Gigabyte GA-7VM400AM
  • lucky13
    • Aug 2007
    • 412
    Hello all,
    Someone give me this mobo with CPU attached to try to help him.
    I connect to my known good PS and memory. It does not POST/beep.
    When the power button is pressed, the mem light on the mobo will light and the CPU fan will run. If I press and hold the power button, it will shut down in a few seconds. If I press the power button, it will start up again, just won't POST.
    The CPU heatsink does get warm if I disconnect the CPU fan.
    I ohmed the MOSFETs and they are not shorted. They all have similar ohms when compared to each other. However, I use my IR temp meter and one of the 4 MOSFET remains at room temperature (25degrees). The other 3 runs at about 30degrees. (How do I attach picture?)
    I have browsed thru all the posts on "KZG" and Gigabyte and learned that these KZGs although not showing any bulges should be replaced.
    Also, do the other two HD series caps (1200/6.3V) seems to have shrunk sleeving?
    Finally, I popped off the heatsink and found the CPU in quite good shape (i.e, no burn mark).
    Any suggestions before I start with recapping?
  • ss627
    Super Member
    • Mar 2008
    • 52
    Re: Gigabyte GA-7VM400AM
    Did you try putting in a new bios battery?
    • Scenic
      o.O
      • Sep 2007
      • 2642
      any "Choyo" caps on that one..?
      25V 330uF (iirc) were common on older gigabyte boards. (socket A and 478 (P4) era)
      they pretty much always leak from the bottom and dry out..
      • lucky13
        • Aug 2007
        • 412
        Actually, I took out the CMOS battery prior to test. I put it (checked and has 3V) back in but still won't POST. Gee, I thought that would have been too easy.
        • lucky13
          • Aug 2007
          • 412
          Nope, anything of larger size are all KZG except two 1200uF/6.3V which are HD(M).
          I borrowed a ESR meter and gone thru all the KZG and HD(M) caps and they are not quite low in terms of ESR.
          Anyway, I powered it up again and check the voltages on the VRM FETs:
          IN Out
          4.28 1.65
          6.05 0.02
          4.27 1.66
          7.44 0.02
          So, it appears two of the FETs are not turning on. However, all 4 FETs give me similiar ohms so I don't think they are shorted.
          Also, I can turn the power to the board on and off using the Power button connected to the mobo so the board is not totally dead.
          Anyone has experience on the voltages on the VRM FETs?
          Anyone still suspect the 3300/6.3V KZGs even they look fine and are not high on ESR?
          Thanks.
          • lucky13
            • Aug 2007
            • 412
            Ah... found the instruction by willawake on how to attach picture. Many thanks!
            So the green markings are the two have zero volt out.
            • lucky13
              • Aug 2007
              • 412
              OK, maybe two of the FETs are dead.
              The two that have no output (and cold) have lower ohms than the other two.
              The markings on all 4 are:
              07N03L
              AV340
              I Googled and found there are 4 different varieties of this 07N03L:
              IPB07N03L
              IPD07N03L
              IPP07N03L
              IPU07N03L
              Does anyone know how to tell which is the correct one?
              Are there any subs for this?
              Thanks.
              • Gianni
                • Jul 2008
                • 681
                • Italy
                Hi lucky13
                it is hard to say because the marking type it is the same for two MOSFET types: 30A and 80A.
                I think probably it is IPD07N03L package TO252 -3-11, let see if other members have a definite answer.
                I attach here the datasheet I found, you can search for other MOSFET with same parameters and case.
                I wonder how they can sell different devices with the same marking on the package.
                Ciao
                Gianni
                "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                H. J. Brown
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  the mosfets are not a problem.
                  that is a 2 phase vrm and it it running.one of each pair is the switch and the other a syncronous rectifier.
                  measure across the big caps close to the cpu and you will also find your 1.65v reading there.
                  there is a chance the vrm output caps are bad but your only way to prove that is to replace unless you own an esr meter or a scope.do you have a post card?
                  http://cgi.ebay.com/USB-PC-Desktop-Analyzer-Diagnostic-POST-Test-Card-PCI_W0QQitemZ370153103748QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item562ed82184&_trksid=p3286.c0.m14&_trkparms=72%3A1546|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
                  • lucky13
                    • Aug 2007
                    • 412
                    Well, that's good to know about the MOSFETS. I was about to unsolder the legs to ohm them again.
                    Funny I just borrowed a POST card from someone today. Although it does not look like the one you quoted, this one has ISA and PCI edges. It does have 4 digits readout like the one you shown. I will plug it in and try and post back results.
                    Is the one you quoted newer and has better indications?
                    • lucky13
                      • Aug 2007
                      • 412
                      Originally posted by Gianni
                      Hi lucky13
                      Ciao
                      Gianni
                      I found Digikey in the USA carries IPU07N03LAIN-ND. It is a N-CH 25V 30A TO-251 MOSFET.
                      I might not have to order them as kc8adu said they are probably OK as this is only a 2 phase VRM!
                      Thanks for your effort!
                      • lucky13
                        • Aug 2007
                        • 412
                        OK, this looks like the POST card I borrowed:
                        http://cgi.ebay.ca/ws/eBayISAPI.dll?...0054557&_rdc=1
                        I plug this card into one of the PCI slot. No memory installed. Just CPU and speaker. K/B & on board video connected. Now, here are the results:
                        Press power button.
                        Memory LED on mobo lights up
                        CPU fan spins
                        No beep, nothing on the screen.
                        The POST card shows 4 dashes.
                        These LEDs are lit:
                        All 4 on the left hand column, -12V, +12V, +5V, +3.3V
                        Only one light on the right hand column lights up: CLK
                        The other 3 are off: TRDY, FRAME & RESET
                        Apparently, the 4-digits should go from 00 to FF?
                        Anyway, just for fun, I removed the CPU, fan and tried again:
                        Same result EXCEPT the RESET on the right column now lights up too.
                        So what does this all mean? Dead CPU?
                        Should I go get another supported CPU to try? Any chance this board is a CPU killer?
                        • lucky13
                          • Aug 2007
                          • 412
                          OK, borrowed a working Duron 750 and popped it in. Same result. No post.
                          Putt he Duron back into the donor motherboard, still works. Yeah, so at least this board is not a CPU killer.
                          Anyone wants to chime in?
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            put your chip into the donor.report results.
                            of course make sure the board can support yours.and your board can support the donor chip.
                            must configure the boards right too.
                            • lucky13
                              • Aug 2007
                              • 412
                              OK, recap those 5 KZG 3300uF and 2 HD 1200/6.3V.
                              I was really hoping for a miracle....
                              but NO GO.
                              Same for the original Sempron chip and the Duron chip I borrowed.
                              The POST card does not show anything other than what I've reported previously. So I guess the board just doesn't get to POST.
                              I was holding out hope for this board because it seems to function other than no POST. The board will shut off if I leave the CPU heatsink loose so that tells me the temp sensor to shut off still works. The NB and SB do not get really hot. The NB which has the heatsink definitely runs much warmer than the SB.
                              Anyway, I put the Sempron CPU into the donor board to see if the CPU is dead. It got to the Compaq logo and I smell something burning so I guess the CPU is alive.. I quickly yank the ac cord and looks like no damage done to the donor board (not sure about the Sempron). it was a jumperfree board.
                              Anyway, the POST card shows many different numbers on the 4-digit display as the Compaq board boots up. So my conclusion is that until the board takes the 1st step, nothing will happen and the board remains in veggie state.
                              I will see what the owner wants to do with this board. Maybe I can keep it and I might further learn how the boot cycles works and find something...
                              Thanks for the pointers everyone.
                              • lucky13
                                • Aug 2007
                                • 412
                                I was reading the post "Testing VRMs" made by AK0R.
                                He said
                                d. Measure resistance from output of VRM to ground (should be greater than 1 megohm, usually much greater).
                                Well, just for fun, I ohmed the VRM 3300uF output caps (replaced already) and they have like 84 ohms!
                                So, they are not a dead short but perhaps explain wht this board won't POST.
                                Now, where do I look again for this partial short?
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Check for solder hairs or spatter trails.
                                  Mann-Made Global Warming.
                                  - Dr Seuss
                                  • lucky13
                                    • Aug 2007
                                    • 412
                                    There isn't anything wrong with soldering... looked with 30x magnifier.
                                    Using the picture I have posted above, this is a 2 phase VRM as per kc8adu.
                                    I've used my DMM to measure the dc resistance from Drain-Source on the 1st MOSFET (the one that has 7.44 in and 0.02 out, see 1st table). This as I understand, is the Vcore voltage.
                                    Here is a somewhat interesting/surprising result:
                                    with CPU in the socket, the dc resistance is 0.2ohm
                                    if I remove CPU out of socket, it is 32.2ohm
                                    Remember the MOSFETs are not hot (see temperature taken with IR temp gun). If anything, 2 of them are pretty cold.
                                    Tested with 2 known working P/S (SPI brand).
                                    So what does this mean ???
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      if vcore is reading correct for your cpu look elsewhere.
                                      normal to read some resistance on vcore to ground.
                                      you probably killed your procs running without the hsf.
                                      amd athlons dont like that!by the time you smell it or the board shuts down its too late.
                                      • DynaxSC
                                        GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                        by DynaxSC
                                        I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                        General test conditions:
                                        - Tested with Core i5 6500 and Core I7 6700K - no difference
                                        - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                        What is wrong:
                                        With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                        When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                        03-21-2025, 06:23 PM
                                        Thermal pad thickness for various laptop GPU / Graphics Cards
                                        ASUS Dual RTX 2070 OC 8GB
                                        ASUS ROG STRIX RTX 3080 OC
                                        ASUS ROG STRIX RTX 3090
                                        ASUS TUF Gaming RTX 3080 OC Edition
                                        ASUS TUF GTX 1660 S-O6G GAMING
                                        EVGA RTX 3060 Ti XC GAMING 8GB
                                        EVGA RTX 3060 XC GAMING 12GB GDDR6
                                        EVGA RTX 3080 FTW3 ULTRA GAMING
                                        EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                        EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                        Gainward RTX 2080 Phoenix GS Specs
                                        Gainward RTX 3070 Phoenix 8GB
                                        Gainward RTX 3080 Ti Phoenix
                                        GIGABYTE AORUS RTX 3080 MASTER 10G
                                        02-09-2024, 08:08 AM
                                      • Woodsworth
                                        PS3 CECHC03 60GB YLOD Troubleshooting
                                        by Woodsworth
                                        I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                                        START
                                        Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                                        03-19-2024, 07:58 AM
                                      • harp
                                        Metod for removing glued heatsink from fragile component
                                        by harp
                                        I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                                        06-23-2025, 02:01 PM
                                        Gigabyte AERO 16 XE5-73UK948HP Notebook Specification for Upgrade or Repair
                                        This specification for the Gigabyte AERO 16 XE5-73UK948HP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 XE5-73UK948HP boardview and 16 XE5-73UK948HP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 07:19 AM
