's a lot of pins to unsolder...
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16958
                                      Yes there is. Take your time and be patient. Don't pry hard on it when all the leads are desoldered. If a lead is still attached, you'll ruin the board if you rip it out. Use a small flat screwdriver and gently lift on it. By feel, it will tell you where it's hanging up, and you can then remove any remaining solder from that lead. Soldering the new one in is a snap, removing the old one is the hard part.
                                      Good Luck!
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • torchzack
                                        Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                        by torchzack
                                        Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                        I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                        Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                        08-28-2023, 07:42 AM
                                      • DynaxSC
                                        ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                        by DynaxSC
                                        I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                        Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                        Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                        The behaviour is also really very strange, i.e.:
                                        • The disk shows always up in BIOS - so it is recognized, so far so good
                                        • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                        02-23-2025, 01:33 PM
                                      • hinisa
                                        Xiaomi router freezes at boot after re-capping
                                        by hinisa
                                        I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                        When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                        After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                        Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                        07-08-2023, 05:58 AM
                                      • DynaxSC
                                        MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                                        by DynaxSC
                                        Hi Folks
                                        I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                                        Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                                        09-29-2024, 04:27 PM
                                      • NolesFan
                                        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                        by NolesFan
                                        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                        10-24-2024, 06:36 PM
