Makita 440 Cap types?
  • R_J
    • 9590
    Re: Makita 440 Cap types?
    Check the large resistor and if it is not open, you might be able to solder back to the leads where you cut them, or add some wire around the leads and still use it
    I don't know where you got that resistor number The value is 0.47 ohm 10watt 5%
    This is the closest I could find here:
    CPC number is RE06460, Welwyn W24-0R47 JI You may need to check its dimensions to see if it will fit
    RS 666-1692 (C10R47JL) (min quantity 5)
    The triac is STP16A60 There is another number after the `6' (16 amp 600 volt triac)
    This Sanken number looks close TMA166G-L
    or Renesas BCR16CM-12LB
    • adamfromayr
      • Apr 2018
      • 16
      this one
      will the new one above replace the STP16A60 Bi-Directional Triode Thyristor
      Repetitive Peak Off-State Voltage : 600V
      ◆ R.M.S On-State Current ( IT(RMS)= 16 A )
      ◆ High Commutation dv/dt
      ◆ Non-isolated Type
      • R_J
        • 9590
        No That is a mosfet NOT a TRIAC (Thyristor)
        I would try BTA16-600BRG (714-0502)
        https://uk.rs-online.com/web/c/semic...834,4294856821
        Or BTB16-600B (251-2993)
        • adamfromayr
          • Apr 2018
          • 16
          well well well Guys
          I got me parts today 1-2 hours soldering 3 bits on
          The Makita worked, Then i tried again didnt work and again didnt work again worked, again worked!
          Im not sure if the switches are dodgy? what do you guys think?> or do caps and resistors need breaking in???
          i will keep testing and let you know how it goes here are the 3 x new parts ive used!
          https://uk.rs-online.com/web/p/mosfe...stors/7396147/
          https://uk.rs-online.com/web/p/produ...E&gclsrc=aw.ds
          https://uk.rs-online.com/web/p/throu...stors/7629560/
            • 31214
            could be the switch, if your carefull you can open them and inspect the contents.
            • R_J
              • 9590
              It is very likely that the fault is the switch. that could be all that was wrong. You could check the voltage across the terminals when it is not working. It looks like a dpdt so if either part of the switch is intermitint it won't operate.
              • petehall347
                • Jan 2015
                • 4440
                • United Kingdom
                #27
                bypass switch and turn on at power point . dont run it too long with 100 ohm 9 watt resistor instead of 0.47 ohm 10 watt
                • petehall347
                  • Jan 2015
                  • 4440
                  • United Kingdom
                  #28
                  RS 666-1692 is 470mΩ ...then op used 100 ohm ... best regroup me thinks ...
                  • adamfromayr
                    • Apr 2018
                    • 16
                    dam guys im GUTTED!!!!!!!!
                    Switched on today first time in 3 days and smoke out of switch area! i hate being defeated after many hours!
                    Might have to spend the £50 on the new board $75
                    As my soldering wasnt perfect and did i choose the wrong parts???
                    sad day for the makita 440
                    • petehall347
                      • Jan 2015
                      • 4440
                      • United Kingdom
                      #30
                      probably just a bad switch .
                      • adamfromayr
                        • Apr 2018
                        • 16
                        GUYS
                        You helped me a lot, so had to let you all know that after buying new carbon brushes, then a new circuit board, to fine out that it was the god darn switches
                        Its okay now, i inspected the old switches and they were contaminated inside with dirt, you wouldnt think a normal on/off switch would of been the fault!
                        oh dear
                        anyway guys thanks for all your help!!!!!!!!!!
                        adam
                        • R_J
                          • 9590
                          Now it really SUCKS
                          • John843883
                            • Nov 2012
                            • 71
                            At-least you've now got spares for future repairs, put them in storage and hope something else fails!
                            • ahmedtou
                              HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                              by ahmedtou
                              help me please
                              I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                              When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                              I will share all the details with you, including the disc information.
                              Code:
                              HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                              Current Profile: BD-R
                              Disc Information:
                              Status: Empty
                              State of Last Session: Empty
                              Erasable: No
                              Free Sectors: 12,219,392
                              Free Space: 25,025,314,816 bytes
                              Free Time: 2715:27:17 (MM:SS:FF)
                              Next
                              08-27-2025, 08:49 AM
                            • Mark R
                              Equipment Display Types
                              by Mark R
                              Most Displays I have worked with are of course LCD Or Blueish Fluorescent Types. I Have a Marantz PMD800 tuner with sort of a white display. The display area is a sealed rectangular shape in a Glass Case. Looks like some sort L.E.D. display only not your typical section number type. I picked up this Tuner cheap as the display is very Dim. In front of the circuit is a dull red Plastic lens.
                              The display is very week and hard to see. I've got my DC 5 Volts allover and also a DC 32 Volt that runs some other section. Power supply looks good front to back. Not familiar with this type...
                              06-07-2024, 07:19 PM
                            • dbuergi
                              DIY: Modified smart charger for all types of batteries
                              by dbuergi
                              sometimes i'm in need of a charger / tester for very small batteries and even if my multimeter doesn't show anything there is a chance that a smart charger helps to revieve. I'm happy with my Keenstone smartcharger and i made a small mod just to use it with smaller batteries like in smartwatches or even camera batteries with special contacts.
                              Soldering wires on the charger contacts and using needles as probes. I covered both with a shrink hose with integrated solder.
                              My first work was to bring my Samsung watch battery back to life with was not recognized...
                              07-18-2025, 03:17 AM
                            • diggitt
                              Makita DSH680 control board
                              by diggitt
                              I’m looking for a schematic and/or board view for the DSH680 circular saw.
                              I’ve knocked off a few components whilst removing the coating on the board and don’t know what they were or their values.
                              04-10-2025, 03:36 AM
                            • zen
                              DMR115 , Makita on site radio
                              by zen
                              Hi all
                              Trying to take this thing apart & there are 2 screws buried deep in the back of unit .
                              Look like torx of hexagonal heads .
                              Can anyone help with type & size of driver required ?
                              06-10-2022, 05:51 AM
