Kodak Printer drivers ESP7 ESP5250
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Long time no post!!
    However I need help with a Kodak Printer Kodak All in One Easyshare ESP7. or an ESP 5250 but happy to try anything.
    Some years back I got these two printers off freecycle and one came with new cartridges In sealed box ( fit both printers)
    I have just got round to trying to get them working and find that Kodak gave up on personal printers
    and will not even look at any queries since 2012 !!
    The printhead on the ESP 7 was dried out but I am gradually getting that unclogged, so working on the main problem
    which is that drivers are hard to find. They show up in a few places as aio.install.exe and it goes through the motions
    of downloading and installing but then fails saying I have a network problem. ( I have seen this mentioned elsewhere so dont think I have.)
    Inks and chips and refill instructions are still available.
    So can anyone help me with the drivers for Win7 or LOL Win10 or Win11
    either as a file or a link to where I can find them. TIA
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Kodak Printer drivers ESP7 ESP5250
    Managed to power up an old PC that runs on win7 that I only use to back up pics.
    Plugged the printer in and it found it imediately and started searching for drivers. First it came up as a camera ? then 5 minutes later decided
    it was a scanner. ( That worked great ) maybe 10 minutes or so it decided it was an AiO ( allinone) Printer and it appears to work though the print output still needs some work.
    Colour is not too bad but Black is barely there. So I am fixed. If I can extract the drivers I will add them to the post. I have also enquired here: https://www.freeprinterdriverdownloa...river-request/
    So will post their reply.
    • re-atari
      Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
      by re-atari
      Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
      Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
      02-03-2025, 06:49 PM
    • Curious808
      Brother HL-2140 laser printer: printer error (solved)
      by Curious808
      SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
      Windows 10
      Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
      Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
      06-22-2023, 11:11 PM
    • Artefil
      HP officeJet 8012e ... A printer update will be installed to fix this problem
      by Artefil
      One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
      On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
      The screen displays the following message :
      "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
      But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
      Have you ever...
      09-28-2023, 05:11 PM
    • japlytic
      DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
      by japlytic
      In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
      Tried (only with keyboard/mouse connected):
      • BIOS + database update
      • Using latest Windows 11 image built with official image creation tool
      • Previous setup version for Windows 11 installer
      • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
      • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
      • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
      06-19-2025, 04:59 PM
    • прямо
      Need dump for 58mm Thermal Printer
      by прямо
      a friend gave me this printer because it's no longer working.
      It powers on, but won't do a self-test print and when connected via USB to Windows, Device Manager says No Printer Attached under USB Hubs tree.
      The red light doesn't blink either with no paper inside.
      I think the firmware maybe corrupted. If someone has a similar printer and can provide a firmware dump, I really appreciate it.
      Printer model: Panda PRJ-58U
      Flash memory: Boyamicro BY25D16ASSIG
      03-15-2024, 09:12 PM
