metal oxide varistor how to chack with multimeter
  • divy
    • Mar 2018
    • 24
    • czc
    I have tevion TV power supply
    • 31293
    Re: metal oxide varistor how to chack with multimeter
    what does it say on it?
    got a foto?
    • divy
      • Mar 2018
      • 24
      • czc
      On Tvr 14621
      • divy
        • Mar 2018
        • 24
        • czc
        Pic
        • R_J
          • 9624
          The MOV should measure open circuit. If it checks shorted, remove it. The power supply should work without it, but it should be replaced for continued protection.
            • 31293
            it's probably good, when they fail they usually explode and cover the area in soot!
            • divy
              • Mar 2018
              • 24
              • czc
              When I chack mov with multimeter it not beeping it mean short?
              • petehall347
                • Jan 2015
                • 4450
                • United Kingdom
                touch your meter leads metal tips together and see what happens ...
                • divy
                  • Mar 2018
                  • 24
                  • czc
                  Only show some number not beeping
                  • petehall347
                    • Jan 2015
                    • 4450
                    • United Kingdom
                    does your meter have a beeper ?
                    • divy
                      • Mar 2018
                      • 24
                      • czc
                      Pic
                        Let's get to the point, what is the power supply or the TV not doing?
                        Are you getting any dc Voltage at the cold side connectors?
                        BTW, in beeping mode when it beeps it is telling you you have continuity between point A and point B, it does not mean what you are testing is bad or shorted out.
                        Use Ohm mode if you looking for shorts, but you need to know characteristic of components you are testing first.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5095
                          • New Zealand
                          If your meter is not beeping, and is showing 1968 with the leads shorted on continuity mode, then the leads or the meter is faulty...
                          Unplug the leads and short the input sockets together with a piece of wire. You should get a beep and a low number, almost zero...
                          -David VanHorn
                            • 31293
                            maybe the battery is low - i'v never had a meter that indicated "low battery" BEFORE it started showing bullshit readings!
                              BrightKing KD07 Metal Oxide Varistors (MOV) Datasheet
                              Metal Oxide Varistors (MOV) Data Sheet
                              Features
                              ● Wide operating voltage (V1mA) range from 18V to 820V
                              ● Fast responding to transient over-voltage
                              ● Large absorbing transient energy capability
                              ● Low clamping ratio and no follow-on current
                              ● Meets MSL level 1, per J-STD-020
                              ● Safety certification: UL: E327997 CSA: 246579 VDE: 40027827
                              Applications
                              ● Transistor, diode, IC, thyristor or triac semiconductor protection
                              ● Surge protection in consumer electronics
                              ● Surge protection in industrial...
                              10-07-2024, 05:58 AM
                            • chth96
                              How can I identify varistor which have been blew up?
                              by chth96
                              I mistakely pluged 100v japanese retro game console to 220v outlet.
                              So It seems that glass fuse and varistor have been blew up.
                              I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                              Is there any way to identify varistor type in my sega saturn PSU?
                              Any reply would be appreciated.
                              EDIT:
                              It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                              11-26-2023, 08:52 AM
                            • AlTaiRius
                              Measuring Resistance of Metal Oxide Power Resistor
                              by AlTaiRius
                              Can I measure a Metal Oxide Power Resistor the normal way?
                              When I put my fluke on resistance and measure across the legs (I've removed it) I get 22 kOhms. Reading the bands I'm expecting this to be a 330 mOhm +/- 5% resistor.
                              Am I reading it wrong or is it stuffed?...
                              02-01-2022, 11:45 PM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • questore
                              nvme and wifi error after liquid metal spill
                              by questore
                              Someone brought me a liquid metal damaged motherboard.
                              First I have removed alll liquid metal from the board.
                              0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
                              Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
                              There are 2 things that not working.
                              1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
                              2. nvme devices are not detected on either of the 2 slots....
                              11-11-2025, 01:16 AM
