Antec PSU - Panasonic FS capacitors
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Antec PSU - Panasonic FS capacitors
    rugger: Good, look here for an example of what happens when you don't:
    https://www.badcaps.net/forum/showthread.php?p=435863
    • Behemot
      • 4845
      • CZ
      ZLQ is only current D10 4700/6.3 series, AFAIK. Though most 3300/6.3 will be also OK, like Chemi-Con KYB.
      • rugger
        • Feb 2005
        • 55
        Already have the 3900/6.3's Panasonic FS. Will probably install them tonight when I get a chance.
        Will see if this whole project is a bust or not
        • rugger
          • Feb 2005
          • 55
          Seems like I have been successful. Power supply is now working again!
          Changed all electrolyic capacitors except a 10uF Teapo hiding under a coil that was pretty much impossible to get out. Didn't feel like taking the coil out for a capacitor just to change a capacitor that is still good!
            • 31213
            the usual method when re-capping a psu is to pull the heatsinks out with the semiconductors still mounted on them.
            i do anyway - it helps brush out the dust.
            • rugger
              • Feb 2005
              • 55
              #26
              Wow (I thought removing the semi-conductors and heatsinks was mainly only done by reviewers to better identify the different regulators)
              That is far more work than just working around the heatsinks with a pair of pliers.
              I've done some basic measurements:
              5V rail, measures about 5.1V with about 20mV ripple.
              12V rail, measures dead 12V on the dot and I get about 40mV ripple.
              I'm pretty happy with that.
              • rugger
                • Feb 2005
                • 55
                #27
                Ok, so I'll just recap all the capacitors I replaced:
                4 x 4700uF 10V - Replaced with Panasonic FS 3900uF 6.3V
                2 x 3300uF 16V - Replaced with Panasonic FS 3000uF 16V (was a pain to fit as caps were bigger than original)
                2 x 1uF 50V - Replaced with Panasonic PW 1uF 50V
                1 x 220uF 16V - Replaced with Rubycon YXJ 220uF 16V
                2 x 1000uF 10V - Replaced with Rubycon ZLH 1000uF 10V
                1 x 470uF 25V - Replaced with Rubycon YXG 470uF 25V
                2 x 10uF 50V - Replaced with Rubycon YXF 10uF 50V
                1 x 47uF 35V - Replaced with Nichicon PS 47uF 35V
                1 x 22uF 50V - Replaced with Rubycon YXF 22uF 50V
                Thanks for everyone who gave advice, pretty cool to see this PSU working well again.
                • Behemot
                  • 4845
                  • CZ
                  #28
                  Exactly, I never do that unless absolutely necessary, takes too much time…
                  • rugger
                    • Feb 2005
                    • 55
                    #29
                    Happy to report, after 3 years of decent use, this smartpower PSU is still working great.
                    It has the 5V ooomph to power any retro motherboard that passes my desk!
                      After all of...
                      07-13-2024, 08:14 PM
                    • dragon3x
                      by dragon3x
                      power on.
                      Here are some examples :
                      switching supply area).
                      than 6.3 V.)
                      03-21-2025, 02:46 PM
                    • Andre Gilbert
                      by Andre Gilbert
                      11-20-2024, 08:52 PM
                    • CWEastwood
                      Antec Smart Power SL300S capacitor replacement.
                      by CWEastwood
                      I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                      The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                      I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                      Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                      03-25-2023, 12:18 PM
                    • slybunda
                      AA and AAA battery charger capacitors?
                      by slybunda
                      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                      it has inside:
                      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                      2 x 470uf 16v LZ105c branded as G.Luxon
                      not heard of these brands are they any good?
                      iv attached photos of the charger and the board inside for an idea on the type of...
                      12-24-2023, 04:41 AM
