Subsitute for Samxon GF 2200uf 10V
  • krjune
    • Dec 2008
    Any one know what and where I can find a substitute for Samxon 2200uf 10v GF (M) 105 C8? The replacement needs to be the same physical size.
    thx
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Subsitute for Samxon GF 2200uf 10V
    whats the diameter and height in MM?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • krjune
      • Dec 2008
      10mm x 20mm
      • Krankshaft
        • Jan 2007
        • 2328
        Dang Panasonic FCs and FMs only have 12.5 X 20mm.
        Do you have 2.5 mm of wiggle room for can width?
        If so you could use caps from either of those series'.
        I can give you the part numbers of the specific sizes if you want.
        Learning to use the manufacturer's datasheets for proper sizing is essential in your case.
        • Big Pope
          Approved Vendor
          • Dec 2005
          • 426
          thx
          Would you mind tell me Samxon GF 2200uF 10V in what hardwares you get?
          Would you consider to try Samxon GT?
          My SAMXON Capacitors Database HERE!!
          X-CON is a new brand for SAMXON's Polymer Capacitors.
          • Mike2501
            • Jan 2009
            Hate to thread jack, But I have the same samxon GF 2200uf 10v caps on a LG 42LB1DR power board.
            Would those samxon GT caps be a sufficient replacement?
            • c00kiemon5ter
              • Nov 2012
              • 6
              • Greece
              hello all,
              I know this thread is already 3 years old but ..
              I own a psu - Chieftec CFT-650-14C 650W - which after a power failure it went dead.
              So I opened it up and found a bad Samxon capacitor.
              It is exactly the same as the one discussed in this topic - Samxon GF 2200μF 10V.
              I see that GF 2200uf are not out there anymore and Big Pope suggested Samxon GT's.
              I went to the local market and shops around here and all I could get were some Lelon and Trec caps. I got a Trec cap and replaced the samxon and the psu is now working again.
              But .. I would like to replace it with a proper quality one.
              So I would consider the Samxon GT if you believe that's a good replacement.
              Should I go for it ? Are there any suggestions for some other cap ? and, uhm,
              may I ask where I can find them (I do not see them on the samxon stock page) ?
              • c00kiemon5ter
                • Nov 2012
                • 6
                • Greece
                alright, found the where to buy caps topic
                edit: the first link for Greece (Caritato Supply) is not working anymore.
                • c00kiemon5ter
                  • Nov 2012
                  • 6
                  • Greece
                  I finally got a Chemi-con KZM series cap, 2200μF 10V
                  hopefully it will hold good inplace of the Samxon.
                  • pixelpadre
                    • Feb 2013
                    • usa
                    My power board on my RCA 46" LCD has some bad caps. I cant figure out what to replace them with. The ONLY markings are as follows"
                    W2A 105DEGREES C8
                    Any ideas what this is?
                    Never mind I found a blind spot and it said 1000uF 35v
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      W2A 105DEGREES C8
                      Not sure why you have posted in this thread but in any case a picture would be really helpful W2A can sometimes relate to a capacitor array.
                      Full TV model number would help and board number the cap is on and the board marking for the cap C???
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        Give the model number of the TV as well, so I can split this off into a thread of its own. This is totally not on topic for this thread.
                        Team : 49813
                        Join in!!
                        Team Stats
                        • chth96
                          Can I replace KME cap with Samxon GF cap?
                          by chth96
                          Hello.
                          I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                          Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                          I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                          04-17-2024, 07:11 AM
                        • learnmore
                          How to choose a substitute mainboard
                          by learnmore
                          Hello again Community
                          Anyone verse on how you go about choosing a substitute mainboard for your TV repair. Like the chap in the video below sometimes a 1:1 replacement board is too expensive and reballing a mainchip(s) maybe outside of your skillset . In the video the poster states one needs to match the replacement board with the SMPS, T-con (if not built in) and panel (and substitute cabling be also be required).
                          I'm very interested in choosing a suitable replacement board for any model or make of TV and the general (or detailed if your willing) step this entails....
                          03-23-2024, 02:55 AM
                        • Grasshopper2Ant
                          ACF Remover G-450 Substitute in Canada
                          by Grasshopper2Ant
                          Hi All,
                          Need help sourcing a substitute for ACT remover G-450 in Canada.
                          Removing glue from Flex Cable on LED TV that I dislodged so I can resolder with ACF tape.
                          Can someone confirm if acetone will work?
                          They will not ship to Canada.
                          Thanks for any help....
                          08-15-2023, 02:00 PM
                        • jdczerwin
                          Physical Electrolytic Cap Size Question
                          by jdczerwin
                          My question has to do with through-hole Electrolytic Capacitor physical size and finding the correct specification in ordering a replacement.
                          Example: I'm working on an old video arcade monitor. The parts list calls for two (2) 6800pF, 50V Electrolytic Capacitors (ECap). Based on that specification, you can go to Mouser, DigiKey, etc and get a through-hole ECap at that spec…and get a far smaller one (physical size-wise) than what was on the board.
                          From my limited knowledge, I understand that size does matter in this application because of the stress that the circuit...
                          01-15-2021, 09:08 AM
                        • Andriy Andrusyk
                          How to Identify My GPU When CPU-Z and Physical Labels Disagree?
                          by Andriy Andrusyk
                          I recently bought a used GPU that was advertised as an MSI GeForce GTX 1080 Ti. The backplate label also identifies it as a GTX 1080 Ti, and the label looks untampered.
                          However, when I run CPU-Z, it detects the GPU as a Radeon RX 480.
                          I inspected the PCB and found a second label near the gold connector reading: V341 VER:1.1 From what I've found online, V341 PCBs are typically used for Radeon RX 480, while GTX 1080 Ti cards usually use a V360 PCB.
                          Is it possible the card was BIOS-modded or relabeled? What's the most reliable way to verify the actual GPU model I have?
                          05-13-2025, 01:32 PM
