Nippon Chemi-Con 3300uF 10x25mm?
  • abyse
    • Nov 2017
    • 11
    • World
    I needed some 3300uF 10v caps for my psu (especially 10mm), so I ordered from ebay 10 Pcs of Nippon Chemi-Con (NCC) KZE 10V 3300UF caps 10mm x 25mm, are these caps counterfeit?
    link for this cap on ebay: https://www.ebay.com/itm/302793396429
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: Nippon Chemi-Con 3300uF 10x25mm?
    that link is just inadequate for telling if its fake as it doesnt show the top vent of the cap and doesnt show the bung on the bottom. two telltale signs of fakes.
    but looking through the chemicon kze datasheet, the 3300uF 10v caps come in 12.5x25mm can size not 10x25mm. please measure the caps again yourself. if they are indeed 10mm in diameter, they are most likely fakes. dont buy caps from ebay or china. buy from a reputable seller like digikey, mouser or some such.
      • 31084
      the seller sounds familiar, i think they are probably legit.
      but they arent really suitable for psu's - the esr is a bit low.
      • mariushm
        • May 2011
        • 3799
        Yeah, KZE series has a bit too low ESR for switching power supplies, but it should still work if it's not a crappy psu in the first place.
        10mm KZE while not in datasheet is not necessarily fake... 10mm is popular with power supplies and motherboards and KZE was used a lot on motherboards so I wouldn't say they're fake.
        abyse, if you decide not to trust them, I have in my personal stock these and I could mail them to you from here in Romania if you can pay for them using paypal ... should get to you in 3..5 days.
        3300 16 12.5 35 Panasonic FM 3750 12
        3300 25 16 25 Panasonic FR 3820 14
        3300 6.3 10 25 Nichicon HM 2800 12
        3300 6.3 10 25 Nichicon HZ 4690 6.5
        3300 16 12.5 35 UnitedChemiCon KZE 3400 15
        capacity , voltage , diameter , height , maker , series , ripple , esr (mOhm)
        6.3v caps would still work, your 3300/10 is most likely used to filter 3.3v or 5v in power supply, so 6.3v is safe enough
        So Nichicon HM 3300/6.3v while a bit on the low esr wise, would probably work just fine in the psu.
        • abyse
          • Nov 2017
          • 11
          • World
          I want to recap this Ultra X-Connect 500w Modular ATX psu for my retro pc build, all caps are Fuhjyyu brand, there are 2 caps "10V 3300UF" (output filters?) at 10mm diameter so I need 10mm caps because largers ones will not fit.
          Im a noob at capacitors so I used google to search for 10mm caps... I found out that Nippon Chemi-Con KZE series was used in high end PSU-us, that's why I ordered from ebay these Nippon KZE 10mm caps.
          So are you sure that Nichicon HM 3300/6.3v will be a good replacement for Fuhjyyu TNR 3300/10v ?
            • 31084
            i seem to remember in the past we had this problem with Antec psu's and solved it by using panasonic FK series 2700uf caps.
            • PeteS in CA
              • Aug 2005
              • 3581
              • USA, Unsure of Planet
              As has abyse, I've seen KZE in modern higher end PSUs. Rubycon ZL as well.
              PeteS in CA
              • Hitto
                • Apr 2019
                • 95
                • Italy
                As anyone checked if these KZEs are genuine? They could be a stock from a custom size made for some manufacturer but it ain't confirmed.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  So have I....in quite a few.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • abyse
                    • Nov 2017
                    • 11
                    • World
                    I will post some photos when I receive my eb@y package
                    • Hitto
                      • Apr 2019
                      • 95
                      • Italy
                      Thank you.
                      Also post their E.S.R. to check if they may be suitable in switching power supplies.
                      As a rough reference please note that Teapo SC capacitors (*2200uF@10V) used in nowadays ATX power supplies measure an average of 0.03Ω.
                      • Stefan Payne
                        • 1267
                        When KZE is too low ESR, Panasonic FM is really too low ESR!
                        They are so low that you can use Pana FM as a replacement for Nippon KZG - they are a bit larger and for the 6,3V/3300uF you have to go for the 16V instead but they are so similar on the lower end (IIRC 1000 or 1500uF).
                        As for Impedance:
                        The KZE has an Impedance of 18mOhms and 2770mA in the 3300uF/10V (12,5mm version though).
                        The Panasonic FM has 15mOhm and 3190mA Ripple Current...
                        Anyway, these look like they should be replaced with the shittiest Low Impedance caps you can find.
                        Such as the Nippon Chemicon KYB for exmple, though KY or maybe KYB preferred.
                        As for KZE in PSU:
                        You see them all the time in modern PSU! Its the Standard if they write "Japense Capacitors" on the Box -> KZE and similar from other manufacturers.
                        With a couple of KY for 1500uF or less...
                        • Stefan Payne
                          • 1267
                          According to the Spec Sheet its the 16V/2200uF. And the common one is the 10x30mm one -> 1780mA and 32mOhms Impedance.
                          The 10V is around 40mOhm (10x25mm) in the spec sheet...
                          • Hitto
                            • Apr 2019
                            • 95
                            • Italy
                            Yes, the common one is the 2200uF@10V (in the damned, recap unfriendly, D10 diameter).
                              • 31084
                              panasonic FR series.
                              have some usefull datasheets.
                              • Stefan Payne
                                • 1267
                                Panasonic F-S is what you're looking for, if you want to.
                                But for that old PSU, though they might also be rather good.
                                2700uF/10V should also be possible - as should 6,3V. Those should be easier to get.
                                • Hitto
                                  • Apr 2019
                                  • 95
                                  • Italy
                                  Thank you.
                                  Panasonic FRs seems to be the choice though they are lower E.S.R. than the KYs. The KYs howewer handle less ripple (~200mA) compared to the FRs. But they have a more close E.S.R. if we are aiming for a replacement for the Teapo SC. A challenging dilemma.
                                  By the way, Teapo SC 2200uF@16V measures 0.24Ω:
                                  On that same power supply there are also some Teapo SCs 2200uF@10V and I can confirm that they measure 0.30Ω/0.32Ω.
                                  Would the KZE, in case it measures around 0.18/0.17Ω, cause instabilities?
                                  • mariushm
                                    • May 2011
                                    • 3799
                                    I sincerely doubt it. You should be fine with KZE.
                                    Also keep in mind if they're for 3.3v and 5v output filtering, you'll be fine with 6.3v rated KZE (or FM) which will have slightly higher esr... datasheet says 22mOhm for 2200/6.3v
                                    • abyse
                                      • Nov 2017
                                      • 11
                                      • World
                                      Thank you.
                                      just received my package today, unfortunately i don't have an esr meter but I will order a cheap “LCR-T4 ESR Meter” from ebay 🤭 and I will post their values.
                                      • Hitto
                                        • Apr 2019
                                        • 95
                                        • Italy
                                        They look legit.
                                        • Topcat
                                          4700uF 6.3v and 3300uF 16v in a 10mm Diameter
                                          by Topcat
                                          Where can I get them these days? My usual sources are a no go in a 10mm, 12.5mm is too big. I'm recapping an old Antec rackmount PSU for a client (SmartPower SP2-450SXR) with a bunch of spooged Fuhjyyu crap caps, and he's insisting it be repaired....which is fine by me, I make more on it that way.....but I need to find these illusive caps....it's been a long time since I've needed these values....and now I can't find them. Odds are I could get away with 3300uf in place of the 4700uF, I've done it before...but if there's a source for them in 10mm, I'll try to stay original.
                                          10-14-2020, 06:35 PM
                                        • Oldschool297
                                          RELAND SUN 6.3v 3300uf Low or High ESR?
                                          by Oldschool297
                                          I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
                                          https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
                                          08-14-2023, 04:32 AM
                                        • ten-d
                                          Nippon Chemi-con 100uf 100v BP electrolytic cap
                                          by ten-d
                                          Hi all!
                                          I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                                          01-30-2024, 05:18 PM
                                        • RUllER
                                          chemicon produced by fuhjyyu
                                          by RUllER
                                          This is not a fake Chemicon, it is genuine
                                          Many companies are outsourcing to Chinese factories....
                                          01-29-2024, 12:22 AM
                                        • ssl6
                                          MSI K7T266 Pro (Ver. 1.0)
                                          by ssl6
                                          Hey Everyone,
                                          Long time lurker, but I think this is my first time posting.
                                          Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                                          I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                                          11-09-2023, 01:00 PM
