Antec PSU - Panasonic FS capacitors
  • rugger
    • Feb 2005
    • 55
    I am working on recapping an old Antec Truepower II 380W I have 4 of these notorious 4700uF Fuhjyyu capacitors.
    I am wondering if these would be a nice replacement:
    http://au.element14.com/panasonic-el...ial/dp/2766904
    The FS range looks like it has very good performance, lifetime and size. So what is the catch?
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Re: Antec PSU - Panasonic FS capacitors
    Are there any other markings on the capacitor?
    Also it's a good idea to post photos of the unit.
    I'm not a expert, I'm just doing my best.
    • rugger
      • Feb 2005
      • 55
      The Fuhjyyu caps are the TM series.
      https://cdn.badcaps-static.com/pdfs/...9d6661716a.pdf
      10mm Diam x 30mm Height.
      For these, 10mm Diam is pretty critical, as 4 are installed right next to each other and are surrounded by other crap
      • RukyCon
        A Fake Rubycon
        • Jan 2017
        • 816
        What's the rated voltage of the capacitors?
          • 31209
          old story those caps,
          i remember those psu's several years back (a search will dig up the threads)
          a lot of us just decided the 4700uf caps must be bogus and used 3300uf instead if i remember right.
          • Stefan Payne
            • 1267
            Could be a bit too good for that PSU.
            What Series are those caps? Are they Low ESR?
            • rugger
              • Feb 2005
              • 55
              Sorry, I should be more clear in my OP. I bury myself in the literature of the old Antec PSU I am repairing, and tend to forget that everyone else hasn't thought about this for 10 years. I am just repairing this PSU for retro computing projects, because it has a good sized 5V and 3.3V rail.
              Stefan Payne:
              I have pulled the 4 x 4700uF, 10V, Fuhjyyu TM capacitors. They all tested very badly on my capacitor tester, awful ESR and high leakage - Their Original Specs are 2310mA Ripple current and 0.038 Ohm ESR. It is classed as a low ESR capacitor.
              I as planning on buying and putting in 4 x 3900uF, 6.3V, Panasonic FS series capacitors, as it is very hard to find the 10mm Diam capacitors that will fit this section of the board. The specs of the Panasonic caps are 2470mA Ripple Current and 0.018 Ohm ESR.
              The things I am worried about with this replacement are if I am going too low with ESR or if there is some inherent design feature of the FS capacitors that I should be aware of that make it unsuited to PSU applications (as their performance is significantly higher than the older FC and FR series in both size, lifetime and ESR)
              • redwire
                • Dec 2010
                • 3912
                I think the Panasonic FS would be the best choice.
                10mm diameter and 10V, very little selection out there. I see 3,300uF but 4,700uF goes to 12.5mm which does not fit without cursing. Only Fuhjyyu offer caps that skinny and tall.
                At 6.3V there are FS and Rubycon ZLQ.
                "Too low" ESR on a filter cap is not a problem. The voltage derating is less 6.3V vs 10V so no lifetime extension there, but quality 3,900uF can beat a cheapola 4,700uF IMHO.
                • rugger
                  • Feb 2005
                  • 55
                  A soggy noodle would be a better capacitor than those Fujyyua capacitors.
                  The Panasonic FS caps, for the case sizes I am buying, are rated 10k hours at 105C. I don't think life would be a concern unless they are being mistreated or deliberately cooked.
                  It is good to know that exact ESR isn't so much of a problem on these filter caps. I know I have to be careful on VRM circuits to match ESR as best as possible, which means that I am always a bit careful on cap choice.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    It's totally ok to replace the 4700uF caps with 3300uF capacitors. Personally, I have recapped several Antec psus with Panasonic FK 10mm 3300uF 6.3V for 3.3V and 5V output rails without any problem. 8 years later, the power supplies work without any problem.
                    • rugger
                      • Feb 2005
                      • 55
                      I will be getting the following capacitors:
                      Original - Replacement
                      4 x Fuhjyyu TM 4700uF 10V Low ESR - replaced by - Panasonic FS 3900uF 6.3V Low ESR (lower voltage OK because these are for 5V and 3.3V lines)
                      2 x Teapo SC 3300uF 16V Low ESR - replaced by - Panasonic FS 3300uF 16V Low ESR (will be a pain to fit)
                      1 x Fuhjyyu TN 470uF 25V General Purpose - replaced by - Rubycon YXG 470uF 25V Low ESR
                      2 x Teapo SEK 1000uF 10V General Purpose - replaced by - Rubycon PX 1000uF 10V General Purpose
                      1 x Fuhjyyu TN 47uF 35V General Purpose - replaced by - Rubycon PX 47uF 35V General Purpose
                      Hopefully there are no mistakes here
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        You should use entry level low esr capacitors instead of GP caps. CWT used TN, general purpose capacitors for cost cutting, but this doesn't mean that you should do the same. Rubycon YXF and Panasonic FK are a perfect example of entry level low esr caps. Use something like that please if you don't want high ripple voltages
                        • rugger
                          • Feb 2005
                          • 55
                          Yeah, I'll change the 1000uF caps to Low ESR (probably Rubycon YXG if caps are a good size match)
                          I'll leave the 47uF cap as a general purpose, as I can't be sure what the particular capacitor is doing. This original didn't look or test stressed in any way.
                            • 31209
                            i think you will find lots of small caps hidden in that psu
                            look between the transformers and heatsinks - also look for caps hiding inside black heatshrink tubing.
                            • goodpsusearch
                              • Oct 2009
                              • 2850
                              • Greece
                              Small caps matter a lot. 1 of them is the critical 5vsb cap. If this cap goes high esr, then the 5vsb could go 7-10V or more and kill the motherboard. It's important that you replace all the caps including the small ones with entry level low esr made in Japan capacitors
                              • rugger
                                • Feb 2005
                                • 55
                                Yeah, there are a few more small caps hidden in crevices. I'm leaving them because I never really see them fail and getting them out will be more pain then it is worth.
                                I believe the 470uF capacitor belongs to 5VSB. That is being replaced by a low ESR cap.
                                  • 31209
                                  "see them fail" ??
                                  they dry up inside.
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2850
                                    • Greece
                                    +1
                                    • rugger
                                      • Feb 2005
                                      • 55
                                      Yeah, Ok, I pulled out a couple extra caps for replacement
                                      2 x 50V, 1uF Fuhjyyu General Purpose capacitors - Replacing with Nichicon PW
                                      1 x 16V, 220uF Fuhjyyu General Purpose capacitor - Replacing with Rubycon YXJ
                                        • 31209
                                        i use YXJ for 1uf and 2.2uf on everything.
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • dragon3x
                                          by dragon3x
                                          power on.
                                          Here are some examples :
                                          switching supply area).
                                          than 6.3 V.)
                                          03-21-2025, 02:46 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          11-20-2024, 08:52 PM
                                        • CWEastwood
                                          Antec Smart Power SL300S capacitor replacement.
                                          by CWEastwood
                                          I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                          The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                          I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                          Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                          03-25-2023, 12:18 PM
                                        • slybunda
                                          AA and AAA battery charger capacitors?
                                          by slybunda
                                          hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                          it has inside:
                                          2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                          2 x 470uf 16v LZ105c branded as G.Luxon
                                          not heard of these brands are they any good?
                                          iv attached photos of the charger and the board inside for an idea on the type of...
                                          12-24-2023, 04:41 AM
