Sewing Machine Help!
  • nathan211
    • Jul 2018
    first post here go easy on me.
    I have a sewing machine that im attempting to repair, iv'e checked over all the motor that runs the belt but on inspecting the foot pedal it seems like a capacitor in the pedal has popped.
    Symptoms are the machine will run for around 20 seconds or so then it will trip the breaker. Almost as if its getting too hot and theres some sort of thermal cut out. The motor turns freely by hand theres no alot of resistance.
    Question is if this capacitor had gone faulty why would the machine work at all?
    I dont know how to identify capacitor resistance etc so i will upload a picture of what i have.
    I was hoping it would be a solder out and in job.
    Thanks for taking the time to read this all
    Nathan
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sewing Machine Help!
    That is a start/run capacitor for the motor. You MUST get the correct replacement else you end up burning the Motor. The two red wires and one black is two caps in one casing.
    • R_J
      • 9544
      It is likely a arc suppressor cap across the line, does one lead go to chassis and the other two go across the line and neutral?
      The machine should work without it but you may not be able to listen to your AM radio at the same time.
      This should be the replacement
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Yes that looks like what I was thinking of.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Interesting arrangement. It could indeed be an arc-suppressor car, as R_J suggested. Though, if the machine doesn't work because of this, maybe it's also possible that it is some kind of a start/run cap.
          In any case, you can see there are three caps inside this one cap: 2x 5.0 nF and 1x 0.1 uF. You could probably use 2x 4.7 nF Y-caps and 1x 0.1 uF X-cap, all rated for 250 VAC. Just connect them in the same way as the diagram that R_J posted above and all should work well.
            • 31039
            it's called a "Delta Cap", they are just for noise suppresion.
            i used to see them in vac cleaners.
            2 wires to the motor contacts, one to the body/earth
            • Behemot
              • 4845
              • CZ
              It's also called input filter, you can often find some which also have common-mode coil in them, forming a complete input EMI filter.
              That machine has it's own circuit breaker or? If it is asynchronnous motor there may be the starting cap inside the motor. It is also possible the startup (or even the main) winding developped a short.
              • CG2
                Janome DC3050 Sewing Machine Pedal Resistance
                by CG2
                OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                04-14-2023, 07:53 AM
              • cind12
                GTX 1080 TI Gigabyte Aorus low resistance on vmem
                by cind12
                Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                Resistance on 12V 4K ohms (Power present when on)
                Resistance on 12V PEX 4K ohms...
                12-08-2023, 09:09 AM
              • bohaboha
                Sewing machine Husqvarna 1610 electric contact
                by bohaboha
                can someone say how to put this plug together, there are two cords, one goes to the pedal and the other from wall plug to sewing machine. Don't know if the pedal should get its power from the motor, it's a bit confusing because the two cords coming from the motor are brown colored, don't know which is live or ground the blue and brown cord comes from the lamp. if anyone knows grateful...
                04-22-2023, 08:05 PM
                ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-12-2024, 03:28 PM
              • RolandVossen
                Kenwood Chef KVC50 / KVL60 / KVC5000 / KVL6000 / KVL6030 / KVL6050 kitchen machine repair
                by RolandVossen
                I am attempting to repair a KVC50 kitchen machine. Problem is that speeds 1..5 on the speed dial do not work at all (motor is not engaged). The 'reverse' and 'slow' settings on the same dial however work properly. I removed the dial, its PCB components seems to be basic: a potentiometer, a microswitch, a couple of LEDs and a couple of SMD diodes or transistors. The dial has three cables with three connectors that hook up to the motor controller PCB. One connector (3 pins) for speed, one connector (5 pins) for the LEDs, and one connector (2 pins) for a safety switch that is...
                03-16-2024, 03:55 AM
