Dropping down 2 volts??
  • Electone
    • Mar 2016
    • 19
    I'm about to recap the power supply on a very large Yamaha organ from the 1980s. It has four large caps on the main power supply: 2 x 10000uf 65v and 2 x 10000 55v. These values are not easily obtained any more. Would it be an issue if I replaced all four with 10000uf 63v? Would the 2v drop in two of the caps be a bad idea? Thanks.
    • 31288
    Re: Dropping down 2 volts??
    i cant see any problem.
    if in doubt, post the model or a schematic so we can see the actual voltage going into them.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      You'll be fine.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        I would check what voltage they are been run at just to be sure.
        My pc
        CPU : AMD PHENOM II x4 @ 3.5Ghz
        MB : ASUS M4A89TD PRO USB3
        RAM : Kingston ValueRAM 16gb DDR3
        PSU : Cooler Master 850W Silent Pro
        GPU : ATI Radeon HD 6850
        • Electone
          • Mar 2016
          • 19
          Looks like the cost of two 80V caps is not that much more than the 63V. So, I think I'll buy two of each. Thanks for the help.
          • u666sa
            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
            by u666sa
            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
            Platform: ipa32 la-m024p rev 1b
            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
            I found a short on the other side:
            10-04-2025, 05:03 PM
          • supermattch
            HP 15dy-2021nr wont power on mystery volts
            by supermattch
            Hi everyone.
            I am diagnosing my personal laptop, because it wont power on and no leds light up.
            At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
            Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
            09-23-2025, 12:13 PM
          • MisterAIL
            PS5 digital / No Power / No Beep / Good power supply
            by MisterAIL
            Brought a non functionnal PS5. Apparently only a bad PSU...
            No beep, nothing.
            After some tests i found this :
            - PSU is fine (12 volts stable)
            - 12 volts line is shorted
            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
            - By the way, nothing change. No signal, no power, no beep.
            Mesuring all rails with my workbench psu (12 volts input)
            - 0.00 amp drawing
            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
            03-12-2024, 03:24 PM
          • Mcfeetroy
            Fishing bite alarm drains battery
            by Mcfeetroy
            Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
            08-01-2025, 03:52 AM
          • BTubbs200
            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
            by BTubbs200
            Dell Latitude 5420 P137G
            Board: LA-K491P REV A01
            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
            Board seems to have no shorts, all power rails are fine and show high resistance.
            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
            01-24-2025, 08:15 PM
