Where to get EVERCON CAPS 1500uf 6.3v E63A
  • delandtechnology
    • Apr 2009
    I have a xfx GF 6800 XT DDR3 video card with bad caps on it. The ones bad to the eye are EVERCON CAPS 1500uf 6.3v E63A (blue and gold in color). Does anyone know where I can get theis caps without having to buy hundreds of them?
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Re: Where to get EVERCON CAPS 1500uf 6.3v E63A
    Hi Deland
    Welcome to the Forum!
    You probably don't want to use Evercon branded caps again. Ever.
    To recommend a suitable replacement, you will need to know:
    Capacity: (1500uf)
    Voltage: (6.3v)
    Brand: (Evercon)
    Dimensions: (???) (usually diameter and length in mm will do)
    Series: (???) usually a 2 or 3 letter code like LE, LA, etc
    If you don't know the Series, Impedance (or ESR) and/or Ripple Current
    Whether is is a Radial capacitor with wires attached or a Surface Mounted Device (SMD)
    Whether is is an Electrolytic or Polymer cap. (Polymers are the metal ones with writing on top, not on the side)
    The Date Code (E63A?) isn't that important.
    Have fun!
    Keri
    The More You Learn The Less You Know!
    • Toasty
      • Jul 2007
      • 4171
      Look on the other side of the cap for the series number as Keri suggested.
      These are very short caps, correct? If the pix out there are correct, then these are radial, through hole mount.
      We're a bunch of voyeurs, so pics are always appreciated.
      Everson's site: http://www.evercon.com.tw/
      Toast
      veritas odium parit
      • linuxguru
        • Apr 2005
        • 1564
        Lol - Evercon are another incarnation of GSC. If you really want them, remit $10 to my PayPal account and I'll mail you all that I have - maybe a dozen.
        • Toasty
          • Jul 2007
          • 4171
          >>Lol - Evercon are another incarnation of GSC.<<
          ...and (probably) Sacon and Capsun
          Big Pope's site reported: www.capsmod.net/forum/viewthread.php?tid=109
          veritas odium parit
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            I rather u choose sanyo, panasonic, rubycon for this
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              no way i would seek out and buy more crap parts.
              stick with high quality replacements.
              • delandtechnology
                • Apr 2009
                Sorry for delay, got sick. Better now. What I have is as follows:
                Radial capacitor
                Capacity: (1500uf)
                Voltage: (6.3v)
                Brand: (Evercon)
                Dimensions: (10mm x 12mm)
                Series:ME (the ME was in a box)
                I am having a hard time finding them.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  i just fixed an xfx card like that.
                  used mbz 1500@6.3
                  10mmx12?
                  if you cannot easily get those get panasonic fm.iirc they are 10x20mm.
                  iirc topcat has the mbz on the main badcaps site.
                  • linuxguru
                    • Apr 2005
                    • 1564
                    There's Panasonic FJ 1800/16v/10mm x 20mm and a Sanyo AX or CG 1500/6.3v/10mm x 12mm that should work. For a graphics card, consider a Nippon Chemicon polymer series, 820/4v instead of an electrolytic. Any of PS/PSA/PSC/PSE/PSF should work.
                      by momaka
                      03-12-2025, 03:42 PM
                    • eryjus
                      by eryjus
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      by Paxman_Swede
                      Hello!
                      01-14-2025, 09:51 AM
                    • captain150
                      by captain150
                      03-16-2025, 07:34 PM
                    • Foetuss
                      Gigabyte GA-6OXT :: caps question
                      by Foetuss
                      Good evening
                      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                      But I was also suprised about the bigger boys, which are 330µF 25V.
                      Could it be they used 25V caps because they were cheaper / available at that time?...
                      02-11-2025, 12:22 PM
