Is this bad?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    #41
    Re: Is this bad?
    Chris, can you post some more pics of the board like including an overall pic and also one of the cpu caps.
    • Chris1992
      • Apr 2005
      • 561
      #42
      Re: Is this bad?
      Overall pic coming soon. For the CPU cap pic I'll have to take off the fan but they are Rubycons.
      The great capacitor showdown!
      • Chris1992
        • Apr 2005
        • 561
        #43
        Re: Is this bad?
        Also, does United Chemi-Con make bright blue low esr caps? I have a few Mercedes logo vent caps of that colour on my Dell board.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          #44
          Re: Is this bad?
          leave the fan, its ok if they are just rubycons there. united chemicon does make blue caps. they will probably have a rectangle and then say the series like KZE or something.
          • Chris1992
            • Apr 2005
            • 561
            #45
            Re: Is this bad?
            I'll have to take off the fan to get my camera down there.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              #46
              Re: Is this bad?
              Chris, a while back you posted this :
              560uF 4v (the cap). And my confuser now boots up and is stable. Just had to clear CMOS and take out my Linksys wireless card. Thanks for the clarification, Neo. Now i just need to borrow a DVM....
              what is the problem with the pc now? did it have boot problems after the above event.
              • Chris1992
                • Apr 2005
                • 561
                #47
                Re: Is this bad?
                No problems at all. The wireless card I just needed to take out. Don't really need wlan anymore now that I don't have broadband.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  #48
                  Re: Is this bad?
                  i wouldnt bother recapping it then at the moment. if you have boot or stability problems again later then it would be worth considering. i have those yellow caps on several boards which are working fine for quite a few years. the rubycons and chemicon will be fine.
                  basically what i dont recommend is to take a working board and then recap it as your first attempt at recapping and then nuke it accidentally. non working boards are different cos you have nothing to lose.
                  in response to your question i have seen those yellow caps commonly replaced by 820uf 6.3 on different board revisions, so 1000uf 6.3 would be great also. The thing is that when you see 25v nearby you have to be careful that the p4 12v line is not running through the caps, although i would not expect that they would be running the yellow ones rated for 4v at 12v instead.
                  if you are still interested in recapping then get a mobo with badcaps as a project and then recap it to learn the technique.
                  what happened to the broadband? it is dissapointing to have to go back to dialup...
                  • Chris1992
                    • Apr 2005
                    • 561
                    #49
                    Re: Is this bad?
                    Broadband just suddenly stopped working and a Comcast tech couldn't get it back. I got my Digikey catalog yesterday and out of curiosity I looked up the Nichicon series of the caps next to the yellow ones. It's VR, which according to Digikey catalog, is an 85°C rated part and not low ESR. How could they get away with this (not putting low ESR caps on a motherboard)?
                    • jasonbay13
                      Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
                      by jasonbay13
                      it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
                      PU200
                      pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
                      pin 8 vreg3 = 0v
                      pin 13 en = .2v
                      pin 1,6 entrip1,2 = 0v
                      b+ and b++ = 19.5v
                      +5valw = 0v & 25+ohm to ground
                      +3valwp = 0v & 25+ohm to ground
                      i cleaned the board up just a little and can get more pics.​
                      where should i be looking? thx...
                      09-25-2025, 10:54 PM
                    • Mufasa
                      Kodak Lumia 150 projector Part Identification - Power Button
                      by Mufasa
                      I have a Kodak Lumia 150 projector and the power switch fell off the circuit board when the button was pushed. The power switch itself is missing and I can't figure out where to find the replacement.
                      Anyone familiar with where to find this type of button and how to source it?...
                      05-09-2025, 07:09 PM
                    • selldoor
                      Kodak Printer drivers ESP7 ESP5250
                      by selldoor
                      Long time no post!!
                      However I need help with a Kodak Printer Kodak All in One Easyshare ESP7. or an ESP 5250 but happy to try anything.
                      Some years back I got these two printers off freecycle and one came with new cartridges In sealed box ( fit both printers)
                      I have just got round to trying to get them working and find that Kodak gave up on personal printers
                      and will not even look at any queries since 2012 !!
                      The printhead on the ESP 7 was dried out but I am gradually getting that unclogged, so working on the main problem
                      which is that...
                      04-15-2023, 03:14 AM
                    • playit
                      ccfl lcd laptop repair help, pics attached
                      by playit
                      this lcd first started showing green lines horizontal ,with flickrs then one day stopped showing rest of the screen , now it just like in the pic , i can see mouse at top,also the icons at right end of screen , i also tried to look around the cable wires ,adn loosened it ,but its the same result . i tried the flex test , the monitor changes to white ,and different colours, but dint show the actual picture , external monitor vga connection is good, so please guide me what next to do . please verify the pics, thank you ....
                      03-15-2023, 05:08 AM
                    • SluggerB
                      Help with trying to fix phone that is not charging (Pics inside)
                      by SluggerB
                      I have two TCL A30 phones.
                      Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                      New Phone: Works fine, bought as a donor board to try and repair Old Phone
                      My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                      08-12-2024, 08:11 AM
