Hello guys, I want to take a couple caps from a dead Mobo, as I always do but this time they are just breaking apart, leaving their legs on the mobo, those are some polymer and pannys FL and FJ
How can i?
Re: How can i?
lol panny fj and fl are sometimes known to do that. i pulled a few off a mobo and the legs were left behind. i've seen other members report the same.
however, im not sure about polymers doing the same. what polymer is that? also is the mobo from the leaded solder era or lead-free solder era? could be the solder wont melt, thus the legs are left stuck on the mobo. haha!
Re: How can i?
You can't order new caps in Venezuela they are all Chinese shit. And ordering new ones from digikey or farnell because shipping would be too expensive for me at least. A normal salary in Venezuela is 20/30usd so 10/15 on a bag of caps is just too much.
I tried applying leaded solder but it didn't work that well. The heat gun helped me a lot because I have the fl's on a Mobo that needed new capsComment
Re: How can i?
It's a scrap board, right? just use your regular iron and add some extra heat with the heat gun, you will need someone to help, but this method really works in big ground areas.Comment
Re: How can i?
try radio sparesYou can't order new caps in Venezuela they are all Chinese shit. And ordering new ones from digikey or farnell because shipping would be too expensive for me at least. A normal salary in Venezuela is 20/30usd so 10/15 on a bag of caps is just too much.
Re: How can i?
Why buying from those overpriced corporation pricks when you buy from me for half the price?
If you have the market for them and you are able to sell it, ordering regularly, I can give you flat-rate discount too no matter if you reach each model quantity discount level
Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
by corrizeHello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
See the test :
https://youtu.be/bNAzC-EvqHs?t=1767
With hot air from bellow the board, that's... -
by petemanukSo I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder... -
by myth77Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
Is there any solder mask... -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... - Loading...
