Preliminary test before recaping
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Hi all
    I have a question about testing a board so I'm here to ask suggestion from experienced members.
    Probably I will have to repair a QDI MOBO with a Athlon 1800. The problem is that sometimes it start correctly and sometimes it doesn't recognize the RAM and it emits some BEEP sound.
    Probably it has some bad brands caps but I'm not sure about it.
    My question is: if I solder good caps in parallel to the caps present on the board, can I have problems?
    I want proceed in this way because I don't want to waste time replacing caps just to discover the problem is still there.
    I believe this method can work, if the caps on the board are ruined (reduced uF and high ESR) I think that soldering good caps in parallel should solve the problem so next step will be to replace the old caps.
    What do you think?
    Do you see any contraindication?
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
  • linuxguru
    • Apr 2005
    • 1564
    Re: Preliminary test before recaping
    If you have unpopulated cap locations on Vcore, you can populate a few and check if the problem goes away. Otherwise, it's too messy.
    • Gianni
      • Jul 2008
      • 681
      • Italy
      Hi linuxguru, thanks for your answer.
      I received yesterday the PC so today I have opened it: there are 3 free locations around CPU, I can try what you suggested.
      All caps look good... but I know that only measuring their parameters you can be sure they are good.
      I posted some pictures in a new thread because I can't identify caps manufacturers.
      I hope to have time on Friday to work on this MOBO.
      Ciao
      Gianni
      H. J. Brown
      • Solder Boy
        • Nov 2006
        • 178
        Hi.. in order to do a proper job you really need an ESR meter to check the other caps. If the board still beeps, it means the board is still alive and worthy of a recapping job.
        Personally I would just replace the bad caps and be done with it. By adding new caps into the parallel series you aren't getting rid of the original problem. The bad caps are still going to be there.
        There isn't really many shortcuts when repairing boards.
        www.bcrelectronics.ca
        • Gianni
          • Jul 2008
          • 681
          • Italy
          Hi Solder Boy
          I agree with you, caps must be checked (with ESR meter) to know if they are good or not, even if they are not bulging or leaking.
          I just want to connect caps in parallel to see if the board works correctly, if it recognize RAM and start all (10-15) times correctly. If this test is positive, I will remove all old caps and then I place the good caps.
          As I do this job for small amount of money, I would like to save time and I want to be sure that recapping it is the right solution.
          If I recap it and the problem is still present, I have to trash the board and spend time to remove the new caps unless I trash them too.
          Last year I spent a lot of time on my second recap and at the end I had to trash the mobo because the problem didn't disappear.
          I'm not going to solder the good caps in parallel to the bad caps as final solution , it is just a test before doing the job.
          I have an ESR meter in my office... but I can't take it at home or test the board in my office, I can check caps after I have removed them.
          I will post some pics about the PC case so you will understand why I have doubts about the problem
          Ciao
          Gianni
          H. J. Brown
          • lucky13
            • Aug 2007
            • 412
            Originally posted by Gianni
            Hi Solder Boy
            Ciao
            Gianni
            Hello Gianni,
            I like your idea! I think adding low esr caps in parallel to questionable caps should allow the board to be checked for further problem. If no further problem, then yank out those bad caps and recap properly.
            I find myself not willing to give up on a board when I've spent time and money to recap it. Especially one that appears to have some life (more like in coma) but not dead.
            I am going to get myself some of those polymer caps to use for your idea. Then I will try your idea and post back here wih my results for all to see.
            • yanz
              • Nov 2004
              • 910
              Gianni, that trick is one of many "first step" that i often do before recapping a mobo (but it depends on the situation). It sometimes help the bad mobo that have problem to POST properly..
              I dont recommend this for a beginner because they will unlikely be able to do the soldering neatly.
              • Gianni
                • Jul 2008
                • 681
                • Italy
                @ lucky13 : let me know your results, I will try next time if I receive a board with serious problem (doesn't POST, doesn't load OS, restart continuously).
                @ yanz
                thanks for confirming my idea was not completely wrong and not, I'm not a beginner with soldering.
                This time I have skipped this step because a lot of caps had small pads so it would have taken a lot of time to solder the caps properly so at the end I decided to replace them all. I was lucky, the MOBO became reliable again and I gave it back after some test (Mem86 etc...)
                You are right when you say it is worth to make this test with MOBO that doesn't post; in this case even if it takes some time to solder caps in parallel, if nothing change, it takes less time to remove them instead of desolder them from original position.
                Ciao
                Gianni
                H. J. Brown
                  by momaka
                  03-12-2025, 03:42 PM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
                • chth96
                  How Can I test PWM DM0365R?
                  by chth96
                  Hello
                  I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                  So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                  I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                  I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                  06-18-2025, 04:14 PM
