Cap Identification please.
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    #41
    Re: Cap Identification please.
    Originally posted by Behemot
    None of those pens will ever work as well as transformer soldering gun, it's just physics.
    A temperature controlled Weller or Metcal with a reasonably high mass tip would probably do OK. Not that Weller is cheap or Metcal is in any sense inexpensive.
    PeteS in CA
    • Behemot
      • 4845
      • CZ
      #42
      I am not exactly sure what is reasonably high mass tip, but I use 2.5mm^2 solid copper wire for my 150VA gun.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        #43
        I don't think its vrm out, so I would not risk 2.5v.
        the 3.0 version of the board had the cap as a real polymer there, I think its a reg cap for that chip up there
        the output vrm is lytics
        http://static.nix.ru/autocatalog/mot.../53036_top.jpg
        • Wester547
          • Nov 2011
          • 1268
          • USA.
          #44
          The image in that URL shows wet electrolytics, not polymers. Those are sleeveless Panasonic FL without a vent stamp. Behemot dissected some 6+ years ago.
          The font on the failed 680uF 4V capacitors reminds me of Suncon (formerly Sanyo's electrolytic division). The font and vent stamp are both a match.
          • Behemot
            • 4845
            • CZ
            #45
            Seems like these custom short caps were quite common for a time of the 775 era. Always around the socket, under heatsink.
            • sunofra78
              ASROCK B460 Steel Legend Component Identification #2
              by sunofra78
              Would anyone know what this component may be? It's on an ASROCK B460 Steel Legend Gaming PC Motherboard. The writing on it is 29 7B / 43N.
              Thanks....
              11-21-2024, 09:33 PM
            • gabrieljma1
              Request: Full BIOS dump for ASRock Z790-CX (DDR5)
              by gabrieljma1
              I’m looking for a full raw 16 MB BIOS dump for an ASRock Z790-CX (DDR5) motherboard.
              The board powers on (fans spin, RGB lights on, RAM LEDs active), but there is no display output and the VGA and BOOT LEDs stay lit.
              I’m using an Intel i9-14900KF CPU (14th gen), and it seems the BIOS version on my board doesn’t support it yet. I tried to flash the official ASRock BIOS file (renamed .ROM → .BIN) directly using my RT809H programmer, but it didn’t work — monitor stays on but with black screen, so I believe the ASRock update file is not a complete...
              10-08-2025, 03:32 PM
            • harp
              Metod for removing glued heatsink from fragile component
              by harp
              I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
              06-23-2025, 02:01 PM
            • DOBBELDUNK
              NEED Bios File ASROCK H61M-VS4 REV.G/A 1.01
              by DOBBELDUNK
              Mobo turn on, HSF on but no display, blank only in monitor.
              Here is bios backup of asrock h61m-vs4 rev. g/a 1.01
              11-20-2025, 10:07 AM
            • Ven
              Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
              by Ven
              I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
              The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
              I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
              If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
              07-08-2024, 09:32 AM
