Jura Coffee Machine grinder motor
  • Trashnetter
    • Nov 2016
    • 5
    Hi
    Not sure where to post this.
    I have just received from overseas my replacement coffee machine grinder motor however this motor which is 230vdc does not have the same capacitors fitted to it as the original does.
    Silly question if anyone knows would they be needed? What are they for? Just wondering if i need to install on the the new motor as they are on both positive and negative terminals then spot welded to the the motor body. I believe they are 1.0 to 2.5nF according to online data sheet. Perhaps for noise ?
    Thanks for any info in advance
    • 31214
    Re: Jura Coffee Machine grinder motor
    noise filters,
    but shouldnt it be 230v AC ??
    • Trashnetter
      • Nov 2016
      • 5
      Hi
      Noise filters you believe?
      Yes, definitely 230VDC. The US models run 110VDC. Must be a control thing as when there are no beans in the grinder it figures it out through load on the the grinder, no other sensors to tell you its empty! Yet some how it knows.
      Thanks for your reply though.
      But yes the unit obviously plugs into 230-240v AC
      thanks
      • R_J
        • 9591
        I agree, they are just noise supression capacitors. the value is not too important, put'er in.
        • Trashnetter
          • Nov 2016
          • 5
          Thanks very much for your input. Putting her in
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Noise filters indeed, as the two other posters before me said.
            When high torque is required in a small space (such as in a food processor, blender, grinder, etc.), then typically DC motors are used, as they have much higher starting torque, especially for their size. Only when you get to the larger applications, such as in-sink food disposers, garage door openers, etc., then AC motors are typically used.
            • double_DD
              Transformer replacement for a dead coffee machine
              by double_DD
              Hi guys,
              I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
              Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
              If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
              My other ideas:
              - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
              - to buy...
              06-23-2025, 05:43 AM
            • mon2
              Saeco SG200E Coffee Machine
              by mon2
              Hello. Have a known good Saeco SG200E Coffee machine but the internal hose from the pump were disconnected. Would someone be kind enough to share a few clear pics of the inside of this machine so we can reconnect the hose plumbing again? Many thanks....
              04-25-2024, 10:24 AM
            • Gaz54uk
              AEG coffee machine no steam
              by Gaz54uk
              Hi. I have a built in AEG model PE3810-M coffee machine after about 2 years from new it had a problem were no steam would come out of the wand so i paid £80 to have it repaired after 6 months the same faulty happened again but the repairers said they only give 3 months warranty so we just left it sat there but now i'm wanting to get some use out of it, i'm 80-90% its one of the solenoids as waters still come out by the wand and the bit where it makes coffee, I've made sure all the pipes are cleared and can hear the pumps going but just not sure and don't want to start wasting money on parts unless...
              01-13-2024, 05:00 AM
            • JupTec
              Thermal fuse for DeLonghi coffee machine EN 167.B
              by JupTec
              I would like to know the "thermal value" of the thermal fuse for the coffee machine "DeLonghi EN 167.B". This value is nor longer visible on the fuse itself (maby 167°C or 192°C or somethong similar ?).
              THANK YOU for your help!
              JupTec
              06-18-2024, 06:54 AM
              ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
              This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-12-2024, 03:28 PM
