4 terminal capacitor is soldered wrong?
  • primetime
    • Oct 2014
    • 12
    I'm servicing the amp on my subwoofer. Each of the two main AC capacitor filters(10mF 80V) have four terminals. The two capacitors are in series. I read the spec sheets on a different capacitor at Mouser and it stated that the two blank terminals should be isolated from either the positive or negative terminals. They are for mechanical support only. Yet, one capacitor has one of its blank terminals connected via a trace with its positive terminal and the negative terminal of the other capacitor. Is this a mistake in the design of the circuit board?
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: 4 terminal capacitor is soldered wrong?
    These seem to be 2-section electrolytic capacitors. Leave them connected as-is.
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
      Can we see good clear pictures of the caps and the circuit board?
        • 31024
        get the datasheet.
        some have all the extra's connected to "-" and some say "dont connect"
        • primetime
          • Oct 2014
          • 12
          View Me
          I uploaded 3 pictures on OneDrive. I circled red the position of the two capacitors. I have not been able to find any info on the Soundia Capacitors. So I don't know if they are upto spec or not. But based on my measurements, capacitance is at 9mF, dissipation factor at 2.2, ESR at 100KHz is 0.3 Ω, ESR at 120Hz is 0.4 Ω. Both pretty much measure identically. Looking at spec sheets of Nichicon at Mouser, these Soundia's don't look too good.
          It looks like I can use two lead capacitors, but will probably need to glue them down for support.
            • 31024
            in that aplication, the most important thing is the ripple current - you want the highest possible.
            and that gets expensive,
              +1, They are just filter cap for +/- dual supply, one cap has NEGATIVE leg to circuit GND, and another cap has Positive leg to GND.
              • primetime
                • Oct 2014
                • 12
                When I replace those caps should I solder them as before or should I cut the trace around that blank terminal?
                  • 31024
                  you are likely to get ones wih 2 terminals.
                  are the center holes 10mm apart? - if they are then it's for "snap-in" caps.
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    .4 esr on those is lousy.
                    bet you have hum issues.
                    View Me
                    • primetime
                      • Oct 2014
                      • 12
                      Yes, center holes are 10mm apart. I'd prefer to get a 4 legged capacitor if I have a choice since it adds extra anchor given the size of the capacitor and the 15" woofer that will be vibrating it. In fact one leg did break a solder joint.
                      The sub did have hum among other issues. Four other Soundia caps blown. I figured I'll replace all the Soundias.
                      • Prolog
                        RTX 3080 FE Identifying capacitor
                        by Prolog
                        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                        I hope these photos make it clear which component I am referring to:
                        (yes, the soldering is a bit botched from removing the blown one, I know)
                        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                        12-01-2024, 08:27 PM
                      • chth96
                        If I replace with inferior capacitor, Is it No harm to other IC components at all?
                        by chth96
                        I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                        Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                        It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                        So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                        I know that these capacitor will not last as long as nichicon capacitor...
                        12-22-2023, 04:34 AM
                      • chth96
                        How can I test non-polarized capacitor?
                        by chth96
                        I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                        I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                        And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                        I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                        06-02-2024, 07:31 PM
                      • chth96
                        Is it no harm to replace with capacitor without ripple current rating?
                        by chth96
                        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                        Rubycon YK DataSheet (b...
                        04-19-2024, 05:19 AM
                      • chth96
                        Should I replace polymer capacitor?
                        by chth96
                        a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                        I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                        Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                        Is this ESR value of polymer capacitor correct?...
                        11-18-2022, 04:22 AM
