Motherboard booted now it doesn't
  • Solder Boy
    • Nov 2006
    • 178
    One of the motherboards I was testing booted up okay initially but when I went into CMOS to change the date and time and hit F10 to save and reboot the bloody thing shut right off and now it doesn't boot.
    It starts for 2 seconds then shuts off just as quick.
    Does an acceptable ESR range necessarily mean the cap is good?
    Thanks.
    www.bcrelectronics.ca
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Motherboard booted now it doesn't
    > Does an acceptable ESR range necessarily mean the cap is good? <
    No but it's more reliable than other tests in weeding out duds.
    It's unusual for ESR to be good and something else bad.
    A cap with good uF (capacitance) reading and bad ESR on the other hand is common.
    Mann-Made Global Warming.
    - Dr Seuss
    • tazwegion
      • Jun 2006
      • 444
      Did you pull the CMOS battery out (and jumper the 'clear BIOS' pins)? leave it sit like that for a while letting the residual current drain from the BIOS chip and you should be able to get it back up and running... I've been having the same issue recently with an MSI KT3 Ultra2 that I'm assessing whether to bother recapping or not, it has a sprinkling of quality caps but also some Teapo 1000uF 6.3v clusters
      Viva LA Retro!
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Take out CMOS battery when you recap.
        When you clear CMOS w/jumper or by removing battery have it unplugged too or CMOS will be powered by +5vsb and reset attempt will do nothing.
        - Dr Seuss
        • glovecaps
          by glovecaps
          11-25-2024, 04:23 PM
        • Docus
          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
          by Docus
          Hi everyone 😀,
          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
          1. I already own the exact same model, but its plastic chassis is badly damaged.
          06-10-2025, 04:24 PM
        • Archimedes
          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
          by Archimedes
          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
          Fans are spinning. Blindly could install windows11 and got the device manager...
          07-30-2024, 05:14 PM
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
          ASUS P5GC-MX motherboard recap
          by momaka
          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
          So here is what the motherboard looked like with its original caps:
          CPU VRM area up close…...
          01-27-2021, 11:59 PM
