Nippon Chemi-Con 3300uF 10x25mm?
  • Hitto
    • Apr 2019
    • 95
    • Italy
    Re: Nippon Chemi-Con 3300uF 10x25mm?
    No official datasheets for this resized version. How to estimate their ripple rating?
    I'd bet not less than 2200-2300mA but a better way to calculate or estimate it would be important for replacing (though they surely beat the Fuhjyyu).
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3266
      • Singapore
      u look at the can size. for electrolytic caps, the esr and ripple rating is affected by the can size so all caps within the same series with the same dimension have the same esr and ripple values. the larger the can size, the lower the esr and the higher/better the ripple rating.
      • Topcat
        4700uF 6.3v and 3300uF 16v in a 10mm Diameter
        by Topcat
        Where can I get them these days? My usual sources are a no go in a 10mm, 12.5mm is too big. I'm recapping an old Antec rackmount PSU for a client (SmartPower SP2-450SXR) with a bunch of spooged Fuhjyyu crap caps, and he's insisting it be repaired....which is fine by me, I make more on it that way.....but I need to find these illusive caps....it's been a long time since I've needed these values....and now I can't find them. Odds are I could get away with 3300uf in place of the 4700uF, I've done it before...but if there's a source for them in 10mm, I'll try to stay original.
        10-14-2020, 06:35 PM
      • Oldschool297
        RELAND SUN 6.3v 3300uf Low or High ESR?
        by Oldschool297
        I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
        https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
        08-14-2023, 04:32 AM
      • ten-d
        Nippon Chemi-con 100uf 100v BP electrolytic cap
        by ten-d
        Hi all!
        I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
        01-30-2024, 05:18 PM
      • RUllER
        chemicon produced by fuhjyyu
        by RUllER
        This is not a fake Chemicon, it is genuine
        Many companies are outsourcing to Chinese factories....
        01-29-2024, 12:22 AM
      • ssl6
        MSI K7T266 Pro (Ver. 1.0)
        by ssl6
        Hey Everyone,
        Long time lurker, but I think this is my first time posting.
        Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
        I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
        11-09-2023, 01:00 PM
